Question about HP LaserJet 2430dtn Printer
Printing a smudged black line on all pages
Our printer seems to have the same problem as previously posted by another user. It's leaving a black line down one side of all pages. We've recently changed the toner cartridge and have cleaned the inside and ran cleaning pages. What is a fuser and how do I replace it? Is it something we can replace on our own? Can you point me to a website?
Any help is greatly appreciated.
  • 300 Answers
Instructions to replace the fuser
1 Remove the back cover and io cover
2 Remove the fuser cable cover by releasing the tab on the cover, then rotate the back of the cover towards the centre of the printer
3 Remove the duplexer inlet guide by releasing the 2 tabs on the guide, hen slide the guide towards the back of the printer
4 Disconnect the 2 cables at the left inside the printer
5 Discounnect the fuser cable at the right side of the printer
6 Remove the 4 screws holding the fuser in place
7 Tilt the fuser towards the back of the printer, then slide the fuser out.
This really is quite simple to do.
Posted on May 17, 2008
My HP LaserJet 2430n prints black smudge lines down the left side of the page. How can I correct this?
check the fusing unit in the rear of the printer and check your print cartridge for smudges.
Sep 28, 2009 | HP LaserJet 2430dtn Printer
I'm getting black smudge marks on copies. After
I also had this issue, waste tone was comming from the transfer belt, had a good clean out been good for months now.
Aug 11, 2009 | Samsung CLP 300 Laser Printer
Lexmark E232 - BLACK SMUDGING on sides of print
try replacing the toner cart. or toner leaked on the area below in which case you will need to blow it out.
Jun 04, 2009 | Lexmark E232 Laser Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Mar 01, 2009 | Office Equipment & Supplies
Canon PIXMA MX700 printhead immediately coated with ink, smudges
It's likely that the foam pads that the print head rests on when the printer is not in use are saturated with ink. They're to the right as you look into the printer: a rectangular one for black ink and a square one for the colored ink. If you power the printer off and back on, with the cover open, you'll see where the printhead goes to rest.
The pads aren't easy to get at, but you can blot them with a paper towel. Gummy, half-dried ink dissolves in rubbing alcohol, and you can soak a paper towel or a cotton ball with alcohol and wipe down the area. I've had good luck soaking the pads with alcohol, then blotting them dry with a rag.
Feb 18, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black ink smudges for color print mode only, not for grayscale
- Try to reallign the cartridge, run a print test, after that if the issue still persist - uninstall and reinstall software - run test and re-allign again the cardtridge using software. run print test again.
Oct 08, 2008 | Samsung CLP 300 Laser Printer
Color lines/dashes at top and middle of page when printing.
Amand321,
Your problem lies with the fact that you manually refilled your cartridges. This is not recommended by any technician I know and your solution is in the replacement of all your cartridges with genuine brother consumables. It is going to be expencive, but it is the only real solution.
Gremlin11
Sep 29, 2008 | Brother MFC-9420CN All-In-One Laser...
Xerox Phaser 8560 mfp Printing issue
That really sounds like you need to replace the maintenance kit.
The white roller most likely is black and has depleted itself of lubricant a bit prematurely.
May 21, 2008 | Xerox Phaser 8560MFP Laser Printer
Colour smudges
try cleaning the print head and also see this post on the photoconductor
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Jan 23, 2008 | Epson Aculaser C1100 Printer
HP LaserJet 2430dtn Printer Logo
196 people viewed this question
Seeker5211
Seeker5211
