Question about Motorola Mobility TracFone® V170 Cellular Phone
Why deleting calls,set date/time
  • knixon May 30, 2008
    Did this, however it is not changing the date, only the time was able to be set correctly.
  • Anonymous Feb 03, 2009
    I went through the above solution, when I went to change the date, it was already correct. But on the display it still shows 11/10/09
To set date and time go to "settings" on main menu, then "other settings" and then to "initial setup."
Posted on May 20, 2008
When i go into my 'calls' menu it brings up numbers from october last year. Not recent calls
hi lindsay volk and welcome to fixya,
Try to delete first all your call logs and check your set up time and date. Your time zone should be at "GMT"
thanks and have a nice day
Jan 11, 2011 | Cell Phones
How do you clear memory, and set date and time 712c
To delete all the records :
  1. Press the MEMORY button
  2. And while holding the MEMORY and the START/STOP button simultaneously for more than 2 seconds all records will be deleted.
To set date/time :
  1. Press the Date/Time Setting button to adjust the date and time (the year flashes on the display)
  2. Press the MEMORY button to advance by increaments of one year and press the Date/Time Setting button,
  3. Press the MEMORY button to advance by increaments of one month and press the Date/Time Setting button,
  4. Press the MEMORY button to set the current day and press the Date/Time Setting button,
  5. Press the MEMORY button to set the current hour and press the Date/Time Setting button (the time is set using AM/PM)
  6. And finally, press the MEMORY button to set the current minute and press the Date/Time Setting button.
Jun 14, 2010 | Omron Healthcare Omron Hem-712c 712 Blood...
How do I set up my Durabrand Phone Model PH-5595 (HAC)? I have lost my manual. Where can I get one? Thanks! George Tabb
Press Delete and Down at the same time to bring up the menu. The first screen will be the LCD display. You can adjust that by pressing up or down. Once selected, Press delete to go to the next screen. Next ones will be Language (E for English), Area Code, Time, and Date. You Use the Up and Down buttons to adjust those settings. The Delete button will act as a Select button while you are in the menu feature. Date & Time usually sets itself after the first call if you have caller id.
Jan 16, 2010 | Lands Phones
Displaying time and date when printing
The date/time cannot be deleted once it is embedded in the image. To turn off the date/time deselect the date/time stamping by following procedure:
These instructions explain how to insert the date in images.
  • The [Date Stamp] cannot be deleted from the image data once it has been recorded because the date is written in as an image.
  • When selecting [Date Stamp] , [Recording Pixels] is set to 1600 x 1200 pixels and the compression (image quality) to [Fine].
  • When the shooting mode is set to <Movie> (g0029623.gif), settings for inserting the date and time cannot be made.
  • The following explanations are provided based on the assumption that the [Shooting Mode] is set to <Program AE> (g0034813.gif).
1. Press the <Power> button on the camera.
2. Press the <FUNC./SET> (g0046915.gif) button.
3. A screen like the one below will appear on the monitor.
Select g0013174.gif [Date Stamp] (g0013171.gif) in the [Recording Pixels] section g0013173.gif.
g0013176.gif Press the <MENU> (g0046624.gif) button.
4. A screen like the one below will appear on the monitor.
g0013173.gif Operate the <directional buttons> left or right to select [Date Stamp] and set it to [Date] or [Date & Time].
g0013174.gif Press the <MENU> (g0046624.gif) button.
5. Press the <FUNC./SET> (g0046915.gif) button.
6. Make sure that the [Date Stamp] is set and the following screen will appear with the icon (g0013164.gif) in the lower-left corner of the screen.
7. When shooting with this setting, the date will be embedded in the image as shown below.
g0013173.gif [Date]
g0013174.gif [Date & Time]
warning: The date, its font and color, and the position where it is displayed cannot be changed. Also, dates and times recorded with [Date Stamp] cannot be deleted.
If you need a manual for the A480, you can download it from:
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PowerShot A480 Digital Camera
Call log is deleting
solution 1:
please try to set the date properly.that is current date,
solution 2:
restore your phone using this code *#7780# reset to factory settings.
Sep 22, 2009 | Nokia E71 Smartphone
Delete all pictures at one time
to delete all the pictures at the same time all you have to do is to press the button that gets up you photos and then open up one of the menus and go delete pictures delete all then yes. to set the date make sure you are on the normal screen so you can see what you are going to take a picture of and then go onto the settings click date and time and you can then set the date and the time, once you have put the date and time in press ok and it is done. you can then go off the menu if needed.
Feb 26, 2009 | Vivitar ViviCam 4345 Digital Camera
Unable to delete Missed, Dialled And Received Call lists.
I think you should check the date/time setting and make sure that it is correct, then try to delete the call list again.
Feb 04, 2009 | Nokia 9300 Smartphone
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Blur Warning
See Understanding blur warning icons.
On Off
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Cidco inc caller id box - model # JA-25A-18
When a call is received it will automatically set the time and date. To change the display contrast hold down the 'delete' button while toggling one of the other buttons. Hold the delete button down until the 'select,mem,mode' is displayed and choose between '25 name & number' or '64 numbers' . Make sure the batteries are good and the batt indicator in top left corner of display is off. I think that is all the features this early model unit was capable of.
Sep 29, 2008 | Home Security
Motorola v170 tracfone
press the center button. Then press the down arrow. when you get to 'recent calls' then press 'select.' You will have three choices, select received or sent or missed. When the call comes up, then press the center button again and you should have a choice of deleting that call. Press yes, the white dot on the right.
May 14, 2008 | Motorola Mobility TracFone® V170 Cellular...
Motorola Mobility TracFone® V170 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
