Code br.07 on cable terminal EXPLORER 3250HD - Televison & Video
2 Suggested Answers
SOURCE: Cable Box compatibility.
my cable box want turn on
Posted on Jun 20, 2008
Odometer light is out, occasionally tire pressure light and ABS light up and stay on the next time you start it they are off.
If your battery is weak you can have intermittent problems with warnings lights going on and off. As a first step have the condition of the battery checked. If it is over 3 years old I would replace it. Also remove the cables from each of the battery terminals and clean the terminals and cables and refit.
If you are still getting the warnings lights popping up after that take the car in for a scan to see if any fault codes are being generated by the computer. I would also be checking the alternator to ensure it is producing the specified power output.
You should also check and increase your tire pressures to eliminate tire pressure as a cause of the TPMS warning popping up.
Dec 07, 2015 | 2006 Buick LaCrosse CX
Tip
Battery Terminals & More
Today's tip is about battery terminals & how to protect them.
I have seen many opinions on this subject, the one i disagree with most seems to be popular among a few "experts" even on this site. So here is my 2 cents on the subject...
Is it a good idea to put Vaseline on battery terminal posts to prevent corrosion? - Not really, & this is why...
Under hood temperatures will cause the petroleum jelly to liquify, and run down between the cable and the terminal - effectively creating an insulating barrier.
I've cleaned up several of these well-intentioned mistakes that were discovered when a car would not start.
There is a battery terminal spray coating specifically formulated for the job, and available for a couple of bucks at the auto parts retail stores like Pep Boys, Auto Zone, etc....That is the correct product to use.
on Sep 21, 2011 | Chevrolet Silverado Cars & Trucks
2002 Intrepid 3.5. How do I replace the alternator?
Watch this video for an idea. It is not a hard job but there are a few things that must be done (i.e. loosening/retightening the belt and making the electrical connections). By the way, ALWAYS disconnect the negative terminal on the battery before this repair.
3.5L Engine
See Figure 10
Disconnect the negative battery cable.
Loosen the lower mounting bolt but do not remove it.
Loosen the pivot bolt, but do not remove it.
Fig. Fig. 10: Alternator mounting-3.5L engine
Loosen the belt adjusting bolt.
Remove the alternator drive belt.
Remove the bracket.
Remove the lower mounting bolt and pivot bolt.
Remove the alternator.
Disconnect the alternator field circuit plug.
Remove the B+ terminal nut and wire.
To install:
Attach the alternator and bracket to the engine, then tighten the mounting bolts to 40 ft. lbs. (54 Nm).
Install the drive belt onto the alternator pulley. Make certain that the belt is seated correctly on the pulley.
Install and tighten the B+ terminal nut and wire to 75 inch lbs. (9 Nm) onto the new alternator.
Connect the alternator field circuit plug.
Jun 11, 2015 | Dodge Cars & Trucks
Error code po171
I had P0107 on my 07 Passat. The problem was resolved after getting the PCV Valve replaced.
Contact the nearest VW dealership to see if there is any recall.
Aug 12, 2014 | Volkswagen Passat Cars & Trucks
How to connect incoming power cable live and neutral to AEG FAVORIT 60860 dishwasher?
I think it is best to connect power cable directly to the interference filter where is normally connected.
The interference filter is connected in the terminal board parallel to the mains feed. See below pictures:
Dado
Apr 07, 2014 | AEG Dishwashers
I wish to terminate my yahoo account
To Terminate Yahoo Mail account. You need to follow the steps:
Go to the "Yahoo Sign in mail".
Click To "Account privacy"
Visit the "terminating Your Yahoo! Account" page.
Fill in the credential that is required and after that,
Tap to Terminate this account
Go through the terms and condition properly.
Once you terminate the account the user need not enter to the account within these 90days to completely deactivate the account. For more information visit the site- https://gonetech.net/yahoo-helpdesk/delete-deactivate-yahoo-account
Jul 26, 2011 | Yahoo Mail
HDTV and cable box; no volume on channels higher than 99
Can you tell me, is the set top box connected directly to the tv? (i.e. not to a surround sound receiver or anything)
Mar 13, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Oct 18, 2007 | Aiwa AV-D57 Receiver
Sound problem
I'm fairly certain this is a cable signal issue... I have had my digital audio cut in and out and the cable company traced it to a weak signal and replaced the cabling. No issues since. Just an FYI, my setup is a Sony 6.1 with an Optical cable. There is a Blue Light indicator for Surround and when I had the problem, the receiver's light would go off and the display "blinked."
Dec 17, 2006 | Aiwa AV-D57 Receiver
Televison & Video Logo
588 people viewed this question
Top Televison & Video Experts
