Question about Toshiba Computers & Internet
Satellite pro200 power light comes on then nothing happens both on battery and mains adaptor
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Toshiba l875d-7332
try doing the hard reset; remove battery and ac adaptor and press the power button for 30 sec; after that reseat the battery and the adaptor and power up the laptop.
let me know if that is working for or not.
Feb 08, 2014 | Toshiba Satellite L875ds7332 Notebook...
Charges but lights flicker when trying to turn on then lights turn off and nothing happens.just bought new charging cord oem.
Not all oem's are created equal, this sounds like a power supply issue. I would be tempted to try another power supply, first remove the main battery and press power, if it comes on the rechargeable battery is bad, replacement only option.
May 03, 2012 | Toshiba Satellite A105-S4284 Notebook
Toshiba wont power on
Remove the main battery and try again, if no change! sub out the ram memory one at a time and power on each time. If still no result! the onlything left is the motherboard with major issues.
Apr 26, 2012 | Toshiba Satellite L455DS5976 Notebook
Led light not working display is dull
Maybe you have a power problem.
Do you have Power light and Charge light?
First of all try removing the battery and running from the ac adaptor, assuming your adaptor is OK.
Without knowing what has happened leading up to this fault, I am at a loss to suggest anything other than a possible Motherboard fault.
Hope that helps.
Dec 09, 2010 | Toshiba Satellite L500 Series Notebook
My dv7 1245 dx had a short at the ac110 adaptor plug on the 18.5 volt end. This shut my computer down. Twisted wires. I bought a new HP adaptor. The computer will not power up now. The only sigh of life...
Dear Sir/Madam...
You just follow these steps:
1.Remove the battery and Adaptor
2.Press and Hold the On buttun for 30 seconds (without battery/adaptor,this is for reset the BIOS in your Laptop)
3.Now you just connect the adaptor with your laptop
4.On the adaptor socket main switch in main board
5.Watch the Laptop charging Light is ok or not.Also watch the Light in Adaptor is lighting normally or not.if all are normal then try 6th step otherwise problem in your Laptop.Just go for an authorised service center.
6.Try to ON the Laptop
All the Best....
thank you very much By Ganesh(INDIA)
6.
Dec 04, 2010 | HP Pavilion dv7-1245dx Notebook
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
90 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
