Question about Fisher and Paykel DG05 Gas Dryer
Its making a scrapeing sound when its tumbling . it seems the front of the drum is rubbing .
Sounds like it needs the slide bearings replaced. They are usually semicircular slides that the drum rides on made of neoprene or some other high impact plastic.
Posted on Sep 12, 2010
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 30, 2014 | Fisher and Paykel DEGX2 Dryer
The tumble dryer is making a scraping noise
The front 'bearing', a felt bearing, is wearing out. Mine continued to work for years after I first heard the noise.
Thanks for visiting today.
Dec 31, 2010 | Dryers
My Maytag dryer (model # MDE4806AYW) makes a grinding sound all of the sudden. Sounds like the cylinder drum is scraping on something. The dryer is only a couple of years old. What do you think needs to be...
Could be your front glides on your drum housing. They are just Teflon pads that the front of the drum rides on. If they wear down you will get a metal on metal rubbing. The part number is 40116501. The other possibility could be your rear rollers going bad but they usually will make almost a squeak usually. They are what support the rear end of the drum.
Hope this helps _MJ_
Jan 29, 2010 | Maytag Dryers
DRUM MAKES NOISE WHEN TURNING ALMOST LIKE IT'S RUBBING AGAINST SOMETHING INSIDE THE MACHINE. SOUNDS LIKE DRUM IS TRYING TO STICK AT SOME POINT OF ROTATION.
check that all the support springs are connected and one is not broken. It is also possible that something is between the drum and the frame.
Sep 26, 2009 | Dryers
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Whirlpool Dryer making a rubbing or jingle noise when running
there are wheels under the drum to support it take the front panel off and check those
Jun 24, 2009 | Whirlpool GEW9200L Electric Dryer
Ge dryer started making a loud rubbing sound
Sounds Like the drum is scraping. You can remove the drum and inspect the felt bearing/gasket for damage or a coin or screw that got lodged in it. You will need to remove Top and front in order to remove drum Carefully note the routing of the belt near the moter.
Jan 23, 2009 | GE DCSR483EA Electric Dryer
Noisy "rubbing" sound...
it may need a good lubrication job. look for all rolling parts metal or plastics and give a good dose of WD-40 and observe. ba particular to the bushing of the drive motor, the roller and the center bearing that hold the drum.
Feb 17, 2008 | Whirlpool GEW9250 Electric Dryer
Fisher and Paykel DG05 Gas Dryer Logo
202 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
