RCA SDTV Model #27V514T
The TV is about 1 1/2 years old. This morning I was watching the news, and it just went off. It will not come back on. The red power indicater blinks on and off, but a picture does not appear. Also no sound. What could it be? And is it worth taking it to a repair shop or should I just buy a new TV.
Thanks for your help.
Kevin Tuohy
2102 W Broadway
Enid, OK
580-237-1069
kptuohy@sbcglobal.net
  • clpark3268 Aug 11, 2008
    My TV was playing this morning. I turned it off when I got ready to leave home. My daughter tried to turn it on while I was out and she called me and said it would not come on. the remote does not work with it at this time either. It will not turn off or on with the remove. If I try to turn it off or on manually it will not work. I unplugged it and plugged it back in, it still don't work you can only here the click noise to let you know that it is plugged back in but there is no picture or sound. Is it worth getting it fix or buying another TV.
    cparker
    clpark3268@yahoo.com
  • dabriz May 19, 2009
    ive got the same problem but the fuse is fine. in fact, i pulled the fuse and the tv and or red light would not come on at all, duh. it has to do with one of the millions of sotter joints on the card.
May want to take it in and have the power supply checked. Sounds like you may have blown a fuse inside. Very easy fixed yourself if you can find the right size fuse. Go online and try to find a manual for you model. Good Luck !!
Posted on May 26, 2008
No picture or sound
Does it make a squeal sound while plugged in to power? If so, possible horizontal output shorted. $150-$200 about.
Apr 17, 2010 | RCA 27V514T 27" TV
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
Lamp light?
Your lamp has probably failed. It is an XL-2100 lamp. Are you sure it is only a year old? This is a somewhat older model set. Was it a demo unit? This may explain why the lamp has failed.
Oct 06, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a rca 27 inch tv modle # 27v514t sdTV.when i turn it on 2 or 3 seconds it shuts off
The cable running from the button on the front unplug it as soon as you get the tv to turn on it should stay on.
Jul 28, 2008 | Televison & Video
Rca 32flascreen tv
high volatge transformer shorted...or component in hi E.
Jul 18, 2008 | RCA F32450 32" TV
Tv broken?
Yes your set can be fixed ,it may have shorted your hori out put transistor and also caused FBT to blow. Flyback Transfomer cost 150.00 up, to 175.00
Jun 19, 2008 | Televison & Video
RCA 32 in TV no picture no sound just a beeping noise TV power is on
The beeping sound is most likely the high voltage generator needing replacement. This is a fairly easy job if you have some tech support to discharge the picture tube. You can go to the following link and leave them an email with your model number and your symptom and they will email you back with the part you need and they provide free tech support with instant messageing so you can do the repair yourself. the HV generator takes about a half hr to replace and takes only the basic soldering ability. heres the link.
http://servicemanuals.vstore.ca/
May 19, 2008 | RCA HD52W59 HDTV Projection Television
56" RCA projection, model P56930BL, no power up.
#1 problem in this model for not powering up is the color wheel needs to be replaced or it could be the lamp is burn out or it could be the ballast it bad. But the #1 problem is the color wheel.
Mar 28, 2008 | RCA P56930BL 56" Rear Projection...
Rca tv screen went all red. you can still see program
Color wheel controls the color. try replacing then reindexing the color wheel. Let me know if you need further assistance.
Mar 14, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
Electro Med Services...
