Question about Hitachi 53SWX10B 53" Rear Projection Television
Blue Projection Gun
Hello, I was wondering if you know how much it would cost to get the blue projection gun aligned, its off by about 3-4 inches? The red projection gun is aligned perfectly, as well as the other projection gun. It's just the blue gun thats out of alignment and distorting my picture. If you have any relevant info, please render.
    Problem Solver:
  • 12 Answers
It is not the gun ,but the convergence IC that needs replaced providing that you have went into the tv menu and selected convergence and manually adjusted the blue convergence.
Sincerely the Hammerman
Posted on May 14, 2008
The screen is green and the tint option in the menu cannot be adjusted.
This symptom usually indicates CRT failure. Projection TV's, especially older types use 3 CRT "guns" to project the image on the screen. One is Cyan or Red, one is Green and one is Blue. If the Red and Blue become weak or do not project, the Green gun overpowers the output of the other two. These three "guns" are aligned exactly on top of each other so when all three are correctly functioning, the correct colors are projected on the screen.
Oct 04, 2015 | Televison & Video
Pioneer SD-533HD5 with No Yellow
Your Yellow Gun is out of order. You should contact Service Station to get it replaced.
Aug 13, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
I have a samsung 47 inch rear projection w/self focus there is a continuos blue shadow around images is there a quick fix
The blue is caused by the RGB gun alignment. Green is a fixed gun and Red and Blue are adjustable. In my Mitsubishi, the guns are motorized and can initially be adjusted (course) with the remote. There are more detailed adjustments that can be made if you purchase the service manual. I paid approx $19.00 on line 3 years ago and it is a complete manual. Unfortunetly I don't remember the site. To do a complete alignment, there are steps to take: starting with entering a code using the remote to enter the setup. To make a long story short, I had my tv aligned 3 or 4 times over 5 years under the extended warranty. After watching the tech, who was good, but under time constraints, it was clear that most anyone could do it if they could read and follow instructions.
Mar 05, 2010 | Samsung Televison & Video
Blue gun jumped to right, and convergence adjustment ineffective
Your blue convergence amplifier is out and needs to be replaced.
Jul 05, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Blue gun lites but no picture from it
you should be able to go to any used appliance shop and get what you need. most of them carry on hand parts or can order whar you need
Dec 25, 2008 | Sony KP-51WS500 51" Rear Projection...
Philip RPTV
There are a few malfunctions that can cause such.
ONE: Mirrors out of location. But it usually throws the picture off center, also. This can be caused if the set is dropped or kicked badly.
TWO: Out of focus. Can be caused by drift of the circuits or from a malfunction of the video drivers. You can check this by going to the crosshairs and see if the lines are sharp and narrow. If not, then the focus is off badly - most likely the blue gun. You may be able to set the focus and other levels for brightness and contrast and color to optimize this weakness as these are all somewhat interrelated, especially in the extreme settings. You can make adjustments for these above what is available from the OSD by getting into the service mode. See this web site for instructions on how to enter it. http://www.fixyourowntv.com/servicemenu.php
THREE: Worst case is the blue gun or projection tube is failing and needs replaced - which I don't recommend due to the very high cost of doing so.
FOUR: And it is possible the blue gun/tube has been knocked out of alignment by dropping or moving the set.
I favor the focus adjustment as the first remedy to try. You can do that yourself. But if it turns out the mirror is out of location or the blue gun is defective you will need a technician for help on those items.
Nov 13, 2008 | Televison & Video
Guns on their last leg- color fading
If you are asking about Guns in rear projection tv then answer is No.
Rear projection TV has 3 Guns (CRTs), red-green and blue and each gun has its unique color phosphorus coating to produce its mono color (red /green /blue) and these are not interchangeable.
Need further info, let me know.
Oct 23, 2008 | Televison & Video
No image in blue gun assembly
the fluid in the bule gun is cloudy therefor the image you need to replace the fluid (coolant) inside the gun. the fluid is toxic (eytholene glycol). so have a tech do this for you. the repair may cost $ 325.00 or so.
Feb 22, 2008 | Akai PT5598HD 55" Rear Projection...
Blue color gun off line
Milt,
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Bill
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Hitachi 53SWX10B 53" Rear Projection Television Logo
190 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
