Question about Hotpoint Freezers
Motor comes on for about 2 seconds and stops and freezer not freezing
  • 32 Answers
Compressor probably going off on overload,clean condenser,and cool compressor.If there is a fan,make sure it is running
Posted on Sep 16, 2010
3 Suggested Answers
  • 161 Answers
SOURCE: Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Posted on Jun 30, 2008
tomsat69
  • 214 Answers
SOURCE: Freezer motor keeps freezing up
Sounds like a defrost timer.Also it can be a defrost thermostat.Try to adcance the defrost timer to a defrost and see if it melts the ice off.If so then i would say you need a defrost timer hope i helped:)
Posted on May 16, 2009
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Daewoo FRN-U20IA top of freezer compartment won't freeze
It was the fan at the top of the freezer that had stopped working after 3 years, therefore the freezing air wasn't getting to the top of the freezer. From the inside, unscrew light unit and unclip, pop out two circular discs at top and unscrew one screw. Unscrew 2 more screws and prise the back panel off. (Arrows mark the clips). Pull off fan, take out motor, replace (keeping rubber bits) and push back fan with a bit of nail varnish on spindle. Put everything back together. Turn on, depress door light switch and after 30 seconds fan should rotate. You can buy a fan on eBay or from www.4daewoo.co.uk for about 40 pounds.
Feb 27, 2013 | Daewoo FRSU20IA Freezer
Why is my freezer not freezing
I had this happen to my freezer and I had to install a fan in the freezer by a repair man and then it worked like brand new.
Jul 18, 2012 | Bush BAF55143W Freezer
Will not freeze
either overload and relay or compressor run windings are bad
May 25, 2010 | True 11.4 cu. ft. / 323 liter Upright...
Freezer comes on fan starts after a few seconds goes off freezer unit freezes solid fan doesnt come on again fan is ok
Good day,
When the thermostat is turned on, the fan and compressor should come on and start at the same time. If the compressor continues to run and the fan doesn't, then the fan motor or the wiring to it are suspect.
Quote (The fan motor is o.k ). I doen't know how you tested it, but it still remains suspect, since the thermostat sends power to both of them at the same time.
Nov 03, 2009 | Whirlpool Freezers
Paddle won't spin
I have a White Moutain freezer motor that is two years old and had the same problem as yours. During my last batch of ice cream the motor was spinning but the beater wasn't turning. I removed the motor and the square drive was spinning but I could stop it with my finger, there was no power like a gear or clutch was shot. I called the 1-800 number on the motor and they said they would send me a new motor. I didn't need to show a receipt or anything. All they wanted me to do was return the broken motor and they even supplied paid postage. I recomend you call them and ask for a new motor.
May 26, 2009 | White Mountain Freezer F69206-X 6 quart...
Maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Sep 22, 2008 | Freezers
Jun 26, 2008 | Freezers
Freezers Logo
240 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
Gerard Curran
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
