Question about Lenovo Computers & Internet
MY LAPTOP WORK ON BATTRY BUT CAN NOT WORK WITH ADEPTOR
  • 2,567 Answers
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Sep 18, 2010
Dell latitude e6400 laptop bios override password needed
u can easilyn remove the bios password by removing cmos battry for abt 3 to 5 mins and in a laptop the laptop battry itself cointains cmos battry so u just need to take out battry and then switch ont the laptop without battry then insert the battry and switch it on again good luck
Jul 09, 2012 | Dell Latitude E6400 Laptop
I have a averatec 7100 and in 3 weeks I tried to on the power and it would not on. no power the adeptor is on I checked to see if there is a power on the adeptor but the laptop is not charging the battery...
Try removing the battery and then plug in the power adapter and try to power it on. If no good, get someone to test the power adapter with a voltage meter. The adapter may be dead. If the power adapter is okay, you may need to buy a new laptop.
Please let me know what happens, and I may be able to help more.
Regards,
Joe
Jan 02, 2011 | Computers & Internet
Laptop wont turn on
please plug out your old battry
let work with out battris
the poer supply can not suppport 2 high current devices
Dec 13, 2010 | Toshiba Computers & Internet
Will not power on
hi
frist chack your Adeptor if it's working then just chack your bettry
if this two devices are wroking then you have to go for technition becoz may motherboard and HDD prob
May 26, 2010 | Dell Latitude D400 Notebook
After hitting power button to turn laptop on it turns itself off after 2 seconds and keeps turning off and on untill I remove the battery
Remove the battery & connect it via power cable then turn on . If its working then you need to replace the battery. Another way is disconnect the power cable & run the laptop via battery If its working then the problem cames from power cable adeptor. Now if your seen both way same problem its mean the SMPS its damaged and its not able to transfer the power in to the motherboard. Remove it & check the SMPS.As well as RAM too. Thanks & waiting for your Feedback.
Feb 25, 2010 | Aspire Acer 7520-5071 Notebook
Battery is not working
hi i feel that either the battary is ded and needs to be replaced or the battry is not connecting well with the pin alignment inside please try to remove and clean the golden pins aover both sides with contact cleaner and should work if not then sorry u have to replace the battry cauz the battries cannot be repaired
thanks
Jan 24, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Do not have access to the internet
which windows is installed in ur laptop if its windows vista go to network & sharing center click on manage wireless network remove ur wireless network from the list the add the network again and u will be able to connect wirelessly incase if it does work with that go to the device manager & uninstall the wireless network adeptor then click on scan for hardware changes onces the driver is reinstalled u be able to reconfig ur wireless network easily
Aug 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Laptop not charging.can hear ticking inside connection to laptop
check out the batery or may be the adeptor foulty
Jun 07, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
