Question about Cycling
How to adjust brakes on a muddy fox hustle dual suspension disc brake. user manual not clear.
3 Suggested Answers
  • 1137 Answers
SOURCE: adjust rear suspension on Mongoose XR-Comp
Here is a good source of info:http://www.bikewebsite.com/suspension.htm Let me know if this helps.
Posted on Jan 18, 2010
  • 58 Answers
SOURCE: I have a muddy fox sprinter how do I adjust the
First of all make sure parking brake shoes are ok. then wit flat screw driver you can adjust the brakes through the small hole other side the brake rotor fits. Basically get under the vehicle between the wheels and look small hole for it, you will see it.
Posted on Sep 06, 2012
I have a Muddyfox stomp has anyone got the instruction manual please
cant find a user manual for that one
is it assembly instructions you need
Oct 27, 2016 | Muddy Fox Cycling
How do I adjust the front disc brake on the Genesis V2100 mountain bicycle, model # 52686?
adjust the cable at the brakes or and piece by turning the retainer that holds the outer cable case
May 24, 2016 | Genesis 26 Inch V2100 Dual-Suspension...
Muddy fox ransom brakes
What are you referring to? Do you have a problem with the brakes?
Suggest you contact your local bike shop for help
Jun 29, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
How to raise handle bars on 20 inch bmx muddy fox
By adjusting the 7 degree reversible headset and adding or subtracting spacers to the rotational bar (attached to front fork)
hope this helps.
Jun 20, 2014 | Muddy Fox Cycling
I have a grinding noise coming from what sounds like the left rear side of my 2003 VL1500 but cant see anything that might cause it
  1. Performance
    • Suzuki has introduced slight changes to the Intruder from year to year, such as variations in accessories and styling. The bike's performance, however, has remained steadily the same. The 2004 model has a four-stroke, 1,462 cc engine with a hybrid air and liquid cooling system. The single overhead cam (SOHC) V-Twin motor generates 67 horsepower at 4,800 rpm. It has a 96 mm (3.78 inches) bore, a 101 mm (3.98 inches) stroke and has a compression ration of 8.5:1. The Intruder also has a five-speed transmission.
    Suspension and Brakes
    • An oil-damped, telescopic fork suspension with coil spring comprises the front suspension. A link-type, oil-damped five-way adjustable spring preload makes up the rear suspension. The front brake system uses a dual hydraulic disc, and rear uses a single hydraulic disc.
    Dimensions
    • The motorcycle has an overall length of 99.4 inches, a width of 38 inches, a height of 45.9 inches and a wheelbase of 66.9 inches. The seat sits 27.6 inches off the ground, the bike clears the ground by 5.7 inches and weighs 659 lbs.
Jan 14, 2013 | 2003 Suzuki VL 1500 Intruder LC
I have a muddy fox sprinter how do I adjust the disc brakes
Sep 06, 2012 | Cars & Trucks
WHAT SHOULD COMPRESSION BE FOR 04 KXF 250
Engine: Four-stroke single cylinder with DOHC, four valves
Displacement: 249cc
Bore x stroke: 77.0 x 53.6
Cooling: Liquid
Carburetion: Keihin FCR37 with hot start circuit
Ignition: Digital AC-CDI
Transmission: Five-speed with wet multi-disc manual clutch
Frame: Perimeter style, high-tensile steel with D-section upper frame rails
Suspension type, front: 48mm inverted, cartridge-type telescopic fork
Suspension adjustments, front: 16-way compression and rebound damping
Suspension type, rear: UNI-TRAK single shock system
Suspension adjustments rear: 16-way compression and rebound damping, spring preload
Wheel travel, front: 11.8 in.
Wheel travel, rear: 12.2 in.
Tire, front: 80/100-21 51M
Tire, rear: 100/90-19 57M
Brakes, front / rear: Single semi-floating 250mm disc, dual-piston / single 240mm disc, single-piston
Compression Ration: 12.6:1 ***********************
Rake/Trail: 26.5 degress/110mm
Overall length: 85.4"
Overall width: 33"
Overall height: 50"
Ground clearance: 13.4"
Seat height: 37.4"
Dry weight: 204 pounds
Wheelbase: 58"
Fuel capacity: 2.0 gal.
Jul 09, 2009 | kawasaki Full Suspension Mountain Bike Men
Would like to know the gas tank capacity for a 1996 xvz 1300 a royal star yamaha cycle, and tire size please
YAMAHA ROYAL STAR Engine Type: 1294cc liquid cooled 70 degree DOHC V-four, four valves per cylinder
Bore and Stroke: 79 x 66mm
Compression Ratio: 10.1:1
Carburetor: 4 x 28mm Mikuni CV
Transmission: 5-speed
Wheelbase: 66.7 in.
Dry Weight: 701 lbs.
Tires: Front; 150/80V16 Rear; 150/90V15
Forks: 43mm Kayaba
Rear Suspension: Kayaba mono-shock with adjustable preload
Brakes: 298mm dual front discs with dual-piston calipers; 320mm rear disc with dual-piston calipers
Seat Height: 28.3 in.
Fuel Capacity: 4.8 gallons
May 05, 2009 | 1996 Yamaha Royal Star XVZ 1300 A
What is the maximum horsepower
It took me over an hour to find this information... Hope you enjoy it!
06/07 Gixxer 600 = Max HP 125, Max Torque 67.7
http://www.motorcyclespecs.co.za/mod...xR600%2008.htm
Suzuki claims 124 on the motor.
Dyno's range from 101 to 109.
Other Specs
Engine: 599cc,4-stroke,four-cylinder, liquid-cooled, DOHC, 16-valve*
Bore Stroke: 67.0 x 42.5mm
Compression Ratio: 12.8:1
Fuel System: Fuel Injection
Lubrication: Wet Sump
Ignition: Digital/transistorized
Transmission: 6-speed, constant mesh
Final Drive: #525 chain
Overall Length: 2040mm (80.3 in.)
Overall Width: 715mm (28.1 in.)
Overall Height: 1125mm (44.3 in.)
Seat Height: 810mm (31.9 in.)
Ground Clearance: 130mm (5.1 in.)
Wheelbase: 1400mm (55.1 in.)
Dry Weight: 163 kg (359 lbs)
Suspension Front: Cartridge-type, coil spring, fully adjustable spring preload, rebound and compression damping
Suspension Rear: Link-type, gas/oil damped, fully adjustable spring preload, 2-way adjustable compression and rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 180/55-ZR-17
Fuel Tank Capacity: 17.0 liter
Color: Blue/White, Silver/Yellow, White/Silver, Black/Matte Black
Nov 24, 2008 | 2008 Suzuki GSX-R 600
Cycling Logo
124 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
