Ive installed a 2nd sata drive in my cpu with a pci sata controller card. my cpu will not power up but once i disconnect the 2nd drive it powers up
  • 702 Answers
Check the BIOS to make sure the primary boot device is configure properly.
Posted on Sep 12, 2010
How to install sata hdd for mother board asrock m266a
The drive installs physically like any any hard drive. The problem is that this motherboard does not support the SATA protocol. You would need to get an expansion PCI card SATA controller. Even then, since the motherboard BIOS is not set up for SATA, you would not be able to use the SATA drive(s) as the boot device. Also, you would need a Molex to SATA power adapter for your power supply since the SATA power connector is different. And you would need a SATA data cable if the expansion card does not come with one.
Apr 26, 2014 | Asrock M266A Motherboard
How much power do I need for this board?
Power Supply Calculator,
http://extreme.outervision.com/psucalculatorlite.jsp
A) System Type: 1 physical CPU (Processor)
B) Motherboard: High-end desktop (KN1 Extreme)
C) CPU Brand: AMD
4) CPU Socket: Socket 939
5) CPU: Lord only knows. I chose a Processor that uses Up To 89 Watts. AMD Athlon 64 4000+ 2400MHz San Diego 1.35v
6) CPU Utilization TDP: 90% TDP (recommended)
(In otherwords leave alone)
7) Overclock my CPU!: Leave alone
8) RAM: 2 sticks of DDR SDRAM
9) Video Cards;
A) Video Brand: AMD (AMD owns ATI now)
B) Video Card 1: AMD Radeon HD5450
C) Video Card 2, 3, and 4: Leave alone
D) Video Type: Leave alone
E) Physics Processing Units: Leave alone
10) Hard Drives:
A) Regular SATA: 1 HDD
11) Go to Drives;
DVD-RW/DVD+RW Drive: 2 Drives
12) Go back up to the right; PCI Cards:
I left alone. Only you know at present, if you are using one, or more of these types of PCI cards.
13) Go to Fans;
80mm / Regular / 2 Fans. (Just guess-timating)
All fields should be entered now. If not make adjustments to what I didn't know. Include in the proper field.
Now go to the bottom right, and click on - Calculate
(Calculate / Reset / Print )
I come up with 265 Watts.
Want to know EXACTLY what hardware is used inside; without opening the computer case?
Use the tiny free program, CPU-Z from CPUID.com
(Can help you download, install, and use, CPU-Z if you need.
I have used CPU-Z for years)
http://www.cpuid.com/softwares/cpu-z.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 19, 2012 | ECS KN1 EXTREME Socket 939/nFroce...
Install 2nd Hard Drive with different connectors and different OS.
yes you can use either sata power or molex(4 pin) plug to power your new SATA hard drive but not both at the same time.
Mar 19, 2012 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Have a d530c tower how do you add a sata drive?
Hi richo64
It seems your motherboard is not equiped with Sata plots :
http://h18000.www1.hp.com/products/quickspecs/11632_na/11632_na.HTML.
If this is the case , you need to purchase a PCI Sata controller card with at least one internal Sata plot .
Disconnect power plug and make sure you are not static electrically loaded . Open tower by removing side panel . Install PCI card on an available PCI plot inside your tower . You will also need to acquire a Molex/Sata converting power cable and a Sata interface cable . Once done , install your Sata drive in an available place in your desktop and connect the cables .
Start your pc . If you have kept the old Pata drive in operation , immediatelly and repeatedly hit a F key ( often Fi or F3 or F8 , it depends on the machine ) to acces bios , select the Sata drive and fix the boot priorities .
Sata controller cards and cables are easy to find by googleling on the net or in any computer shop .
Best regards ,
fanaudi .
Jul 23, 2011 | HP Compaq d530c PC Desktop
I have a compaq evo w8000 desktop and want to install a sata drive instead of the built in scsi drive. I can install windows xp (i've got the sata card drivers and pressed F6 etc, that all works fine)...
ok a very very old DT , desk top, ive done this vast times, back long long ago... 17 years old, you use this old of hardware why?
we dont use XP in uSA its VIRUS magnet. horred
and no updates, now, means will get worse each day forward in time. endless...
has built in, SCSI chip. l Ultra160 SCSI and Ultra ATA/100
that ATA means PATA port, not SATA back then.
my wild guess now is that someone put an a new SATA card in the PCI slot, (ive done so vast times)
The BIOS in your machine will never support that.
that means you can not boot to PCI SATA. for sure.b
but wait, the better SATA card works just like a new Adaptec
ultra160 card that if love.
the new SATA card has what is called a BIOS extension ROM on said card, and a new HOT key to access it.
some are CONTROL +A but each maker of said card ,does as he pleases, so READ THERE MANUAL.
you set it to boot o STAT port and it does if port 0 is bootable drive. SATA.
here ill take you now to newegg.com and show you hardware that works.
if you showed a photo of your CARD and # id have answered, 10x better. !!!!!
i cant shop for you, nor pick SATA 1 ,2 or 3 for you.
but here
https://www.newegg.com/Product/Product.aspx?Item=9SIAC0F5KW5808&cm_re=sata_card-_-9SIAC0F5KW5808-_-Product
the big trick here is making sure you relic MOBO
supports the current levels of PCI>
like above
32-bit / 66MHz PCI interface compliant to PCI Rev 2.3
(Backward-compatible with PCI 33
https://www.promise.com/media_bank/Download%20Bank/Datasheet/FT_TX2300_DS091406.pdf
Control +F (see page 11)
https://www.promise.com/media_bank/Download%20Bank/Manual/FastTrak_TX_Series_User_v3.2.pdf
warning, ive run in to big problems using very old relic
motor-boards that use the very old PCI signals and levels.
and will fail on some newers card
I warned you,
the above reads good. for that. (hope )
now my question why use such old hardware.
when goodwill has truck loads of 10year old pCs for $20
why, love of XEON?
id trash it.
find a use desktop with SATA ports, ALL DO now, or scrapped.
