Question about Whirlpool Duet GHW9150P Front Load Washer
Machine goes to one minute and then the red light on cancel starts flashing with the door locked.
  • 1 more comment
  • Boomer9001 Sep 12, 2010
    I do not see a RINSE/HOLD button on my washer. That being said, I have atempted to press and hold each of the buttons w/no success. I was able to manually unlock the door and remove the last load. I also cleaned out the trap, which was pretty ffull. (This has happened before, but on those occasions I always got an error code). It appears to be completely drained, but the last load was very wet when removed. I have unplug the washer probably 10 times. Sometimes when it is plugged back in it returns to where it was when unplugged and plugged back in it simply goes immediately to a red flashing cancel/pause light with a locked door, on others it runs through a cycle (I'm keeping them short) but it is unclear whether it is accepting water. On these occasions it stops at 1 minute with the red flashing cancel/pause button and the door locked.
    I looked at it again and it now has a solid red light on pause/cancel with the door locked and a gree light flashing on the final spin.
    none of the buttons appear to be working. Right now it is stopped on 1 minute with a solid red on the cancel/pause button and a flashing green on the final spin. THe door is locked.
    I have been able to manually open the door and remove the last load of laundry. I cleaned out the trap and it had a lot of stuff in it. THis has happened before, but in the past there was an error code. THe washer is now empty, but the last load was very wet as it clearly did not go through a final spin.
    I have unplugged the macine probably ten times. When it is plugged back in it either starts at the beginning of a cycle and goes through the minutes stopping at 1 minute as indicated above, although it does not appear to be actually going through the washing process (i.e., I don't believe that it is accepting any water), or it just freezes with the door locked.
  • 2,272 Answers
Disconnect the blue harness from the motor control board and start the machine. If the machine acts like it is going to run (but it won't because the plug is disconnected) then the MCU will need to be replaced.But if there is no difference in the problem and the machine reacts in the same way as before and after the MCU connector disconnecting then the problem is related to faulty CCU.CCU is main control board.Check for voltage going to Central Control Unit (CCU) by listen ing for a click in the CCU when unit is plugged in. If no click replace CCU. Other possibilities to be checked are:-- 1. Press PAUSE/CANCEL button on the touch-pad twice. 2. Drain the unit, then check that the Drain hose and Drain Pump Filter is clear of foreign objects. 3. Check/ Replace Touch-pad/LED assembly. 4. Check harness connections. ----------- For getting manual of your washing-machine.Please click on the link directly.On page number 45 there is troubleshooting mentioned go through it.For more help.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Sep 13, 2010
  • 4,323 Answers
Hi
To unlock the door press RINSE HOLD to finish the cycle and unload the washer. If this doesn't unlock then try and unplug the washer and check, try this 2-3 times.
If it still doesn't unlock then press and hold the start button and check whether you are getting any error message. If there is no error message then you would need to replace the door latch or check the wiring to the door latch. To manually unlock the panel--
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼” or until a click is heard.
6. The door may now be opened.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 12, 2010
I have an aeg washer dryer L87695NWD which is stuck on drying. When I turn the button to select a washing program the drying light stays on, and the washing light is still off.. what can I do?
From user manual:
10.4 At the end of the drying programme
1. The appliance stops automatically.
2. The acoustic signals operate (if they are active).
3. In the display (number "0") comes on.
4. The indicator of button Start/Pause goes off.
5. The last minutes of the drying cycle the appliance performs the
anticrease phase. The anti-crease symbol ietounus3lrwasi2ko2vq2k81km1my9gxk62inwk5r2qaaaabjru5erkjggga=flashes. The
door is still locked (the key ezfxrjud2vanwq0oeawt0sih4u7drnvleuvj3nru5hkbv+p2lq2ra1xbwbjeddwhka3byaaaaasuvork5cyiiasymbol is on).
6. Press button On/Off for some seconds to deactivate the
appliance. After some minutes from the end of the programme,
the energy saving function automatically deactivates the
appliance.
7. When the door locked light goes off you can open the door.
8. Remove the laundry from the appliance. Make sure that the drum
is empty.
9. Keep the door ajar, to prevent mildew and odours.
10. Close the water tap.
If this doesn't help than check:
- If the delay start is set, cancel the setting or wait for the end of
countdown.
- Deactivate the Child Lock function if it is on
If anything of this doesn't help then pay attention to all the symbols appears on the display and check what it means in the user manual.
Dado
Apr 01, 2017 | AEG Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
I have a wtw5600xw0 Whirlpool washer. When I press the start button the sensing light and lid lock lights turn on. Then after a few seconds the lid lock light goes off and the sensing light stays...
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Source
Nov 27, 2012 | Whirlpool WTW5600X Washer
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Ultrawash dishwasher Model 665 15810000. Originally "water heating" light was flashing and no water in dishwasher. Replaced water inlet valve. Turned power back on, normal wash light goes on...
lock light is locking the panel push this child lock button for 3 sec and see if it un locks . then try it again .. may have a pannel out. mm
Dec 06, 2009 | Washing Machines
Dishwasher won't start. Clean light keeps flashing. I have tried cancelling a couple of times, and it goes through a 2 minute process and goes right back to the flashing clean light and not allowing it to...
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 20, 2009 | Dishwashers
Door locks, but will not fill up with water. Alarm sounds and lights flash once every minute or so
There is a rectangular magnet attached on the inside of the drawer for the detergent. Located on the right hand side near the front of the drawer. This magnet had come loose. Some glue and caulking worked well and the washer is working fine now. Meant to post this weeks ago.
May 12, 2009 | Kenmore Front Load Washer
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Clean light flashes constanly. Won't clear out to start new cycle
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 03, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
