Question about HP Compaq nx9030 Notebook
Does not power up when plugged in suspect battery needs replacing
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Replaced coach batteries and still not working
There is a relay that operates when you hook up to shore power that switches from battery power to converter power. It also charges the batteries. If you do not have battery power then suspect a faulty relay. It is located inside the power converter.
Aug 15, 2016 | Thor Motor Coach 2014 Windsport 32A
My dell inspiron plugged in not charging
buy a replacement charger
if this does not work
i suspect the socket is perhaps damaged
sometimes its the laptops power management
so take the battery off
open the screen
press the power on
wait a few seconds
plug the battery back and the power
and see if the light flashes for charge again
i do suspect the charger or the laptops power socket...
Apr 19, 2015 | Dell Computers & Internet
Hi my presario cq62 battery is not charging can u help me
There are 4 things this could be:
1.) There may be an issue with your outlet/power strip. Try plugging the power cable into a different outlet.
2.) The power cable's brick (that box-like component in the middle of the cable) may have gone bad. Some bricks will have a green LED on them to show when they are operating properly. If the LED is OFF, you need to replace the power cable. If it's ON, the cable is probably OK. If there is no LED, test with a multi-tester.
3.) Your battery may be bad and, therefore, cannot charge. The steps to test this are below (after #4).
4.) You're DC jack (the part inside of your laptop which the power cable plugs into) has broken solder joints due to too much tugging of the power cable over time. The steps to test this are below.
For issues 3 and 4, try the following: 1.) Remove the battery, 2.) Plug the power cable into the laptop, 3.) Try to turn ON your laptop.
If your laptop can power ON, then the power cable and DC jack are working fine and your battery needs replaced. If checking the brick's LED (Issue #2) has proven the power cable is fine, AND the laptop does not power ON, then you need the DC Jack resoldered (PC shop).
I hope this is helpful and best of luck!
Sep 21, 2011 | Compaq Presario CQ62-215DX Laptop
My acer laptop will not charge anymore when plugged in
Could be one or all of these things:
Old battery, defective battery, defective charger, broken ic power port.
Nov 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
When adapter plugged in computer starts then goes
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 14, 2009 | Dell Inspiron 6000 Notebook
Toshiba satellite laptop will not power on if you plug in the power cord.even you take off the battery. but it will turn on if on battery power. if its runnung already it freezes if you plug in the power...
I would suspect that either your power cord or power adapter is defective.
Try testing using a new power cord/adapter & see if this fixes the problem.
Another possibility might be a loose or defective power connector in the laptop. Check the connector where you plug the power cord. It might need to be re-soldered or replaced.
Nov 07, 2009 | Computers & Internet
Dark screen, no power ligts at all
try taking out the battery and plug in power, if it works, i suspected it's a battery faulty that needs a replacement.
May 28, 2009 | Everex StepNote NC1500 Notebook
Possible mishap with the power?
there are different ways on how to check the problem you encounter regarding on your machine. kindly follow the procedures below:
- first take out the battery and plug in the power supply. if it works, suspected it's a faulty battery (if your machine is under warranty call the service center for the replacement of your battery
- if the machine won't turn on after taking out the battery and pugging in the power, take out the hard disk, plug in th power. if it works, suspected hard disk faulty. (replace hard disk)
- if machine still won't turn on after taking out the hard disk, take out the memory card. you will hear a beep sound after taking out memory card. if it works suspected memory card faulty. (replace memory card)
- if you didn't hear any sound after taking out the memory card, suspected motherboard faulty. (replace motherboard)
May 27, 2009 | Toshiba Satellite A25-S207 Notebook
Flashing battery light orange three times then one green?
Try charging your battery for about 30mins, light orange still came up it means your battery is faulty. To confirm, take out your battery and plug in power. If it turned on, i strongly suspected it's a battery faulty. You need to replace it.
May 17, 2009 | Dell Inspiron E1705 Notebook
No power
It the notification occurred while the AC adapter was connected to the system, then I'd suspect the AC adapter 1st.
If available, try another compatible ac adapter and see if the system powers on.
Since the system will not power on with AC adapter alone, I suspect it has failed.
Places Like Best Buy, should have a bench AC adapter you could test to see if the system powers on, if so, then buy a replacement.
If under warranty, contact HP tech support.
Jun 15, 2008 | HP Compaq Presario C304NR Notebook
HP Compaq nx9030 Notebook Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
