Question about Garmin GPS
When I connect my GPS to my computer to charge the battery, do I need to turn my Garmin unit on or will it charge without being turned on. Also where will I get a replacement battery to keep on hand
  • bscoular Sep 15, 2010
    Yes; my GPS problem was resolved successfully.
    Many thanks
    Brenda Scoular
    President:
  • 1,554 Answers
You can charge your device either on or off as long as the computer is on. You can purchase a spare battery here.
Posted on Sep 12, 2010
I have a nuvi 265w garmin. It turns on and then turns off without loading the map
The GPS battery may need to be charged.
Does the GPS turn on when connected to a vehicle power cable?
Running the Garmin WebUpdater to load or reload the latest software will usually fix any bugs.
Contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 23, 2012 | Garmin Nuvi 265W GPS Receiver
Just bought Garmin 1300 series unit. Need to charge batteries. Can I do this by using my computer or do I have to use car battery?
You can charge it with your computer if you wish. It will take about 8 hours with the computer compared to 4 hours with the car charger. To charge it with your computer just connect the satnav to your computer with the mini USB lead. The computer and satnav must be both turned on.
Jun 12, 2011 | Garmin Nuvi 1300 GPS Receiver
I have a computer and i want to know how do you charge it to a computer
If you want to know how to charge your GPS unit using your computer you can do this by simply connecting your GPS to your computer using the USB cord that should have been included with your unit. It will be a black cord with one end that should fit a USB port on your computer, and the other end will attach to the back of your GPS. Turn off your unit, then plug the smaller end into the GPS and the larger end into a USB port on your computer. Your GPS should then come on by itself. Your normal Garmin startup screen will display, and it will also display that it is loading maps. Then a graphic of a computer connected to a GPS will show on the bottom of the screen, and a white line the width of your screen will slowly change to green. The entire time you are connected your GPS will be charging. Depending on how much of your battery needs to be charged, leaving it connected for about an hour and a half should give you a full charge.
Mar 06, 2011 | Garmin nuvi 200W GPS Receiver
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205W GPS Receiver
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
Apr 16, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 255W
No, it may take a little longer if you are charging through the USB port. I normally have mine plugged in while driving, it charges and is in use too. To use GPS with USB. First turn the GPS on (without USB plugged in). Press Battery symbol on screen for about 10 seconds, a test screen will come on. Plug in the USB (bottom of screen shows USB connected). Tap EXIT to return to maps. You can now use it while USB is charging Make sure you turn GPS off before removing the USB cable
Apr 08, 2009 | Garmin nuvi 255W GPS Receiver
Garmin 2005 will not charge, new in November of
Make sure the internal battery is charged by connecting it to your computer with the included USB cable. Make sure the computer is on and running. Let it charge at least a couple of hours and then try to turn the GPS on while still connected to the computer. If the unit still will not turn on you might need to return it to Garmin.
Apr 03, 2009 | Garmin nuvi 250W GPS Receiver
Garmin nuvi 200 pick up charger as a usb cable
The problem is very simple... The GPS unit perceives whatever you plug in depending on the power supply figure.
If you car charger is not giving enough power, then the GPS perceive the cable as being connected to a pc.... thus not charging. Check with an car electrician if you can raise the power supply on your car...
Nov 24, 2008 | Garmin nuvi 350 GPS Receiver
No power to garmin c330
Does the unit turns on while pluged into the computer? If the answer is yes, then you will need to replace the battery. The battery is not taking a charge.
Jun 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
104 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
