Question about Dishwashers
Kenmore quyite guard ulta clean mod 665.1382 k605, wont start, lights blinking, wont cancel
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
  • 4 Answers
SOURCE: quiet guard 3 dishwaher
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
  • 9 Answers
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
SOURCE: Kenmore Ultrawash Quiet Guard 4 dishwasher - clean light blinking
I have the same problem. I called the repair guy and he told me how to do a diagnostic check on it to clear the problem out and let it run a cycle to see if it fixes itself. That cleared my problem with the light but unfortunately didn't fix my problem. Press the heated dry button, then press the normal wash button. Press the heated dry button again and press the normal wash button again. Then let it do its thing. If all the lights go out and it does not run a complete cycle, then press normal wash and start to see if it will run the cycle. To speed up the test cycle, he said you can press Start several times slowly to get it to go to the next cycle one at a time. You will see the red lights change from sensing to washing to drying and so on until it goes to clean. Then try to wash some dishes and see if it works. If that didn't solve the problem, he said it could be that there is food or other items stuck in the bottom and needs to be cleaned out. Just remove the spray arm on the back and top of the dishwasher by the 2 screws and take it out of the dishwasher. Then remove the screws at the bottom and take the screen out to get to the tray at the bottom to see if there is food stuck in there. Pay attention to how you took it apart though, so you can put it back properly. Also check the spray arm and run water through it to remove anything that might be stuck in it. If that doesn't solve it, he said it could be the heater or your motor or possibly wires burned out. I am looking at trying to remove my motor now to see if I can replace it and check that before I pay any money unnecessarily. My repair guy is so busy that he tries to help me over the phone before he comes out. Great Guy. He said that if it is the motor, the charge to replace it is not worth fixing, but if the repair is only 100 to 200, that is definitely cheaper than the cost a the same kind of dishwasher I am planning on purchasing to replace it. They say that because the do not want to work on it. A lot of times they do charge more than it's worth though, so you have to get an estimate concerning your worst possible problem before hand so you can make up your own mind. Hope this helped you. Now I will see if anyone can help me figure out how to remove the motor from my Kenmore Quietguard 4 Dishwasher. Have a great day.
Posted on Sep 28, 2009
Normal wash light blinking, d/w wont start
Wish I could solve this, as I'm having the same problem too. Normal light blinks not matter which wash button is pressed. Cancel light will light, but still NOTHING happens. Same model as yours.
Jul 23, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
Green light on kenmore dishwasher is flashing
I actually had to change the steps a little and this is what I did:
press heated dry
press normal wash
wait a few seconds
hit cancel again
Started a cycle and began washing.....Thx
Dec 31, 2008 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore Dishwasher - Flashing Lights - wont start
Is the clean light blinking 7 times? If so this means you have a problem with your heating element
Dec 03, 2008 | Kenmore 15899 Built-in Dishwasher
My kenmore dishwasher had green clean blinking light
push cancel or start resume the green clean light will blink after every wash cycle to tell you the dishes are clean on some you just open the door to clear it on some you push stop or cancel
Feb 13, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Clean light keeps blinking and I can't start a new cycle
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
Owen Barnes
