Question about Panasonic Viera TH-50PZ85U Plasma TV
My tv panasonic viera tx p42s20b its working ok from the morning after 7 hours and less its turning off by its self ifen when i am using controler remote and red light is flashing shouing up and disapiring and I cant turn the tv on again till the next morning I try everything I plug out the tv for 20 minits and plug it back tv start working gren light flashing its showing the screen but after 5 secconds its going off and i still cant turn it on till the next morning please help because tech enginers want to take my tele for couple weeks to lab for check up and that is not good option for me help help
    Top Expert:
  • Panasonic Master
  • 74,634 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. ..
Posted on Apr 08, 2017
5 Suggested Answers
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
Jay_Sav
  • 93 Answers
SOURCE: Panasonic Viera 42" TV won't tun on
This problem happens when you connect a DVI-HDMI input to the back of the set. It can happen other ways too though. Press and hold your power button, which will reset the unit to it's factory defaults, and should return it to normal use.
Posted on Mar 05, 2009
djchillsnyc
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
  • 43 Answers
SOURCE: Panasonic Viera TX-L32X20B no channel found
the problem looks like bad main board , try to do the auto program , and see if it works , if dont work main signal board need to be replace
Posted on Feb 07, 2012
Panasonic tx-48cx400b TV turns off when I connect my Ps4 through hdmi cable. Can anyone help?
Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model ...
www.amazon.co.uk > ... > TVs
Amazon.com, Inc.Buy Panasonic TX-48CX400B 4K UHD 48 Inch TV (2015 Model) at Amazon UK. ...PRO GOLD RED HDMI v2.0/1.4a HDMI Cable 3D 2160p PS4 SKY HD 4K Ultra HD ...This tv offers excellent picture quality through HD sources and Netflix HD and ... TVand PC are both connected to my network switch with Ethernet cables).
for LED TV VIERA TX-48CX400B - Panasonic
www.panasonic.com/uk/.../viera-televisions/.../tx-48cx400b.ht...
PanasonicExplore the Panasonic TX-48CX400B - LED - Uncompromising 4K picture quality is yours with this 4K Ultra HD LED TV featuring an HDMI 2.0 terminal. ... Many describe the 4K effect as feeling more like looking through a window than watching ... Simplyhook up your various devices - such as a Blu-ray recorder or the latest ...Missing: turns ‎ps4
Panasonic VIERA TX48CX400B ' 48 inch 4K Ultra HD 3D ...
Dec 26, 2015 | Panasonic Televison & Video
Panasonic TX-P50G20B How to connect Panasonic Viera TX-P50G20B with Windows7 as a media server. The G20 is connected to the network, Viera Cast is working, I can also ping the g20 from my PC. When...
You need to run a DLNA server on your Windows 7 PC, I recomend using a program called Serviio: http://www.serviio.org/
Simply download and install, select the folders that you want view on your TV and you should be viewing your films and pictures in no time.
Mar 08, 2011 | Panasonic Televison & Video
I can connect my laptop to a monitor and it works ok. When I connect to the Panasonic TX-L32S20BA tv in the same way (through the PC input) and select PC input I don't get a picture. Any suggestions?
Hi
Before connecting it to your Tv try to turn down your resolution settings on your laptop to 680 or something, Maybe your TV does not support the resolution your laptop is in at the moment.
Feb 02, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Hi I have a Panasonic VIERA TX-32LZD80 32 in. LCD TV TV which will not turn on. The standby light will flash continuously, but will stay on red if I press on the on button using the remote. My TV is...
BECAUSE THE QUESTION WAS ASKED BACK IN December 8, 2010, it is more likely that he has moved on. Anytime you have a product UNDER WARRANTY, USE IT OR LOSE IT. THINGS HAPPEN. DEVICES FAIL.
Dec 08, 2010 | Panasonic VIERA TX-32LZD80 32 in. LCD TV...
Cannot remove input label from Panasonic Viera's screen
Are u using HDMI/1 hook up HD box and signal?The HDMI/1 port still work?Do u use the device in the HDMI/1 port lately dose it work?Replaced the HDMI cable,Unplug the tv about an hour,plug it back in,reset it back to factory setting again.See if this work,not than ur HDMI/1 is shorted.
Mar 23, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Sep 10, 2009 | Panasonic Televison & Video
Code
Hi
I have a Panasonic viera TX-32LMD70 TV and a Panasonic
remote control. I also have sky and I cant use the sky remote
control for the sound when I try to change it asking for the code
and I do not have any for the panasonic remote how came with the TV when I bouth it. Can you help me.
Thank you
Gill Plimmer
Aug 18, 2008 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panasonic Viera TH-50PZ85U Plasma TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
