Question about Omega Rear Drive Wheel Snapper Mowers
I have a Snapper Yard Cruiser with a Kohler 15 hp OHV engine. Family no.SKH426U1G2RB; model cv15s; spec.no.41570. I bought this mower new and started having fuel troubles after about a year. My dealer rebuilt the carburetor but I started having the same trouble after a few weeks. I took my mower to another snapper dealer and they replaced the carburetor along with a lower engine gasket which started leaking oil because of the gas which kept leaking into the oil past the piston rings. Now my engine has developed the same troubles, plus this morning I see that I have a mix of oil and gas on my garage floor under my mower and no oil showing on the dipstick. I got a little ahead of myself. The trouble with my engine started with backfires then the engine wouldn't turn over because the cylinder filled with gas and I had to turn the flywheel or pull the sparkplug to get the gas out the cylinder to relive the pressure on the valves. Then when the engine did start it blew raw gas out of the exhaust. My question to you is what I can do to take care of the problem as I don't trust the carburetors for this engine. I can't believe I am the only one to experience this problem. Has Kohler ever had a recall due to this problem? Now with the oil on the floor would it be cheaper to get a new engine than to have this one repaired? The last time I had the carburetor and gasket replaced my bill was almost $500. Thank you for your time. Joe
I HAVE THE SAME PROBLEM. As soon as you shut the mower off, lift up the seat and turn the gas shut off to the closed position. Do this even if you are only going to be off the mower a few minutes. When you need the mower started again, open the gas shut off and start the mower.
Posted on Oct 14, 2011
My snapper yard cruiser Lou runs drives turns left right but when I pull the PTO switch the blades will not engage it's a snapper z yard cruiser with kohler engine
There are limit and safety switches in the wiring circuit. When it registers a back-up it disables the blades or turns the engine off. Find the backing switch and try to temporary bypass it
Jul 10, 2015 | Snapper Garden
Engine starts fine. Go to release the brake and it stalls. Snapper pro 61"
u have a bad switch or a wire touching somewhere maybe the sit switch
Oct 14, 2013 | Snapper Pro S200x 27 Hp Kohler 61"...
Need help with KOHLER COMMAND 15.5 hp (model no.cv15s)
Are you sure the anti fire solinod in the bottom of the float bowl is working as this will shut the fuel off to the main jet, remove it, now switch the ignition on, the needle should retract fully into the housing, failing that there has to be some dirt in the jets, perhaps you could get the carb sonic cleaned this should help to unclog any jet orafices
Jun 15, 2013 | Craftsman Garden
I cannot disengage the cutting attachment so that the mower will start; it seems like it is stuck, because when I attempt to disengage the blades the lever will not move into the disengaged position. How...
You haven't specified the model number, but pretty much all riding mowers use a plunger-type electrical switch to engage the mower. If it's stuck in the 'lifted' position (mower engaged) then it has broken internally. You must replace it. In doing that, the wires need to be placed back on the correct terminals, so take a picture of the wires (showing their colors) before you disconnect them from the switch. Take the broken switch to a lawnmower shop to find a replacement. Shouldn't be more than $10 - $20. Good luck! Please rate my solution if you found it helpful.
Jul 03, 2010 | Craftsman Garden
Snapper yard cruiser 33in. cut joystick blows
Unplug the engagement clutch[it bolts to the motors crank] and try to engage again.If the fuse does'nt blow you need a clutch.If it does still blow you need a switch or you have a short in the harness.
Nov 03, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What type of oil does a OHV 17.5 HP Kohler engine; number of zerk
10w-30 oil. The only grease fittings I know of are on the front wheels and axles.
Jun 22, 2009 | Mtd 22" Yard Machine Push Mower
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Feb 26, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Omega Rear Drive Wheel Snapper Mowers Logo
706 people viewed this question
Top Omega Garden Experts
cwradio73
Rodney Carroll
Level 1 Expert
randy yarpos
randy yarpos
Are you an Omega Garden Expert? Answer questions, earn points and help others
