Question about Diesel Garden
Tell me how to check hydrolic oil level on belarus tractor
2 Suggested Answers
  • 2468 Answers
SOURCE: ran tractor out of fuel try prime got fuel to pump
you need to open the fuel line at the injector on the cylinder to get the air out of the line while still priming the pump ,its building back pressure and fuel cant get past the pump,another way would be is to remove the air cleaner and carefully get a spray container of diesel fuel and spray directly into the air intake and see if it will fire,if so it may pull the air lock thru when the engine starts and till it gets fuel from the pump directly and runs on its own
Posted on Mar 07, 2010
Ii have a 6640 branson tractor hydrolic fluid has beed changed all filters including internal filter . bailed two bails of hay lost all hydrolic presure again1 any sugestions
Did you fill the new filters with hydraulic oil before you put them back on. If not you will get air in the system which will cause the hydraulics to fail.
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_722ea729aae6fd07
Aug 15, 2016 | Garden
Belarus 250as manuals
3 point hitch wont come up. ran out of oil, added more still wont come up. why?
Jan 02, 2012 | GPS
My john deere 316 stopped moving forward and reverse and the hydrolics stop on the blade. what could cause this?
HAVE YOU CHECKED THE TRANSMISSION/HYDRAULIC
OIL? THEY ARE THE SAME. ON SOME TRACTORS THIS
CAN BE CHECKED AT THE REAR OF THE TRACTOR JUST
BELOW THE SEAT. IT COULD ALSO BE A BAD HYDRAULIC
PUMP.
Jan 01, 2011 | John Deere 420,1020,2010,2020,2510,2520...
How do you check hydrolic fluid level in a John Deere 2030?
Right side foot plate next to the rear end housing is a cap you screw off with your fingers. It has a dip stick under it.
Sep 21, 2010 | John Deere Tractor Side Screen...
I have a 4120 PowrReverser with a similar problem. Machine was working great. Turned it off to talk to friend. Turned it back on and it would not move, forward or backward. Loader, PTO, and accessory...
You needb to drain the hydrolic fluid and then remove the suction tubethat comes from the right side of the engine and attaches to the hydrolic pump.Loosen the hose clamps and seperate the hose from the tube.Now go under the tractor and remove the brace that goes to the deck.Then go further under the tractor and take the last bolts out of the suction tube.Now you can remove the suction screen and clean it with some solvent and put it back in.Put your tractor back together,install a new hydrolic filter and top up the hydrolic oil,it should move.
Dec 05, 2009 | John Deere 4020 Gas & Diesel Tractor...
Have a 19 hp john deere zero turn riding mower. starts up, blades turn, has oil. will not move forward or backward. does the hydrolic oil level have anything to do with that?
ck on traction motors for lever or nut to release fluid. Can you move mower with engine off?
If so, this is your what is wrong traction motors
are disengage
Aug 30, 2009 | Garden
Husqvarna riding mower will not go in forward or reverse. it is hydrolic
Check this site out it is called manuals online. Have you checked the oil level ? could be something simple like an o-ring.
Jul 26, 2009 | Garden
I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
66 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Are you a Diesel Garden Expert? Answer questions, earn points and help others
