Question about Car Audio & Video
I have a 1995 ford mustang 3.6L and the stailess steel line that comes off the exast manifold broke i dont know what that line is called to get a nother one..
  • 62 Answers
Its an emission vent that goes to the air pump. its just 1/4 inch tubing usually can usually buy an oem part at napa or they can make one.or the cheap way get a flanging tool and rebuild it
Posted on Sep 13, 2010
I have a 1995 ford mustang and the odometer and trip dont work what is the plastic gear called that i need to replace
Speedometer gear in the back of the transmission tail piece. remove the cable going to it, then twist and pull out the gear. Good luck finding the gear for the instrument panel if it is broken.
Dec 18, 2014 | 1995 Ford Mustang
My 1995 ford mustang is blowing air out of the defrost vents instead of the ac vents
You need to trace the vacuum lines that run from the air box at the fire wall to see which one is broke. Once you locate that buy a piece of rubber hose that fits tight and slide onto it. Should fix the problem.
Jan 18, 2011 | 1995 Ford Mustang
I have 1995 ford mustang tailights dont work where is fuse
CHeck in the Ford-Mustang-Owners-Manual (page 272 and next).
Hope helps (remember rated and comment this).
Aug 21, 2010 | 1995 Ford Mustang
I was backing out of a parking space when the car kind of fell on the tire. the tire was still attached to the wheel hub. i believe i need to change the ball joint but dont know. i think it also might be...
Unfortunately the balljoint is probably what broke on you happens all too often.If possible jack up that side of the vehicle to get a better look at it.
Aug 19, 2010 | 1995 Ford Mustang
SHOWING CODE P1407 ON 1995 FORD MUSTANG. WHAT CAUSES THAT CODE?3.8 V6
P1407 EGR No Flow Detected
You could have a blocked or dirty EGR valve or tube from the manifold or a non functioning EGR sensor.
May 28, 2010 | 1995 Ford Mustang
I have a 1982 ford mustang i just put a c4 transmission in it and when i drive it down the road it wont shift out of 1st gear and i cant find a vacume line that needs to be hooked up butit has 4 wires that...
there is a vacuum modulator on the back (pass side ) of the trans.it will have a small port in the center,(facing rear of car) hook up manifold vacuum to it and it should work.
Mar 19, 2010 | 1982 Ford Mustang
I have a problem with my 1990 ford mustang the tensioner pully locked up and broke the belt so i got a new one and now my car is idling at 2 1/2 and will not go down i have no clue what it could be vacuum,...
Odds are that the broken belt took out a vaccume line while it was flailing around,that would be the first thing that i would check for.Any hard plastic or rubber lines that are within stiking distance of the broken belt would be suspect.
Feb 02, 2010 | 1990 Ford Mustang
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
