BenQ projector says filter not well attached several times then will turn off in 1 minute. We cleaned the filter then it still did not fix it. What do we need to do.
  • 3422 Answers
SOURCE: Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Posted on Feb 25, 2008
Marrie
  • 563 Answers
SOURCE: "clean filter" prompt
Hi there
Not at all. This promp automatically appears after a certain amount of hours.
To get this message away , all you have to do is go into the Menu and reset the Filter Timer.
Posted on Apr 15, 2008
SOURCE: Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Posted on Oct 07, 2008
Marrie
  • 563 Answers
SOURCE: benq 8250 projector shuts down
Hi david115
I've had this problem MANY a time before and what BenQ does wrong is that they only replace the two main fans at the back of the PB8250 , they should in fact replace both the fans and the Mainboard. This is unfortunately the only way to get around this problem.
Posted on Dec 12, 2008
projdoc
  • 2236 Answers
SOURCE: my benq projector turns on for a few minutes
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Posted on Nov 30, 2009
BenQ SP920P projector overheats and turns off after a minute of use
Is your power supply clean ? and check which IC is heating up ? are you sure u have no air filters in it ?
Dec 10, 2013 | BenQ SP920P Projector
Red lamp/ orange/lamp After a "break" of about
test this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 28, 2013 | BenQ PB6110 Multimedia Projector
I have a Benq w710st DLP projector and when i turn the power on after a minute it turns off. The power button turns off and both the lamp and temp lights turn red. How do I fix this and can I do it my
New bulb is probalbly needed. You need to find out what zero means on that projector. The real problem is finding out why the cooling fan is not turning on. This is probably the reason that the temp light is coming on.
Jan 06, 2013 | BenQ W710ST 3D HD Short Throw DLP...
The projector has several white dots on the screen. how can i fix it, it started with a few white dots then every time i used it, it doubles and doubles until it became many dots.
I have the same problem. I think we need a class action!
http://s1231.photobucket.com/upload/albums/m3231/?location=projector+spots
Oct 06, 2010 | BenQ MP511 Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
My projector screen has js turned all bluish! Instead of the black background, it is all blue, and the entire movie color is messed up...the lamp life is only 300hrs!! i've had the projector for almost a...
the light filter on the blue lcd is fried due to excessive dust and heat. clean it out with canned air and replace the filter. unfortunately, you might have to replace the entire optical engine because benq doesn't sell individual parts for it.
Oct 22, 2009 | BenQ W500 Projector
BenQ 500W projector shuts off after 10 minutes
it has lamp which has 2000hour in normal and 3000 in econom mode to shinenormal then it must be changed and your may already in this state and began such things.
Aug 18, 2009 | Televison & Video
Color problem
Check the cables connected to the back of the projector. reinsert the cables a few times to get a good contact. Jiggle the connection at the projector to see if there is a bad connection, do this while viewing the image on the screen. If everything is good and no response to the connections, It might be the main/input board is bad and will need replacement.
Aug 16, 2008 | BenQ PB6100 Multimedia Projector
Problems with keeping the projector on!!
if it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Dec 08, 2007 | Mitsubishi HD4000U Multimedia Projector
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
