Question about Nokia 3110 Cellular Phone
My 3110 is got damage? its lcd is broken and other things are ready and it is not started, so what shuld i do? and ans me with photo graph andalso i want to learn more abut mobiles phone.
    Guru:
  • 317 Answers
Take mobile to nearest repairing center
Posted on Sep 13, 2010
Add toner always show copy not print and ready
When the toner supply belt is broken or displace than toner not supply from the cartridge in the DV unit.You shuld check this drive section and replace new one.I wish best luck.
Oct 26, 2013 | Kyocera Mita KM-4035 Printer
I have an HTC desire and the LSD screen is broken. The actual screen dose not look broken but there are stress lines on the side that you can see on an angle, just. I want to know how much to fix it and...
Welcome to Fixya. The price of the repair will depends on the service center if the only thing that is damage is the LCD or just the connector you also need to keep in mind the labor for the repair man. You won't loose the photos inside since the LCD is just the only part that will be replaced not the software. Just remind the repair man not to format the phone so that you will not loose all the data on the phone.
Thanks for using Fixya.
Jul 10, 2011 | HTC Desire Cell Phone
How do I replace a cracked LCD Screen? Olympus FE-370
This requires technical skills plase attempt this only if you know about electronics as there are many of the delicate components attached with the LCD screen in a digital camera.Open the camera carefully and do not touch or bank anything against it's lens senser inside as it might even detoriate the quality of the photos you take with the camera after replacing the LCD screen.Carefully remove any loose remains of the screen broken now apply solder carefully to the strip wire connecting to the screen boken with a de-solder wik to remove the connections from the main motherboard.Take out the broken screen and clean the terminals of the main motherboard with some alcoholic spirit or petrol to remove all dust and dirt from the terminals accumulated on them now take the new screen and solder the ribbon like wire on the terminals by applying minimal solder on each terminal with the soldering iron remember not to apply excess of solder on any of the terminals as they might get shorted with each other and will damage the camera as well as the new LCD screen replaced when powered on.If in any case you see any terminal shorted with one another then remove the excess solder with the help of de-solder wik or a hot air gun .Replace the screen by soldering each terminal carefully and now replace the cover and your camera is ready to click photos .BUT STILL I WOULD RECOMMEND YOU THE REPLACING ACTIVITY ONLY IF YOU ARE A TRAINED PERSONAL IN THE FIELD OF SOLDERING MICRO-ELECTRONIC COMPONENTS.
Also that use a soldering iron of 25watt or less as the heat might damage the delicate components
Dec 03, 2010 | Olympus FE-370 Digital Camera
The power button has broken
If this is only the buttton but the set is working allright, you can mend the broken one with a fabricated button. Get help from a plastic shop / machine tool shop or use an old knob to be stuck up and fixed into for activation of switch.
Have the set connected to an external switch and use the remote to switch on than the damaged switch which must be kept ON.
Sep 18, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My dell laptop fell off my bed and now my screen is broken.. is there a way i can get my pictures off?
Provided the screen is the only thing damaged, you have several options.
  1. Connect and external monitor and use it to see what you are doing while you copy you photos to other media. (Fn+F8 enable external monitor)
  2. Remove the HDD, connect it to another system using a USB adapter, and copy your files: http://www.amazon.com/Universal-Drive-Adapter-Serial-ATAPI/dp/B0012TOG08
  3. Replace the broken lcd: http://cgi.ebay.com/DELL-LATITUDE-D620-D630-COMPLETE-LCD-WARRANTY_W0QQitemZ220582533329QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item335bbe58d1
http://support.dell.com/support/edocs/systems/latd630/en/sm_en/display.htm#wp1105347
Apr 03, 2010 | Dell Latitude D630 Notebook
Hi , I haVE TI84 SILVER EDITION AND i LOST THE MANUAL ON HOW TO OPERATE IT iM TRYING TO DO GRAPH AND i CAN'T CAN YOU HELP ME I
Here is the link to the manual.
Here is a short tutorial to get you started.
First thing to do before any new type of graphing problem
1. Turn StatPlots OFF : press [2nd][STATPLOT][4:PlotsOff] [ENTER]
Second thing: Clear the statistical lists
2. Press [2nd][0][PGRM] DownArrow to point to ClrAllLists.
3.Press [ENTER][ENTER]
Third thing : Configure the graph type to be FUNCTION graph
4. Press [MODE]. If FUNC (on fourth line) is highlighted. Press [Y=] and start entering the functions.
5. If FUNC is not highlighted, use Down arrow till 4th line, highlight FUNC and press [ENTER]. Press Press [Y=] and start entering the functions.
Fourth thing: Enter function and select them for graphing
1. As you start entering the function Y1=, notice that the = sign becomes highlighted. Press [ENTER] when Y1 is typed in. Make sure the = sign for Y1 remains highlighted as cursor moves to Y2=.
2. Keep entering the functions and verifying that their = signs remain highlighted as cursor moves to another equation.
3. When finished press [ENTER]
4. Look at the graph style for each function: it is a bit of line to the left of each Y. Here is a picture of all the 7 styles.
To set a graph style, highlight the style to the left of the Y, and press [ENTER]. Each time you press [ENTER] you see a new style, in the order shown on picture.
Avoid the style of Y6, it is bubble, and as such will burst and disappear once graph is finished. Avoid also the triangular ones (for Y3 and Y4) they will shade areas of the graph, and may hide other functions.
Fifth thing: Graph Functions.
1. You can press [GRAPH] to see your graphs.
2. If one curve is missing (and you have not set its style to be rhe bubble), it may be due to the Window dimensions.
Sixth Thing: Set Window dimensions and Zoom.
1. Press [ZOOM][6:ZStandard] to use standard window dimensions.
2. If curve still missing, Press [ZOOM][3:Zoom Out] to zoom out so that you may be able to see a bigger range for the functions.
3. If necessary press [WINDOW] and set the Xmin, Xmax, Ymin,Ymax to values of your own.
Dimensions must obey the conditions: Xmin < Xmax, and Ymin < Ymax.
Feb 11, 2010 | Texas Instruments TI-84 Plus Silver...
My 50 inch toshiba is black only on one side i have half of a good tv
Ur backlight video board is the problem,must change for this problems.Check for crack or damage the on the LCD screen,tv it worthless,if the LCD screen is dead,broken LCD screen glass.
Nov 24, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Graph after photo is taken
I'm not exactly sure what you mean by "graph looking thing" but, you can change what appears on the screen in the setup menu.
Sep 05, 2009 | Nikon D40x Digital Camera
Physical damage to lcd screen
I have TCL LCD TV 32E61
Dispaly problem in Centre White line
Dec 09, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Nokia 3110 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
