Question about Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
I have a rheem model 81V800 A that isnt heating the amount of water it used to...seems like half..any sujestions?
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
Depending on the age and water hardness in your area, sediment buildup is the most likely cause of this issue. Other problem that you may run into are:
One burnt out heating element.
A bad thermostat.
A broken dip tube.
The heater is running on half power.
To run a maintenance check on your Rheem water heater you will need a voltmeter and a 4-way screwdriver.
Follow the testing procedure in this link.
Posted on Sep 12, 2010
Code 14 comes up on the remote what does that mean
Before calling Rheem or service technician, open following link for troubleshoot resources including error codes, Rheem chat, typical required maintenance manual, and possible product manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Error codes are start point for troubleshoot.
Error 14 is 'overheat wrap fault.'
This can include venting problem, failed heat exchanger, bad safety circuit, gas problem.
Rheem does not have a service manual posted for this specific problem.
Additional information: Tankless water heaters consume large amounts of gas during combustion. The combustion burns away hydrogen and the remaining poisonous byproduct is vented into the atmosphere at each home day and night.
Byproduct includes acidic water vapor that condenses along the vent pipe and drips back down vent.
Each tankless vent pipe has a drain line that directs acidic water into household drain.
If this drain line becomes clogged, or if vent was not installed correctly, then water drips down into heat exchanger and can erode or crack exchanger.
The typical maintenance manual above shows steps that can solve many tankless problems before they happen.
Sep 11, 2011 | Rheem Water Heaters
Rheem 49 gal model 81V400B - hot water lasting only 5-10 minutes then takes an hour to heat back up.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Basic info on Rheem
Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 2nd and 3rd digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects that cause lower amount of hot water.
1) TP valve is running hot water out of tank -or- leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Do I need to use the heat trap nipples on my new Rheem electric hotwater heater, I am pressed for space Thanks
Rheem residential electric water heaters appear on following page:
New water heaters are made with heat trap nipples pre-installed so the product meets industry energy standards.
Sample Rheem manual says: 'All models equipped with heat traps.'
http://globalimageserver.com/fetchDocument.aspx?id=052c9e32-ce37-48d7-8990-9e430f23fef3
Jan 31, 2011 | Rheem 38 GAL ELEC SHORT Water Heater 6YR...
I am only receiving half of the normal amount of hot water.
You have electric water heater.
Electric water heaters are fully repairable by homeowner, excluding hybrid type.
Rheem electric water heaters:
Rheem fury series manuals and models
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Age of Rheem water heater is shown first 4 digits of serial number located on side of tank: for example 0705 means July 2005.
Serial number also shows model number & wattage of elements in case you need to buy new generic 4-bolt type 4500 Watt element from hardware store.
A) If your water heater receives very cold incoming water, it may not heat fast enough to keep tank warm.
Add a tempering tank.
http://waterheatertimer.org/Tempering-tank.html
Add insulation over entire water heater except TP valve. Insulate pipes completely.
Read more information:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
B) 40 or 50 gallon water heater is 240Volts and tank will have 2 access panels on front.
Rheem ships all water heaters with 4500 Watt elements.
Narrow down the suspects:
C) Water heater has some hot water.
This tells us upper element is working.
And that water heater electricity is working.
And that reset button is not tripped.
And that heater is not experiencing run-away overheating event.
That gives us 3 solid suspects.
1) lower element is burned out. Test lower element using inexpensive multi-meter from Home Depot.
This will restore water heater to full 99% efficiency.
2) Upper or lower thermostat is bad. Replace both thermostats for about $25.
If you want to test thermostats and all parts before replacing anything:
3) Burned or shorted wire. Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially lower element. Tighten any loose wires. Replace part that shows signs of burning.
geno_3245_185.jpgRheem 4500 watt element
Dec 14, 2010 | Rheem Water Heaters
Rheem electic water heater model 81v52s. Switch was tripped off. I turned the switch back on. Will the water heat now?
providing ther is no problem with water heater it should.
It it trips again check out thremostats on heater.
May 15, 2010 | Rheem 81VP6S/430126 Water Heater
Not getting the amount of hot water I used to get
Remove power from WH Remove heating element covers and, insullation you will see two screws and, a red button (reset) for each element; push the button for each element to reset them; put everything back repower and, test. If the problem is still there: Remove power, test element screws with a meter set for resistance; if no continuity drain WH and, replace element(s)
Apr 25, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My rheem water heater doesn't seem to be heating the water. I have a Rheem model 81SV40D and the water is not hot and doesn't seem to get hot. I have checked the dials on the water heater and they are set...
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
Jan 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Richman gas lp tankless hot water heater. used for infloor heat and kitchen and bathroom hot water. getting c2 and 11 error code. water temp. setting 120. ran great last year. made no changes. we have very...
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 09, 2009 | Rheem Tankless Hot Water Heater...
Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802 Logo
286 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
