Question about Sport & Outdoor - Others
Discovery channell fx5000 weathertech instructions
Meaning of charging system fault
Check alternator output with a volt tester ,check drive belt is on and not slipping.
Jan 11, 2016 | 2010 Land Rover / Range Rover LR4 /...
Do i have to find a thermo-hygrometer sensor and a wind speed/anaemometer for the stx-7500 weathertech weather station, or can i use a general or generic brand for these sensors? I searched for a man
contact the manufacturer by phone to see if parts are available.. If the unit can be calibrated then you may be able to use generic parts . Contact Jaycar and see if they can put you onto anyone who repairs the units.
Feb 08, 2015 | Cars & Trucks
Weathertech TX2000 Outdoor Reading does not work
I hope you also know the transmitter is not weather proof. I know that is not logical, but it is a fact. I wrapped mine in plastic and left the bottom open to reduce condensation. I hung it at the northern end of my home out of direct sunlight. Archery tech is correct about putting it close to the base to set it. Poor technology I guess.
Nov 24, 2013 | Discovery Channel Measuring Tools &...
Numark 5000FX power
***Please read this reply in its entirity because there's more information way down at the bottom of the reply. Now the below Pro-Audio International Supplier Thormanne, had the power supply for the Numark FX5000. That's where I bought mine and it was shipped fairly quickly. Also here's the part number from my order so you know you're getting the very specific power supply the FX5000 requires.***
1 Stck order code 188821
Numark Power Supply for Numark 5000 FX
each 42.85 EUR, total 42.85 EUR
Tel,-0049-9546-9223-641
Fax,-0049-9546-9223-24
greece@thomann.de
Musikhaus Thomann e.K.
Treppendorf 30
96138 Burgebrach
Germanyhttp://www.thomann.de
Apantiseis stis perissoteres erwtiseis sas, mporeite na breite edw: http://www.thomann.de/gr/faq_99.html
HRA Bamberg Nr. 8988
Also so you are aware you're going to need to pick up an eletrical convertor for electronics built with EURO specs but allows to down step the current to what it is in America. Any Fry's Electronics or Pro-Audio store here in the US will have the one I bought which is a -
MODEL: TC-100A Up/Down Convertor $45.00.
That's it and my mixer is playing wonderfully so there you have it.
Thank you.
Jan 31, 2013 | Numark Industries Numark 5000FX 5 Channel...
I do not have instructions for the Discovery Kids Pottery Wheel. I need to know how to form the clay. Do you need water?
go to mscustomercare.com-scroll down until you see the pottery wheel, then download directions. We did receive the directions for my daughters pottery wheel, however it is missing page 4 and 8. I hope this helps!
Dec 28, 2010 | Discovery Channel Discovery Ultimate...
My new storm tracker STX7500 weathertech does not display the outside temperature
Take out the batteries in the main station for at least 5 min. Also, check the batteries on your outside station and make sure that they are new and the same brand, not rechargeables. Make sure that the outside station is reading a temperature and humidity first. Make sure that the outside gauge is close enough to your inside station. Having your inside station to near electrical or metal things or the outside station too far from the inside station is the most likely of your problems. To test this, once you've restarted your inside station, bring it close to the outside station and see if it's reading. Also, check the bottom right to see if your inside station has an antenna icon. If so, it's just updating from the radio station that updates your station often. Wait for that antenna to disappear from the bottom screen before trying to figure if your outside station is reading correctly. Finally, make sure that you have the right time zone, state, and city programmed into your inside station. If none of these work, call or e-mail the link in your book. Hope this works.
Dec 28, 2009 | Discovery Channel Toys
I want to use the text messenger (Discovery
We dont have the instructions but I know how to use them:
Press the on/off/mode button to turn on Have one of the texters on "recv" in order to receive a text  The other texter will be the one sending  To send first press chat Next press send  Now you can type your message  When you are done typing you message press the send button again After you press send it should say P/I When this comes up press the call button (THE ONE WITH ICQ UNDERNEATH IT)  Now your message should come up on the other texter instantly  You can repeat this back and forth between the two texters
Dec 05, 2009 | Discovery Channel Discovery Pink Slide and...
VIDeo CARD not working
You will need drivers for the FX5000 first, disable the driver for the one your using, shut down and then install the new FX5000, boot up and wait until the VGA comes on, it can take several mins sometimes.
Sep 26, 2008 | EliteGroup P4VMM2 Motherboard
Sport & Outdoor - Others Logo
461 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