May 08, 2017 | Compaq Evo Workstation W8000 PC Desktop
Can I install this product in an older XP computer? If yes, How?
If the computer does not have a SATA controller on the motherboard, then you need to purchase a PCI SATA controller and insert it into the PCI expansion slot. You will also need a SATA data cable and a SATA power adapter that converts a 4 wire power connector to a SATA power connector.
Sep 14, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Motherboard diagram
A Computer Motherboard Diagram motherboard-diagram-01.jpg Once you know what you are looking at, you can recognize the components on any motherboard layout. A computer motherboard diagram is very useful for when you need to replace motherboard, do motherboard upgrades, troubleshoot motherboard, or build your own computer.
  1. PCI Slot - This board has 2 PCI slots. These can be used for components such as Ethernet cards, sound cards, and modems.
  2. PCI-E 16x Slot - There are 2 of them on this motherboard diagram, both are blue. These are used for your graphics card. With two of them onboard, you can run 2 graphics cards in SLI. You would only need this if you are a gamer, or working with high end video / graphics editing. These are the 16x speed versions, which are currently the fastest.
  3. PCI-E 1x Slot - Single slot - In the PCIe 1.x generation, each lane (1x) carries 250 MB/s compared to 133 MB/s for the PCI slots. These can be used for expansion cards such as Sound Cards, or Ethernet Cards.
  4. Northbridge - This is the Northbridge for this motherboard. This allows communication between the CPU and the system memory and PCI-E slots.
  5. ATX 12V 2X and 4 Pin Power Connection Power Connection - This is one of two power connections that supply power to the motherboard. This connection will come from your Power Supply.
  6. CPU-Fan Connection - This is where your CPU fan will connect. Using this connection over one from your power supply will allow the motherboard to control the speed of your fan, based on the CPU temperature.
  7. Socket - This is where your CPU will plug in. The orange bracket that is surrounding it is used for high end heat sinks. It helps to support the weight of the heat sink.
  8. Memory Slots - These are the slots for your RAM. Most boards will have 4 slots, but some will only have 2. The color coding you see on the motherboard diagram is used to match up RAM for Dual-Channel. Using them this way will give your memory a speed boost.
  9. ATX Power Connector - This is the second of two power connections. This is the main power connection for the motherboard, and comes from the Power Supply.
  10. IDE Connection - The IDE (Integrated Drive Electronics) is the connection for your hard drive or CD / DVD drive. Most drives today come with SATA connections, so you may not use this.
  11. Southbridge - This is the controller for components such as the PCI slots, onboard audio, and USB connections.
  12. SATA Connections - These are 4 of the 6 SATA connections on the motherboard. These will be used for hard drives, and CD / DVD drives.
  13. Front Panel Connections - this is where you will hook in the connections from your case. These are mostly the different lights on your case, such as power on, hard drive activity etc.
  14. FDD Connection - The FDD is the Floppy Disk controller. If you have a floppy disk drive in your computer, this is where you will hook it up.
  15. External USB Connections - This is where you will plug in external USB connections for your case or USB bracket.
  16. CMOS battery - This is the motherboard's battery. This is used to allow the CMOS to keep its settings.
May 31, 2010 | E-Machines T2542 PC Desktop
Motherboard will not post
Turn it off. Remove the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-drive).
Remove any add-on PCI cards (modem, network, TV, 2nd video).
Remove ALL the RAM.
Reconnect the power, and turn it on.
Try to POST -- if it is not "dead", it should "beep" a few times, due to having _NO_ RAM installed.
Turn it off.
Add ONE stick of RAM.
Connect the AC power-cord.
Turn it on.
Same "beeps"? Different? No beeps?
Oct 09, 2009 | ASUS P4P800 SE (890552603657) Motherboard
How to use/add sata on my mobo?
You need to add a controller card for SATA. These are not expensive. One you might consider is this:
Vantec UGT-ST200 Serial ATA PCI Host Card
It costs about $25, and is available many places, including Tiger Direct, Fry's Electronics, and others. Here is a link to one on the Fry's website. Shop around, you might even find it somewhere else cheaper:
http://shop4.frys.com/product/4236634?site=sr:SEARCH:MAIN_RSLT_PG
Once you install the card in an empty PCI slot, you install a new SATA hard drive, and cable it to it. It should work fine with your existing PATA drive(s).
Cheers
Nov 13, 2008 | PC Chips M848ALU Motherboard
XP won't recognize 2nd SATA drive and shows 1st SATA drive as drive F:
To get Windows to recognize the 2nd HDD, you have to initialize it in disk management.
http://www.simplyguides.net/guides/prepare_second_hdd/prepare_second_hdd1.shtml
As far as the drive letter for the OS install, that was caused by the HDD not having an existing partition and other drives in the system having one (Either USB Drive, Printer with a card reader, 2nd Internal HDD)
Here is a Microsoft article on how to change it, but you'll notice MS doesn't recommend you try it. (Personally, I can live with ah HDD with a drive letter other then C:, so can Windows.)
http://support.microsoft.com/kb/223188/en-us
In the future, when installing XP, boot to the CD, run the install to the point of formatting the hard drive. Once formatted, turn off the computer, reboot to the XP install again, the HDD will be assigned C:
As far as the drivers go, they needed to be installed in this order:
Desktop System Software
Chipset
Video
Audio
Network
Modem
Aug 04, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
