Question about RCA Televison & Video
I HAVE A RCA 27F634T PICTURE IS CLEAR EXCEPT ANY VERTICAL IS CONCAVED TOWARD THE CENTER "EXAMPLE IF YOU ARE LOOKING AT A GOAL POST THE UPRIGHTS ARE BOWED IN. THIS DOESN'T HAPPEN ON ANIMATED SHOWS. HOW CAN I FIX THIS OR IS IT EVEN WORTH FIXING
    Problem Solver:
  • 12 Answers
You have a horizontal issue with the unit and it is either in the HV supply area or the eprom may be corrupted.
Posted on May 14, 2008
32" RCA white vertical "Hazing" that eventually clears up
daniel143962
Take you unit to a service center and ask them to fix it. They won't be able too, but ask anyawys. When they tell you they can't fix ask them for the work order and then call 1877-297-8391 and they will help you
Feb 23, 2010 | RCA L32WD22 32 in. LCD HDTV
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
52" rca rear projection
the picture is bent inward and shadow looking sides are cut off.
Aug 10, 2009 | RCA D52130 52" Rear Projection Television
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA projection TV - the picture only shows red green and yellow and the picture is distorted almost concaved. It overlaps and nothing is clear. All 3 bulbs seem to be working. No idea what is wrong.
Sounds like convergence problems. This TV may not have the standard "STK.." modules. These sets are bad to lose voltage feeding the convergence amplifiers.
Mar 31, 2009 | RCA P52926 52" Rear Projection Television
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
The picture is drawn in from the sides
this problem we cal vertical fault..cause by capasitor is not in good condition at vertical area or loose solder at the vertical ic
Dec 08, 2008 | RCA F35673MB 35" TV
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
RCA P46770CK
Check Cr4503 in the vertical circuit for short or leaking. The convergence circuit is most likely fine. Also check for any leaky electrolytic caps in the 500 block. (example) CR4503 will be printed on the PCB as CR503. The vertical circuit is located in the center of the chassis behind the big aluminum heat sink.
Nov 01, 2007 | RCA P46810LV 46" Rear Projection...
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
