Question about Samsung HP-S5053 Television
Model Samsung HP-S5350 5)" plasma TV, 2 years old with minimal use, was turned off a night before with everything work in excelent condition, turned on the following day there was sound no video at all completely blank screen I tried to change the input no luck, I pressed the menu button also no menu display on the screen, not sure what is the problem? any input would be appreciated. Thanks, Mike
5 Suggested Answers
redgs95
  • 15 Answers
SOURCE: 50 inch Plasma Samsung HP-T5054 appears to have power however...
check the power inverter on the power strip. also check the caps on the board and if any of those caps have a round top it is bad and needs to be replaced. i hope this helps.
Posted on Jul 28, 2009
dsacco86
  • 1077 Answers
SOURCE: sound no picture
Most likely the TV has a power supply related problem. The most common problem are the power supply for the screen itself. Most manufactures call it a Backlight Inverter Board. Something you may want to look at for your problem. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Posted on Sep 18, 2009
  • 146 Answers
SOURCE: I have a Samsung 50" plasma HDTV, about 6 years
either backlight (flourescent bulb inside) or power supply for backlight went bad - if you have voltage meter you can check if there is voltage where bulb goes and if there is replace bulb or if no power you will need to trouble shoot power supply which is common thing to go bad on these sets.
it is usually not worth paying to get this fixed if it is power supply and you might be better off just getting new set - sorry i know that is not what you were hoping to hear but....
good luck!!
Posted on Mar 27, 2011
  • 1212 Answers
SOURCE: I have the samsung LN52A550. When I turn the tv on a blue screen appears. I tried changing the source with the menu button but does not display anything. The TV is about 2 years old. The sound works.
Try this
Method one- with set on, hold down the exit button on the remote for 10 seconds. It will bring up the warning it will reset to the defaults it had when removed from the box and powered up initially. in the warning box it will show the cancel button highlighted initially. press the left arrow to select the reset option. You may end up doing this blind, so you may need to try it a couple times and the only indication of where you are is just a slight flash from part of the screen.
Once that left arrow has been pressed once, the reset option choice changes to "Ok" or "reset", press "enter" The set should
do it's thing to reset and then shutdown.,
Method 2
it should get you into the hotel settings, but you can reset to factory defaults from there, changing any other settings may limit access to the normal settings.
Shut the set off.
The while holding the mute, menu and info buttons, trun the set on while holding them down. If the functions portion of the board is working, it should bring up hotel options menu.
Posted on Feb 07, 2012
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
Plasma TV-power light does not come on
have you tried a completely different wall socket altogther/
Mar 03, 2008 | Samsung HP-S5053 Television
2 year old plasma on 5 minutes no pic, but sound
yes take it to a tv tech would be your best bet.
regards
shaun
Apr 20, 2014 | Samsung PN Televison & Video
I have a 4 year old Samsung Plasma. While watching tv, the tv will turn off and then keep trying to turn back on, but is never able to turn back on. We unplug it, then after 1/2 hour it will work again...
Good day!!!!
You have a better chances if you have failing bad capacitors on the power supply board...
bad capacitors sometimes bulged on top,sometimes not...if the caps is bulged you can easily identify it..
Thanks for using fixya..
Aug 04, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
I have a 50 inch LG plasma tv that is less than 2 years old. It use to turn on by itself throughout the night, and now it's completely not working???
Hi there
Try doing a system reset on the TV, by unplugging everything from it, then wait 3 minutes and plug the power lead in only. If it works, then plug everything back in one by one. If the problem persists it may be that the software has been corrupted in an update process, which can be performed at night via the aerial signal (this may be why it was turning on at night). In which case contact the TV manufacturer.
Hope this helps
TV_Doctor
Jan 03, 2011 | LG 50PX4D 50 in. Plasma Television
We recently experienced a power outage and our Plasma TV did not come back on afterwards. I have read about similar problems but we do not have a red led. I have removed the back panel and have checked...
The problem with these sets is you have to gamble.
If power outage, it is most likely on the power supply board-------only way to confirm this is test voltages to see if are there or not, do you follow me?
Fuses can look good but also need to be "tested".
Let me know if I can help, I am here to help.
SD TECH
Nov 06, 2010 | Sylvania 6842THG 42 in. Plasma HDTV
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
Plasma-No picture
Main logic board $124 fixed mine email me rudog3369@yahoo.com!!!
Apr 26, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
111 people viewed this question
Jerry Greenberg
Jerry Greenberg
