Question about HP Officejet 5780 Printer
How do I insert printer cartridge
Having just bought the HP 5780 I don't understand how one inserts the
printer cartridges 350 and 351. The diagram is not very clear at all.
Just push them in horizontally ie. completely straight. You have to push pretty hard - just make sure you don't overdo it - until they go no further.
Posted on Oct 18, 2008
Inserted 95 (color) ok but having trouble inserting 95.
Please specify what "trouble."
If you try another cartridge - including the old one - does that work, or have exactly the same "trouble", or what else happens, please?
Best wishes,
Robbie
Mar 19, 2015 | HP Officejet 6310 All-In-One InkJet...
Am having difficulty removing Black (96) print cartridge from an HP 7210 All-in-one printer/scanner to enable installation of a new (96) cartridge and need help!
on the software on your PC there was a option in the printer setting>> preferencess>> maintenance, which you can select the ink/cartridge replacement..
Jun 25, 2008 | Office Equipment & Supplies
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
How do you place cartrige in printer
Step eight: Install the cartridges
  1. Raise the top cover of the product. Figure 5: Raise the cover c00830210.jpg
  2. Remove the new cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 6: Remove the tapec00442146.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00442147.gif
  3. Slide the new cartridge forward into the empty slot. Then gently push the upper part of the cartridge forward until it clicks into place.
    • Slide the tri-color cartridge into the left slot.
    • Slide the black or photo cartridge into the right slot.
    Figure 7: Insert the cartridgec00830211.jpg
  4. Close the cartridge door. Figure 8: Close the cartridge doorc00830212.jpg
Aug 08, 2010 | HP Officejet 5780 Printer
My printer error says: Color cartridge inserted is not intended for use in this printer
That printer is intended to use the HP 95 and HP 97 cartridge. If anything other than these are inserted then it will not operate. Check to be sure your color is one of these two. If it is then you should take that cartridge back to where you bought it and get it exchanged or contact HP.
Mar 18, 2010 | HP OfficeJet 6210 All-In-One InkJet...
I have a C8180 photosmart HP aLL IN ONE PRINTER. i GET CODE 0XC18A0105. WHAT TO DO? perhaps I get punished because I did not use HP cartridges?
The printer is effectively rejecting one or more of the cartridges that you have put in the printer. However, this could be a result of having a defective or incorrectly set chip on one of the cartridges. The best option is to insert some different cartridges, preferably HP and make sure that the printer has white A4 paper inserted when you initially switch on so it completes the registration process without error.
Sep 25, 2009 | HP Photosmart 8250 InkJet Printer
Cartridge error - printer doesn't recognise cartridge inserted.
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 24, 2009 | HP Officejet 6310 All-In-One InkJet...
How to insert ink
you mean ink cartridges?
Remove the tape from cartridge.
Caution: Do not touch the copper-colored contacts of the cartridges. then hold on the top HP logo. Insert it (tri-color cartridge- left slot)-(Black cartridge- right slot) make sure you push the cartridges firmly until they snap into place.
see your manuals dear, you have it with your printer u bought.
Aug 02, 2008 | HP Office Equipment & Supplies
Open Questions:
See all HP Officejet 5780 Printer Questions
HP Officejet 5780 Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
