Question about Dometic Heating & Cooling
I was running my furnace and operated normal. during the night it quit. blower motor will not start at all. motor is free and batteries are fully charged. thermostat closes but motor will not start. can not get continuity across points when closed. this is installed in my cobra 5th wheel trailer, 1994 yr
  • 3,083 Answers
On the web the start capacitor for the blower seemed to be the most likely culprit, as relayed in this forum:
http://2manytoyz.com/air.html
This makes sense, since caps dry out and go bad after a few years.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 12, 2010
Blower motor goes off
The ecm controlled motors are know for ecm failure. They do not like high speed(T5 terminal connection). Normally when the ecm is acting up the blower will not work at all. But I've seen em run for a bit then quit. The motor probably needs a new ecm
Oct 21, 2017 | Goodman Heating & Cooling
I have a White Rodgers 50E47-843 Ignition control, my gas furnace gets the call for heat and the exhaust fan starts and runs for 1 min before the LED lights yellow for 2 seconds and then starts the hot...
A certain sequence of events has to occur to start normal operation. My furnace would start the stack blower which would then run forever without the furnace starting up. The service tech replaced the stack blower controller and the ignitor to get things running right again. Remember that some stages of startup are temperature dependent. For example, the burner has to heat the bonnet enough to close a thermal switch and turn on the main.blower.
Oct 26, 2013 | Heating & Cooling
WEATHER KING GAS FURNACE . BLOWER MOTOR COMES ON INSTANTLY ON CALL FOR HEAT AND WONT SPARK IGNITE.
You have a high temp safety open. The control board sends a signal through all safeties first. And if there is a safety open, the board believes the unit is overheating, so it engages the blower to cool it down. The safeties are normally on the blower assembly, near the burners, and near the heat exchanger. Hope this helps!
Sep 24, 2017 | Heating & Cooling
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
Goodman furnace GMP075-3 The thermostat was in the off position over night and sometime during the night, the induced blower and blower motor came on. The trouble light on board blinks 5 times. I checked...
Need your model # to check the codes but, this coming back on after turning the t-stat off is rare. You may have been in a lockout and the furnace re-started. Some furnaces try to start three times , then lock out. Time out, then re-start. The codes should be on your furnace blower door. Write back with this info and i could help.
Oct 12, 2011 | Goodman GMS90703BXA Heater
Gas Furnace will not start when outside temperature rises to 50F
There is a pressure switch near your draft inducer motor that needs to close when draft inducer motor is running. Verify that the switch is closing. If it is not closing, you might have a problem with either the switch itself, or there could be some sort of blockage in your flue. I would start with the switch first. This switch has to "prove" before it will allow anything else to happen. The loud click could be from your switch or your gas valve. If the switch is closing and nothing else is happening, it could be a problem with your gas valve or HSI.
Mar 12, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Furnace Operations
Yes, That is normal for many furnaces, not just the Carrier...
Seems to be a bit dumb but then the ones who desogn these things are sitting behind desks and not out in the field working on them. I'm sure they have a perfectly good reason to have the furnace do that but I have never figure it out....
It does get your attention when the furnace is there running for ever, blowing cold air and burning up your electric....
You just hope that it does not happen when you are away for an extentend period of time...as you said.
Always make sure that if you have someone checking in on your place that they verify the temperature and not just peek in and say yup the furance is running...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Jan 01, 2010 | Heating & Cooling
The furnace send signal to the fan in about 30 seconds, now this fan is set in auto from my termostat, my problem is the fan is starting slowly and some time it don't start, but if I use the option manual...
Depending on the model of the furnace, the blower is either a 2 or 3 speed. When the furnace operates in heating mode with the thermostat in the auto position, the furnace starts the fan when the furnace reaches a specific temperature or after a set time delay, but it operates the fan in low or med low speed on heat mode, when you put the thermostat fan switch in the "ON" position, the furnace operates the fan in "HI" speed, the same speed used for cooling mode. You may have a blower moter that is starting to short. I would recommend having a professional replace the motor before now before it becomes an emergency in the middle of the night during a cold spell.
Oct 10, 2009 | Heating & Cooling
I have a Goodman furnace GMPN080-4 REV B. I had the blower motor take a dive, so I replaced it with another equivalent 115 VAC 60 Hz 1/2 HP motor. I replaced the 10.0 MFD +10% -5% capacitor with a 7.5 MFD...
limit switch is on the heat exchanger black plastic about 1and1/2 in. by 2 in. with 2 wires going to it , it has 2 screws holding it in take it out and check it with an ohm meter and you should not have a reading if it is good
Feb 01, 2009 | Goodman GMS90703BXA Heater
Electric Furnace Trips Breakers
it is normal for a breaker that is run right on the edge (50 amp and your furnance to use 45) to get weak after a while . the first thing you should do is change the breaker with the same type and amp rateing . it should take care if it
Jan 16, 2009 | Heating & Cooling
Heating & Cooling Logo
29 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
