Question about Sony Xplod XS-V1340H Car Speaker
Hi, I had no problem with my speekers since recently. The skeepers (it seem to be the left one) is making a terrible ugly noise (seems to be associated with the bass line). An more, the left speeker is playing intermittantly. To avoid this problem, I have to cut almost all the bass and reduice the volume. My amp is a Pioneer 4x50w. So is the the amp the problem or my speeker is blow up?
  • 3 more comments
  • rickbougie Sep 13, 2010
    Ok, but how do I locate the amplifier fuse? and how do I change it?
    1. Ok, but how do I locate the amplifier fuse? and how do I change it?
    A little bis discourage... Was not able to take out the radio from the car. I have to buy kind of hooks to took of the radio without braking everything.
    When the radio would be out, I'll try to locate the fuse and fix the problem.
    At that point, I may reply you.
  • rickbougie Sep 24, 2010
    Hi, I took of the amp, change the fuse and get everything in place. Appears to be fixed, but the noise came over. The noise is synchronized with the bass. So, instead of a clean based it sound like ****. It appears on the left side only (the front and rear speaker).
  • rickbougie Sep 27, 2010
    Ok, I think it could be bad connection too. Yesterday, only 1 speeker or 2 were playing, instead of four! It's no the speekers... I think it could be the connextion to the amp. I'll do some test and keep you posted.
    Thanks!
    President:
  • 2,047 Answers
Speakers seldom have problems especially pioneer speakers. When ugly noises emanate from your speakers they are usually caused by 2 things. The first being bad connections. Check the wiring which run to the speakers for inconsistencies or breakages this could create partial contact and cause such noises.
On the other hand if the speakers have torn then they will need replacement but this is very unlikely.
Hope this solution has been helpful?
Posted on Sep 24, 2010
  • Rockme
    Rockme Sep 27, 2010
    Hope the testing is in order. If some of the speakers stop working for a bit then it is the wires definitely.
  • 944 Answers
This problem is not associated with the speaker.The amplifier fuse is blown out.When it is blown out you get this type drdrdrdrdr type of noise along with the sound.You have to solder the fuse if its loose or blown up.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 12, 2010
  • 2 more comments
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 13, 2010
    Open the Pioneer amplifier in that you could see the fuse has shown in below diagram it will be based on the model
    There will be many capacitors and transistors to.Use multimeter to check the volts and do continuity testing on the board to find out the exact cause.Some times burned transistors and capacitors could also be reason.Do continuity testing to find out.
    have a nice day:-)
    You have to solder at from the backside to remove it.Solder again it place when you place new one.
    Natarajan Ramasamy Sep 14, 2010
    hmmm yes you can i will be always available
  • rickbougie Sep 19, 2010
Nad c355bee
Check to see if it works with headphones. If it doesn't then you might have a main power amp failure.
Aug 06, 2013 | Audio Players & Recorders
I have bad road noise after 40 mph. This started after changed tires and both front boots and axles
to possible answers
the axles are new and the cv joints mat be firm resulting in noise transmission through failing engine mounts ( unlikely but possible )
the tread pattern may be the cause of the noise especially if the tyre pressure is incorrect
Take it back to the shop and take them for a road test to see if they can find the reason
when drive axles have to replaced , it generally means that the front lower arms have to be disconnected so a wheel alignment may also be in order
May 04, 2017 | 2006 Subaru Outback
Making a terrible noise
its cloged or the pad behind it is burned up
Jan 25, 2012 | LG DLEX7177 Dryer
Our volvo 850 makes an terrible loud grinding noise coming from front passenger side. Cannot pinpoint when the noise is made as it seems to happen at any time but is more persistent after turning full lock...
Hi! The problem will be the constant velocity joint on the driver's side. When its worn it makes a noise on turns specially when putting it back to straight direction. Have it replaced and you'll be good. HOpe this helps and have a good one!
May 20, 2010 | 1995 Volvo 960
Engine 'chuggs' terribly on idle.
Could be a bad injector, miss fire. At this point it's best left to a repair shop.
Jan 03, 2018 | 2007 Toyota Yaris
Sliding noise in trunk
These cars have struts inside the springs. When the struts fail they start to make a noise that sounds like your problem. Also the strut mounts will make a terrible racket. Have these checked and replaced if needed. Hope this helps. Good luck.
Jun 03, 2009 | 1999 Saturn SL
Screen froze-terrible noise-refused to power down
it is possible that the video card became unstable. It is possible that the card may be on it's way out; keep an eye out for those lines in the future, if they shoe up again plan on replacing your video card
Apr 15, 2009 | Computers & Internet
Trany seems to not ingauge makes noise terrible noise when P
Check fluid level in transmission. It could be a faulty pump or a faulty governor all inside the transmission, it could possible be a plugged filter
Mar 17, 2009 | 1999 Mercury Cougar
Sony Xplod XS-V1340H Car Speaker Logo
49 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
