CF Card Capacity
What is the maximum CF card capacity for this device?
What is the capacity of Apple iPod Video 30 GB Black
Posted on Aug 01, 2008
Binatone Homesurf 744 - put in micro SD card but nothing will save to it although it says it is there (can unmount it).
Please make sure the capacity of your microSD card is not larger than the maximum card capacity allowed by your device. For example, if the maximum card capacity allowed by your device is 16 GB and your card capacity is 32 GB, your device may not recognize it. And is the "unmount SD card" option grayed out or solid ?
Hope this helps.
Dec 16, 2014 | Cell Phones
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
4 gb compact flash card- e10 shows card error
Your camera was designed and built long before CF cards of that capacity had even been envisaged. Your cameras internal hardware was therefore never designed to handle CF cards of a capacity greater than 1GB and could never have been tested (before going into production) on anything higher than the largest capacity then available of 512MB, which still enables your 4MP camera to store hundreds of images even at the highest quality setting.
In practice, your camera *might* work with a maximum capacity of 1GB, although in practice the E-10 had problems handling the 1GB MicroDrives (an obsolete type of CF card containing a miniature hard drive). Take a gamble on a regular 1GB CF card, or play safe and stick to 512MB cards. At least with the latter there are millions of them lying unused and worthless these days and you can usually get them for zilch by asking on your local FreeCycle/Freegle groups.
You have a great camera which is still capable of producing excellent images, but as it's now a twelve year old design you have to accept that the hardware has some limitations.
Sep 15, 2011 | Olympus Camedia E-10 Digital Camera
I own a Canon Powershot pro 90 IS with 16 MB CF memory card. I want to upgrade the card. Can you tell me whats the maximum capacity the Camera can take.
The camera can take whichever capacity card your want. Type 1 and 2 CF cards up to and past 16GB are available. It is really what you can afford and how many frames you want to put on a single card before downloading it.
Aug 30, 2010 | Cameras
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
My computer wont read my sdhc card
If you know that your CF card is working (e.g. as in your camera) then the most likely cause is your computer Flash/CF reader either inbuilt or external): older readers (and cameras/phones) will not support High Capacity (xxHC) card and will be limited to a maximum of 2GB. Hope it helps.
Jul 13, 2010 | SanDisk ULTRA II 4GB Compact Flash Card...
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
Can this Olympus C5050Z works with Sandisk CF Ultra 4GB 30MB/s? I tried to insert it, and always gets card error message, although I can use the card in my notebook.
Your camera was designed to be fully CF compliant, but it was designed long before 4GB cards were available so your problem is likely to be that the camera cannot handle a card of that large a capacity.
I've checked the Olympus servicing manual but unfortunately it doesn't state a maximum CF capacity and there have been no relevant firmware updates to extend CF compatibility.
When your camera was released back in 2003 the largest capacity CF card was 1GB so I suggest that you don't go above that size. You'll also be wasting your money on any more than a regular Sandisk Ultra as the camera cannot take advantage of the faster data transfer rates of later cards, I'm not even certain that it can utilise the speed advantage of an Ultra over a really basic model, but it won't cause the camera to throw it's toys out of the pram either.
I hope that you've found my reply to be of use and ask in return only that you return the goodwill and rate my answer.
Nov 23, 2009 | Olympus Camedia C-5050 Zoom Digital Camera
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
SD and CF reader
The PC will see the card as a storage device so should read any capacity Compact Flash, or Secure Digital cards that you put in the readers.
The devices their used in usually have the capacity limitations as to what size cards they will read/write to.
Mar 21, 2008 | Fujitsu Siemens LifeBook P5020 Notebook
 Grubhead
Grubhead
