Question about Tecnik TKL9260 Front Load Washer
I washed a bathroom rug in my Maytag Neptune and it seems to have disintegrated in the machine and now it won't drain or spin. How can unclog it myself?
    President:
  • 1,554 Answers
Please indicate the exact model of the machine for specific advice as there are two types of Maytag Neptune washers; one is a top loader and the other is a front-loader. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions should you need further assistance. But accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 12, 2010
  • Jahn27
    Jahn27 Sep 12, 2010
    Unplug the machine. Remove the rear access panel to access the pump then depress the locking tab on the face of the pump housing. Rotate the block portion of the pump containing the motor windings toward the front of the washer to disengage the locking tabs of the pump housing from the pump face then carefully remove the pump body away from the housing. The drain impeller is now exposed for cleaning.
On a Maytag Maxima XL front load washer, please tell me on what cycle to wash a bathroom rug. zo vs
the heaviest cycle there is . but it sounds like the control board is not advancing the timer if it sits that long on one thing perhaps a call to a repairman is called for .
Jun 22, 2015 | Maytag Neptune MAH5500B Front Load Washer
How do you unclog drain on washer so it will drain again?
You need to open the water pump to see if it is clogged with any thing causing the obstruction for not draining.
Jun 09, 2014 | Maytag MAH8700A Front Load Washer
MAYTAG NEPTUNE WON'T SPIN OR DRAIN
If it can't drain, it shouldn't spin. Pump blocked? Broken pump? Level sensor broken?
Sep 05, 2012 | Maytag MAH6700AWW Neptune Front-Load...
My washer will not drain . I washed bathroom rugs that fell apart leaving excess fibers that I beleive plugged up the holes that allows drainage. A few gallons of water is still sitting in my washer and...
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
WASHED RUG IN MY NEPTUNE WASHER. rUG CAME APART. washer won't drain all the way. ND COMES UP.RUG WAS SHAG TYPE.hELP!
You will have to clean up drain system in washer. Get the rug pars out. A wet vac is a useful tool here.
May 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage Neptune Model #MH5500BWW will not drain
I removed the pump and removed thread from a rug that had been washed the day before. The thread had bound up the pump preventing it from turning. Once the thread was removed and the parts put back together the machine worked perfectly.
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Itis a 'no spin".
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Oct 18, 2006 | Magic Chef CAV2000 Top Load Washer
Itis a 'no spin".It washes, drains, then it rinses, bypass spin to off.
Tecnik TKL9260 Front Load Washer Logo
Top Tecnik Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Tecnik Washing Machine Expert? Answer questions, earn points and help others
