Question about MSI K7T266 Pro2 (MS 6380-060) Motherboard
I have a MSI K7T266 Pro2 Version 2.0 Motherboard and I went to replace the processor, and When I went to put the old one back in it ,It quit working. Now neither one of the processor's work. The fans work and the keyboard lights up but I dont even get a beep out of the motherboard. Did I Blow the processor? ;I have tried everything., different ribbons, I cant even get a bios to come up on the monitor.
  • MSI Master
  • 17,173 Answers
It is very easy to bend the pins on a processor. Also you need to make sure that the locking lever is engaged.
Posted on Jul 31, 2017
SOURCE: msi motherboard
use the booklet that came with the MOBO...i used it and it was pretty user friendly...the acronyms on the MOBO will confuse you
Posted on Sep 15, 2007
MeneerFixIT
  • 5 Answers
SOURCE: Hav K7T266 Pro2 motherboard, can not get it to go past turning on
Lorna,
to change bus to 133 MHz, you need to unlock the speed by setting a corresponding jumper on the board to assign busspeed by bios. After doing so, you need to clear CMOS and reboot. Next you'll have to set speed and multiplier in bios. Ideally: 900MHz = 100 x 9. Alternatively: 133 x 6.5 If that doesn't help...check if your RAM-modules are any good anymore. When RAM is not functioning, CPU-error code may be presented, since CPU cannot read/write to RAM, therefore not function. Let me know how this turns out.
Kind regards,
Stephan
Posted on Jan 30, 2009
PC Commando
  • 142 Answers
SOURCE: I just bought a used (or refurbished) MSI 845GE
Return it
Posted on Sep 18, 2009
leethedeuce
  • 4472 Answers
SOURCE: I have an MSI 785GTM-E45
First thing I would do is try a different power supply as those are relatively cheap. If the problem persists it is likely a CPU problem.
Thank you,
Lee
Posted on Aug 22, 2010
byteguy
  • 2229 Answers
SOURCE: MSI usb problems
Sounds like your O/S was damaged when the old MB failed. I'd boot the computer with yoru system disk and run a scandisk or, in the case of Win Vista or 7, choose the option to repair Windows.
Posted on Mar 22, 2012
Motherboard goes for 3 seconds then shots itself
hi i like to help. first off, put back the old processor and reset the motherboard. you''ll find the jumper caps near the battery or you can read the label on the board something like jbat1. put the jumper cap on pins 2 and 3. wait 10 secs to reset the board then put it back to pins 1 and 2. The board should work now. to upgrade your processor i think you have to upgrade the bios first. download it from the manufacturers website. after bios update, replace the procesoor and it should work again.
Apr 17, 2012 | MSI K7T Pro2-A MS6330 (K7TTURBO-R)...
IDE devices not detected
daer customer check ahci mode (pata )mode will be check & your problu is solve.
Mar 02, 2012 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Audio, sound card
there you can see 5 white slots you can insert your sound card there..........you can youse 4.1 creative sound card only............
Nov 13, 2010 | MSI K7T266 PRO2-A Socket A XP Motherboard...
Audio draiwers no
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Oct 23, 2010 | MSI K7T266 PRO2-A Socket A XP Motherboard...
K7t266 pro2 ver:2 the mother board can't be powered on. Could some one tell me how to check it ok please
When your motherboard/CPU board CMOS battery dry or have charge then you can not run to power *********** board.Or CMOS is disable.Please check
1 Power supply
2 CMOS Battery
Mar 15, 2010 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
I am looking for diagram of my motherboard n.msi 1996 please help me, thanks lot
N-1996 is the 'C-tick' number. This is what MSI (Micro Star International), uses.
"A C-Tick mark may also appear on our MSI products that are required tocomply with Australian electromagnetic compatibility requirements andradio-communications standards. It signifies that the product may belegally sold in Australia. Now it requires EMC compliance must bemarked with the C-tick logo and ACA supplier code number. Our ACAsupplier code is N1996. The supplier is responsible for holding aCompliance Folder that contains compliant test reports and aDeclaration of Conformity."
(From MSI Computer.com)
Look on the motherboard in-between the expansion slots, (PCI, AGP) Also look in the middle of the motherboard, or off to one side.
You are looking for the MSI model number.
Example: K7T266 Pro2 v2.0
That means it's the K7T266 Pro2 -> version 2.0
Probably uses DDR Sdram at 266MHz. (PC2100)
If it is the MSI K7266Pro2 v2.0, it's also called the MS-6330
This link is to Motherboards.org, and the download page for the Motherboard Manual. It has all info needed to connect the wires.
What processors can be used. What ram memory can be used. What chipsets are on the motherboard.
It's a Motherboard Manual.
http://www.motherboards.org/mobot/manuals/MSI/K7T%2BPro2-A%2B%2B%2528MS-6330%2529/
Go to the right of -> File6330v10e-exe Version:--Release Date:--
,and click on -> Download <-
This is a Zip file.
After you click on it, it will download to your computer. IF, you do not have your downloads set to download to your My Documents folder, it will go to your desktop screen.
When you see it double-click on it.
A Microsoft 'Squawk Box' will come up. Ignore it. It's a safe file straight from MSI. They don't want to pay Microsoft, to digitally certify this download. If they did, they would have to pay Microsoft everytime somebody downloads this file.
Click on Run.
Now you will see the Extraction Wizard come up. Go up to the left, and click on Extract All File. Or the window may be a little different.
If so, click on Un-Zip.
Now you will have four unzipped files on your desktop screen, besides the original zip file. How to attach the wires is in File 2.
I would appreciate it, if you woulde rate my solution.
Apr 03, 2009 | Intel Motherboard
Lorna,
Kind regards,
Stephan
Jan 30, 2009 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
Msi motherboard
Sep 14, 2007 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
MSI K7T266 Pro2 (MS 6380-060) Motherboard Logo
261 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
