Question about Mountain Shimano Altus Front Bike Derailleur Bicycle Part 78
I bought a mountain bike with Shimano Altus gears over the net with most of the assembly in place. Have indexed the rear gears which work fine. Did the same for the front deraileur works changing up but misses the second gear when changing down. Any ideas.
    Problem Solver:
  • 10 Answers
There are a couple of possible problems. You can try backing off the cable tension a little bit at the shifter and running back and forth through the gears adjusting as you go till it hits 2nd coming down.You can also try backing off the High limit screw on the derailleur. This will allow the shift to start a little farther from the bike hopefully hit 2nd. Hope this helps.
Posted on Sep 14, 2010
How to assemble a rear shimano altus c20 shifter?
contact local bike shop for assistance
Aug 12, 2014 | Cycling
I have a TREK mountain bike with a Shimano combination brake and shifter with an Altus derailleur. It shifts all gears fine but when coasting with my feet on the pedals, the chain goes slack and sags...
Only YOU can evaluate any error you may have made. LOOK at why the chain is slack. Does the rear derailleur pull back to take up the slack? Are you using some ridiculous small chainring, small rear cog combination that allows too much chain to go slack?
Perhaps the freewheel isn't freewheeling and is instead feeding chain forward when you stop pedaling. Walk the bike forward and see if the rear cogs just coast. If not, lube time (internal). take it to a Bike Shop or buy all the special tools and DIY.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://www.parktool.com/blog/repair-help/categories/cassette-and-freewheel-service
Mar 22, 2011 | Cycling
Good evening - I have Shimano Alivio Gears on my Cannondale F6 MTB and the gears are trying to change down a gear on the rear cogs (go to the larger cog) and need adjusting - which screw is the one to...
Neither screw is for mis-shifts. Those are limit screws for the largest and smallest cogs. Tweaking the cable tension will usually bring in the indexing...
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
It sounds like your cable is/was a smidge too tight.
Aug 14, 2010 | Mountain Shimano Alivio Front Bike...
I don't know how to change gears on a diamond back 26" woman s bike
I think Diamondback gears are Shimano and should carry the Shimano part numbers or groupset description such as Altus. Given that info you should be able to find exploded parts diagrams and service info on http://techdocs.shimano.com/techdocs/index.jsp
Nov 15, 2009 | Diamondback Cycling
Mountain bike advise
sounds like a pretty good bike for what you will be using it for
Oct 22, 2009 | Cycling
Where can I find a drawing of a 21 speed 26" mongoose duel supp rear deralier so I can see how the cable runs?
http://www.amazon.com/gp/product/images/B000B8IDS2/ref=dp_image_text_0?ie=UTF8&n=3375251&s=sporting-goods If it has a Shimano Altus rear derailleur, you can look here:http://bicycletutor.com/adjust-rear-derailleur/comment-page-3/ or here:http://www.parktool.com/repair/readhowto.asp?id=76
Oct 16, 2009 | Mongoose Sector 26 Men's Full Suspension...
Shimano Altus gears
The old lubricant has gummed up. It needs a good cleaning and relubrication.
"STI shifters gum up after years of use. I've had good luck with this method and since it's nearly free it's probably worth a shot--
"Get a can of WD-40 or a similar light solvent/oil solution. Pull the brake lever back to the bar to partially expose the shifting mechanism and generously hose down the interior with your solvent. I mean really get it in there from all directions, using the little red spray tube if possible. Let it sit for a while and then drizzle in some light oil like Tri-Flo or similar. Then wipe down the exterior of the shifter with some Simple Green or other degreaser (to keep the overspray off your hands).
"I've rescued two sets of STI-type shifters with this method. Hope you get your problem solved one way or another, because new Dura-Ace sure ain't cheap."
source: http://www.bikeforums.net/archive/index.php/t-83743.html
Jun 25, 2009 | Mountain Shimano Altus Front Bike...
Mountain Shimano Altus Front Bike Derailleur Bicycle Part 78 Logo
493 people viewed this question
Top Mountain Cycling Experts
John Egan
John Egan
Lawrence Oravetz
Are you a Mountain Cycling Expert? Answer questions, earn points and help others
