Question about Simplicity for Children 4-in-1 Convertible 3040 Crib
I need to order a new mobile/arm piece, how can I do that?
The left arm-clamp has come off. It seems to be different from the left arm-clamp. At first I thought I just needed to figure out how to reset the spring, but a neighbor seems to think that the arm was...
They break. The latch arm is one piece, spring and all. So if any part of it is still in the
juicer it's broken. Order a pair from Omega and have them walk you through replacing
them.
Nov 22, 2010 | Omega 1000 Juice Extractor
Dishwasher works perfectly but has a regular thump when operating. Rotating arms not fouling. Does it all the time
One of the arms is either broken or starting to break...check them closely for cracks i the plastic or broken pieces....
better yet would be to just order new oarts and replace them. It is not that hard to do and is very affordable...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Aug 17, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Having a problem getting charger to nstay lock in to razor
1. a Piece of tape to hold the locking arm down works
2. for a more long term fix, I drilled a very small hole thru the locking arm when it was held down with tape, I now put a small nail thru the hole and it holds down the arm.
This solution has been working for me for about 2 years, total cost 3 cents for the nail.
Feb 13, 2010 | Braun Syncro 7526 Electric Shaver
Part 1544681 has come off. Cannot reattach.
I have had the same problem twice. After paying for a replacement part and waiting for it to arrive once, i decided to try fixing it myself and came up with a fix that works realy well dispite the manufactures bad design. I used a small "Butterfly" bolt.23345fe.jpg Grind down the wings so they will rest only on the inside rim and allow the part to spin. Cut the bolt to the proper langth. Drill a through the middle of the larg part and use the bolt to hold it all together. Water can still pass around the bolt. Hope this helps.
Aug 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Plastic on steamarm blew off
Those pieces (2 of them) are suppose to come off. The outer sleeve turns 1/8th of turn clockwise looking down on it and then can be slid down. The inner slides off and has a flat spot on the back to line up with the steam wand, it's held in place by an o ring. All can be ordered through Delonghi.
They are designed to be removable so they can be cleaned after each use.
Before replacing any other parts, try descaling your machine. Build up will cause heating and steaming issues.
Aug 23, 2009 | DeLonghi EAM3400 Espresso Machine
Broken Cartrige Guide Arm, can't find part number
it is like as canon LBP 1210 or hp 1200,1000,1300
Apr 27, 2009 | Canon imageCLASS D320 Digital Copier
Installation of a new top spray arm
should only be a little plastic push in clip facing down towards the dw in the middle of that spray arm. should be able to pop it out. you may need to take the supply tube off the back so you can get a good look at it
Nov 21, 2008 | Dishwashers
I have a Danby DDW399 W countertop dishwasher
I have a Danby DDW399W countertop dishwasher. I need a replacement tap attachment and haven't been able to locate one. Email buddysmom@telus.net
Jan 14, 2008 | Danby 22 in. DDW396 Free-standing...
Third level spray arm
If your dishwasher is the same as our GLD2440REB1, the sort of star-shaped piece on the ceiling unscrews.  Then there's a sort of flangey washery kind of guy that you can poke through the star-shaped piece and snap into the arm.  Then screw the whole thing back on to the pipe.  I know this works, because I do it every time the arm falls off.  Which is every time I run the dishwasher.  ... Oh, crud.
Before I order a new part (spotted for US$7.65 plus shipping), I'm going to try putting some thread or a pin or something in there to hold it together.  Maybe some epoxy.
Am I a cheapskate or what?  :-)
Sep 08, 2007 | Frigidaire GLD2445RF Built-in Dishwasher
Simplicity for Children 4-in-1 Convertible 3040 Crib Logo
32 people viewed this question
Top Simplicity for Children Baby Gear Experts
Dennis Crouse
Joseph Hoffmann
Are you a Simplicity for Children Baby Gear Expert? Answer questions, earn points and help others
