Question about HP Office Equipment & Supplies
Wireless hp j4680 printer will not print...offline help....
  • 1,218 Answers
If this problem arises check for updated printer drivers, compatibility between your wireless printer and Windows Vista and firewall settings. All or any of this could prevent your HP wireless printer from printing documents. Setting up wireless printers is very easy; however, sometimes certain settings can create hassles for you. get more help......... http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Wireless-not-working/m-p/319330#M19085
Posted on Sep 15, 2010
I have a macbook pro and an HP officejet J4680 All in one. Struggled all weekend to get it on line as it just says Offline and won't print. First tried wireless and then plugged it into my Mac. Still no...
If everything is ok and printer is not printing it needs to be checked manually now. you need to check printer settings to make it online. Hope it will start working.
If you wish you can contact me at +1631-855-3940
or through IMO app +918510879267
Feb 17, 2018 | HP J4680 Office Jet All-In-One Printer
HOW TO GET MY PRINTER FROM OFFLINE AND TO PRINT. we HAVE A HOME COMPUTER WHICH THE PRINTER IS SETUP TO BUT WE ALSO HAVE IT WIRELESS FOR OUR LAPTOPS. NOW ITS NOT PRINTING FROM HOME COMPUTER ITS SAYING ITS...
Make sure that the usb cable is well connected from the computer to the printer .... try switching usb ports on the pc....
if it still stay offline... you will have to delete it and make a new installation of the printer driver....
But i'm pretty much sure that the usb cable is losse or something
Jan 24, 2010 | HP J4680 Office Jet All-In-One Printer
I can not get my HP Officejet J4680 Inkjet Printer to work on wireless. Can only use with USB cable. I no longer have my Setup CD. Any suggestions?
First check that your antivirus and firewall software are not blocking the print jobs. Do this by turning off the services for a few minutes. If you can print, check for a setup option of trusted machines. If that doesn't help, make sure you have a strong wireless signal between the computer and the printer with no interference from other appliances (cordless phones, microwaves, etc). Also check your settings to make sure the printer and computer are set for the same wireless network profile and security settings.
For additional information, try the user's manual: http://h10032.www1.hp.com/ctg/Manual/c01770356.pdf
I hope this helps.
(I have generally preferred printing with a wired connection (USB) over using a wireless networks. I've always spent more time on printer problems that were directly linked to the network signal loss problems rather than printer issues.)
Dec 05, 2009 | HP Officejet J4680 InkJet Printer
HP J4680 Will not see the router or wireless internet. When I do a network configuration print there is no IP address. Please help!
  • Option 1
  • any wireless product must be hardwired to the router prior to running wirelessly.
  • otherwise use a memory stick and your OS disk to transfer setting to allow for your configuration
  • Option 2
  • reconfigure the network.
  • start with the disk to the router
  • router software will lead you to build a network
Sep 13, 2009 | HP J4680 Office Jet All-In-One Printer
Officejet J4680 won't printer after router reset
) You might not have to do this step, but if all else fails reset the HP Officejet J4680 network by pressing the setup button (the wrench) go to Wireless Menu and Press OK then go to Reset Wireless select YES and press OK. If that doesn't work then there is another reset that I found in the setup menu (the wrench) under Tools and then Restore Defaults. I wound up doing both resets on my Officejet J4680
2) Power the HP Officejet off and on for good luck (again optional but might help).
3) Make sure the the wireless on the printer is enabled by pushing the button on the left side front under the 802.11g so that the blue wireless light turns on. (again optional, but make sure the blue antennae light is on)
4) Connect to the HP Officejet J4680 wireless printer directly from the MAC (this is pretty cool stuff) Click on the Airport icon at the top bar of your mac screen, if you see the hpsetup listed then click on it, if it is not listed then click on join other network and type in hpsetup and click Join. This will join the mac to the Ad Hoc HPSetup network and you can now setup the printer from the mac!
5) Important: Print a network settings report on the HP Officejet by pressing the setup button again (the wrench) go to Print Report and press OK, go to Network config and press OK. If you try and print this before you connect (step 4) you will not get the info you need in the report, so connect first from Mac to HP then print this report.
6) fire up safari or Firefox or chrome browser on the Mac and type in the URL that is listed on the report you just printed out. It starts with http:// type in the http:// and the 4 numbers all together with no spaces into the address bar in your browser and press return.
7) you are now connected to the HP Officejet J4680 via the web browser interface. Click on Networking, then Advanced, click the infrastructure tab and fill in the passphrase info for your router type it again to confirm, then click apply. It should now connect and print from the router. But below is a good video with even more detailed info:
8) More Officejet J4680 setup via the mac using this very thorough guide: http://www.youtube.com/watch?v=Rjd1ZqJ89N4
Jul 15, 2009 | HP J4680 Office Jet All-In-One Printer
I Have an H.P. Office Jet J4680 and it prints only one copy.
uninstall the wireless drivers from your computer and reconfigure the settings.....these issues are generally related to the printer drivers.....
Jun 24, 2009 | HP J4680 Office Jet All-In-One Printer
I have just got a new HP wireless printer, i have vista on my laptop and even though it said installation was complete it says error when i try and print and says printer offline. its a hp j4680
I had a similar problem,and after spending several hours on the phone with an HP tech yesterday, reinstalling the drivers over and over, we ended up manually creating a port with the printers IP address. Under "printers," right click on the 4680. Go to "properties," the "ports." We added a port, and named it the IP address. Then I could print. I STILL CANNOT SCAN, however!
I also have Vista.
Mar 20, 2009 | HP J4680 Office Jet All-In-One Printer
287 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
