Question about Polaroid FLM-1911 19 in. LCD Television
Hooked up tv in my daughters dorm room and had the tv scan for channels. After scan, it will only show channel 1. No other channel can be accessed.
  • 333 Answers
SOURCE: can't get all cable channels
Chech with you cable company to see if they switched to the higher chanels. I do not know if you are connected directly to the antenna or a cable box.
Posted on Nov 28, 2008
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Posted on Feb 20, 2009
rulds2008
  • 3866 Answers
SOURCE: I have a Polaroid TLA-01911C. I switched from
Ether the antenna is not good enough for the digital signals that are now brodacasted or you got a bad digtal tuner in this unit. i would buy a antenna from radioshack special for this TV.
Posted on Jul 18, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
  • 136 Answers
SOURCE: I am still trying to scan the air channels, I am
Sure your audio Isn't set to SAP?
Posted on Aug 08, 2009
My TV picture is not coming in and neither is all my channels.
Perhaps you have the TV set to receive analogue TV rather than digital (DBV). Consult the manual about receiving a digital signal.
Jan 21, 2014 | Sansui 19 in. LCD TV
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
I just moved into my college dorm room and got the tv all hooked up to my cable outlet, but n=my channels dont show up. is there programing i need to do to make it happen?
Yes,Used ur tv remote.Push the button said Menu.Go into ur tv MENU go to SETUP go down to Ch.setup or something like that on down to all the option of the SETUP menu.Look for 2 words like AIR or CABLE.Pick CABLE if ur college dorm offer pay tv services.Press the Enter button to scan for pay cable channels after it done scanning for channels tv should have picture and working.
Aug 17, 2011 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Hooked up the tv to my existing cable and it will only receive 15 channels. All my other tv's receive many more like 100 +. I did the auto detect when I hooked up the tv and 15 is all it detected.
This is a fairly common issue, either the TV has the upper channels blocked or the signal in that room is just not as strong so a quick scan is passing them over. I will give you the steps to remedy both issues. If the channels show up weak or snowy or not at all after trying these steps you may need to install a booster where you current line splitter is but try these steps first as the TV can easily compensate for a slightly low signal.
Enter the TV Menu, Select TV, Select Channels, Select Master List. Look for channels with X beside them, if they have X they are blocked, simply move down the menu selecting each one to remove the X.
Now that you have verified or corrected your master list select Turn on Additional Scan from the scan menu and run a new scan. The additional scan will take a lot longer but will take more time on each channel and should find them even if the signal is a little low.
Hope this helps FixYa,
Chris
Jan 04, 2011 | Vizio M220VA 22 in. LCD HDTV
Disney princess tv won't show all channels
HI,TRY THE AUTOCHANNEL SCAN FEATURE,IF USEING A INDOOR AERIAL YOU WILL NOT PICKUP ALL CHANNELS,HOPE THIS HELPS THANKS.
Dec 26, 2008 | Televison & Video
Problem with my ltv-19w6 flat screen TV
hi your tv will  not show picture if there is no cable or antenal connected insted it will show u the blue back baground
Sep 29, 2008 | Westinghouse LTV-19w6 Television
TV will only show Air Channels
TRY HOOKING THE CABLE DIRECT INTO THE TV AND TUNNING IT AGAIN.
Dec 12, 2007 | Durabrand DWT2405 24" TV
Sharp television without remote
should be able to go through on the tv unit itself to auto search the channels, i've done in numerous times for friends in dorms who lose their remotes or don't know how to reprogram for the new cable channels. it should be on the tv by the channels and volume buttons.
Oct 09, 2007 | Sony RM-Y133 Remote Control
Polaroid FLM-1911 19 in. LCD Television Logo
22 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
