Question about Riccar 8955 Upright Vacuum
Our Riccar SupraLite Upright Vac used to glide across the floor so easily, but now we have to push it pretty hard. This just recently started. What can be wrong?
  • snbonfiglio Sep 18, 2010
    You're right! I should have been more generous. Please don't turn in your "DAGDD" button...surely someone else out here in cyberspace will need you. :)
  • Anonymous Mar 17, 2014
    burning smell
  • 377 Answers
Suggest you check the wheels to see if they are moving freely. Also check the beater brush to see that it is moving freely. Be sure the belt has not broken. If it has, replace with a new one. Also take the time to clean the beater brush of any debris and spray a little WD40 on both ends of the beater brush axle.
Posted on Sep 12, 2010
  • 1 more comment
  • snbonfiglio Sep 17, 2010
    It wasn't any of the above but at least I learned how to open my vac and check out all these items. Thankss for your response.
  • pwillitz Sep 17, 2010
    Oyi! Look at all you learned! And you only gave me 2 thumbs up!!!!!
    OH! THE SHAME OF IT ALL!
    I will have to turn in my "Do a good deed daily!" button.
    Glad it helped a little at least.
  • pwillitz Sep 18, 2010
    Ah! I will hang on to it a bit longer. At least you did respond. I have about 170 solutions submitted with only about 23 responses.
    Have a great weekend.
    Paul
Hard to push across carpet
Check the belt that drive the brush not broken or brush not clogged up.
Oct 01, 2016 | Dyson DC28 Animal Upright Vacuum New DC 28...
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
Riccar supralite makes a loud rattling noise like the roller is banging around
If the noise is not something in the brush roll or the brush roll bearings or shaft is damaged the impeller may have something stuck in it or it may be broken.
May 15, 2014 | Riccar Vacuums
Too much suction on smooth surface
Check the wheels on the bottom plate to make sure they are not allowing the bottom to sit flat on the floor. The wheels must keep maintain a gap between the plate and floor or it will suck down like a suction cup.
Jan 26, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
I need to replace the belt on my Riccar supralite vacuum and need instructions
Lay the vacuum upside down, remove the bottom plate, remove the brush roll and belt, install new belt around motor shaft and brush roll, pull on brush roll to stretch belt far enough to drop brush roll back into place.
Aug 14, 2013 | Riccar 8955 Upright Vacuum
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
Riccar supralite sounding rough
it could be the bearings at end of brushbar,take belt and brushbar off and see if it's ok, if ok would sudjest replaceing bearings
http://www.riccar.com/ftp/whitepapers/RSL_SupraLite_OwnersManual_8-08.pdf
Mar 22, 2013 | Vacuums
Dyson Animal Vac has become hard to push
Hi there, check that your brush bar is going round if you are having this problem on carpet. When the machine is stood upright, ensure the brush control dial is in the centre position when upright and then moves forward when you release the head.
If this does not solve the problem call us on 1866MYDYSON as we may be able to run through some more checks to help you.
Kind regards
Darran
Dyson Customer Liaison
Apr 06, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
DC17 doesnt move on floor good
Yes, it certainly sounds as though you haven't re-fitted the sole-plate correctly. On most models, the sole-plate has three tabs at the front, and these locate in slots in the bumper bar at the front of the body. These tabs must be in the slots before you tighten the three locking screws. You need to hold the rear of the sole-plate up while pushing the tabs in to the slots, then press down on the rear and tighten the screws. Just the fact that you cleaned the machine will not be the cause of the problem.
Feb 10, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Reset button on riccar upright vacuum
I CANT SEEN TO GET THE TOP TANK TO SNAP BACK IN, IT KEEPS SPILLING THE WATER AND SOLUTION
Dec 21, 2008 | Riccar 8955 Upright Vacuum
Riccar 8955 Upright Vacuum Logo
290 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
