Question about Whirlpool GS460 Gas Kitchen Range
Neither the burners nor the oven will light. When turning the knob to light there is no clicking sound, however, I do smell the gas. We can light the burners with a flame because the gas is there. Should I call the repairman or the gas co? Thanks for your help. Shelley Bowlen
  • 494 Answers
Before you call a repairman, you first need to decide if the problem is isolated to just the gas stove. Have you tested all your other gas appliances (wtr htr, furnace, etc) to make sure they are operating? If not, call your gas co. If they are working fine, then check your breaker box and check to see if the stove breaker is tripped. If it's fine, then try plugging it into another electrical outlet using an extension cord and see if you get power. If not, then call an appliance repairman for the stove. Douglas
Posted on Sep 12, 2010
How to light oven pilot
When the oven control knob is in the off position(vertical), turn it counter-clockwise to the next position. This is the oven pilot light. Push the knob down, and while holding down, push the red piezo ignitor button located behind the bottom plate under the oven door. This little door swings open top down, like the oven door. Push the ignitor repeatedly, while holding the knob down. If it doesn't light, or you smell gas, let it dissipate before trying again.
Jun 13, 2014 | Star Tri-Tsr-6 36" Gas Heavy Duty 6 Burner...
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Oven is slow ot light and has a gas smell when
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 21, 2010 | Kenmore Ovens
Mid 90's Magic Chef gas stove
hi there,
since you can smell gas, you have a gas leak. i would recomend checking and cleaning the gas valves. if you can hear sparking, that means it's just the valves. sometimes cleaning the rods will fix the problem.
Oct 10, 2008 | GE JGRP17 Gas Single Oven
Oven
Hey ascollins217
This is normal with a gas range. The oven is lit with an ignitor (the glowing that is seen) - it glows first then the gas comes on and lights up shortly afterwards. There is no clicking sound for the oven (at least not for the model you have)
Regards
Sep 06, 2008 | Frigidaire FGF316 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Only one burner of four not working
sounds like a bad switch in the knob, turn on the defective side, turn on the one that works and keep the clicking going then turn on the defective burner while "other" is clicking if this lights then it means you have a bad switch or loose connections
May 31, 2008 | GE JGBC20 Gas Kitchen Range
Oven and stove do not lite and display is black
sounds like a power problem .. I would first check the cord and ther terminal black if ok then I would go to the control... there is ware I would start..
Mar 31, 2008 | Tappan TGFS_63 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
226 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
