Question about Brother Sewing Machines
My machine keeps bunching underneath why - Brother Sewing Machines
    Genius:
  • 1,788 Answers
Totally rethread your machine, your top threading is wrong or thread is tangled. Sometimes the needle is bent or has a burr, use a new needle.
Posted on Sep 12, 2010
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
Brother pe180d thread bunching up underneath
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin is turned the right way
make sure the thread has not come off the thread take up lever
if the machine continues to see bunch thread underneath then the
machine may need to be checked to see if some part has become
damaged or out of alignment
Dec 02, 2012 | Brother Disney PE-180D Computerized Sewing...
Thread keeps bunching on the bottom of the material when I sew. Have a Singer Futura 920
Generally bunching underneath is related to the top tension. Check your tensions - you might have to fiddle around a bit to get it right
Feb 28, 2012 | Singer Sewing Machines
The thread keeps bunching up underneath top looks good but bottom stitch is bunching up
Totally rethread and put in a fresh needle. It should work wonders, if not go to brother-usa.com and troubleshoot
Sep 06, 2010 | Brother Sewing Machines
I have a pfaff 2040 tiptronic and the bobbin thread keeps bunching up and stopping the machine
Here are a couple of solutions to try.
* Re-thread your machine, it may be threaded incorrectly.
* Raise your feed dogs if your machine has this feature.
Note: When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Dec 22, 2009 | Sewing Machines
My singer 533 machine keeps bunching up with
Top tension about 4 or 5, make sure the bobbin turns anti clockwise, make sure you only use a mercerised thread no thicker than a number 40 and the bobbin thread should pull through with slight resistence only.
Oct 27, 2009 | Singer Sewing Machines
How do I keep bobbing thread from bunching on model 375?
upper part of machine not threaded correctly - no needle tension = bunching underneath
Apr 22, 2009 | Euro-Pro 373 Mechanical Sewing Machine
Thread bunching on model singer 2157C
According to everything I've researched, when this happens it's because there is no tension. Check & make sure it's threaded properly. If it's still bunching underneath, then there may be something wrong inside the machine - even though you adjust the tension, it may not really be happening inside. You'll have to take it apart or service it.
Aug 29, 2008 | Singer 2517 Mechanical Sewing Machine
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
