Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
Will not copy says "clear paper jam"! I have cleared all paper
  • 1,218 Answers
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Oct 12, 2010
Where is the duplexer of the HP 4500 Officejet printer?
its located on the backside of the printer behind an access door. You can find a very good video from HP on clearing paper jams at YouTube. Here's the link:
https://youtu.be/lS1441RmrKY
Fixing Paper Jam HP Officejet 4500 Wireless All in One G510n
Jul 08, 2015 | HP Officejet 4500 Wireless All-in-One...
How can solve error H5 in sharp 5516s?
H5-01 means repeated paper jams on the Sharp photocopiers.
Once the paper jam is cleared properly, you need to clear the error condition.
Put it in 'Copy' mode
Press on the keypad:
P * C * 14
Click execute and press 'Yes'
Then press the 'Copy' tab.
This will reset the menu and jam condition.
Oct 04, 2014 | Office Equipment & Supplies
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
I recently cleared out a paper jam from my printer / scanner / copier. Although I can scan and copy just fine, when I try to print something, I get an erroe message on my screen that says "Paper...
Hi. The error message shown as paper jam cleared a) not fully b) not carefully and there is any paper fragment or a whole page remained yet. The sensors are perceive the paper in the paper way, so there are any dirty thing or paper fragment. Read again the user manual, section of paper jam carefully and try to clear out again.
Sly
Nov 22, 2010 | HP Office Equipment & Supplies
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
Jamms paper when copying
hi,make it clear where is the location paper jam?how to know follow this steps:-
1.make one copy & where the paper is stoped?
2.clean the area or clear misfed sheets.
May 14, 2009 | Canon Office Equipment & Supplies
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Canon ImageClass MP730 - Clear paper jam
Were you doing duplex? take out the duplex and look in side and UNDER it
Nov 18, 2007 | Office Equipment & Supplies
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
132 people viewed this question
Seeker5211
Seeker5211
