Sharp lc26sh20u 26"flat panel has vertical lines on left side,What coulb be problem?
Yes this tv has vertical lines on left hand side of inside screen,what board is faulty?help me,help me,please. my Sharp LC-26SH10U lcd tv has a 2 inch black vertical bar on the left side of screen. Would the LCD control pcb cause this?
  • 1 more comment
  • Ted Leber May 19, 2008
    I've been an A/V service tech for fourty-five years. Worked on the USAF's first digital satellite secure comjunications equipment back in the '60s. I'm just new to LCD technology. Can you suggest any good general purpose tech manuals for LCD tech? Thanks And BE Blessed!!! IHS Ted Leber
  • Anonymous Mar 12, 2014
    Sharp LC52E77UN left side of screen black
    left one third screen black on a sharp tv model LC52E77UN
    President:
  • 2,712 Answers
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
Posted on May 14, 2008
  • 2,296 Answers
The vertical line could be cause by the screen driver board, it could also have a loose or oxidaze contact where the main board connects to the screen driver/buffer board.
How old is your LCD?
  • 3,037 Answers
This line would either indicate a horizontal problem cropping up or a power supply problem
I would suggest getting a service tech to look at it to determine where your problem is coming from but most likely it will be the power supply /deflection board that is the problem but I can't know for sure, it will have to be checked.
A lot of sets have had damages after a long hot summer a/c flipping off and on and current demand being peeked from the utilities storms or quick power loss off and on can cause problems like this to occur
Please let me know if you have any other questions, thanks
  • Benjamin Patri
    Benjamin Patri May 19, 2008
    What is the current situation with this problem?
    If you were able to fix it, then please give me some feedback by rating my solution, otherwise I would be happy to answer any further questions that you may have.
    Have a Great Day!
  • Benjamin Patri
    you can buy the specific manual at this link
    http://www.manualsparadise.com/ReWrite-S...
    or you can use www.eserviceinfo.com to get a variety of manuals for free but I don't think you can get the specific service manual for free.
    Let me know if you need anything else or if one of the links doesn't work for you, thanks
Vertical blue stripe on my Sony KDL-40S4100
Was the telvision impacted? Usually a Blue line on various tv sets such as Sharp and Sony can also indicate a firmware upgrade being needed. Try that first, as to a panel if this is a panel we have in stock cost could be between $200-400 for the part that part cost from Sony coulb be double if you need to purchase new. Call or reference us if you need TV repair in Colorado 6_2_2012_7_06_05_pm.jpg
Jun 02, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a sharp 26" tv that displays a please wait. do you know whats wrong?
Part called DIGITAL UNIT has failed and require replacement, You probably talking about LC26SH20U or LC26D40U?
Oct 31, 2009 | Sharp AQUOS LC-45D40U 45 in. LCD...
Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
Oct 14, 2009 | Televison & Video
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
One verticle line appeared
Same thing happpened to us with a Vizio 26" TV. Its a defective panel,and cannont be fixed, we were told. Vizio replaced the TV under warranty.
Nov 22, 2008 | Olevia LT27HVX 27 in. LCD Television
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
On al the plasma tvs there are control boards on the lower part of the screen that control the vertical images. If one of the chips on one of the boards fail, have a bad connection, or no ground it will result in a thick black lne down the screen. Seeing as the tv is new I would get the warrantee repair on it. There is a possibility that there is a problem with the screen itself but more than likely its the boards.
Aug 09, 2008 | RCA L26WD26D 26 in. LCD TV
Vertical line
Sorry, you have a defective LCD panel. If your TV is still under warranty, contact Sharp to get the TV exchanged. Otherwise, LCD panels cost more than the TV is worth.
Mar 25, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
252 people viewed this question
Top Televison & Video Experts
Electro Med Services...
