A spectra model 642 T doesnt work, the light is on but nothing happens
Just finished driving car, tried to start it back up and nothing happens. Radio works fine, lights come up but car won't start.
if starter is not engaging or clicks then have battery load tested. if battery checks good then test the voltage draw on the starter,may be dragging when it gets hot.
Jun 03, 2012 | 2002 Kia Spectra
My car 2001 spectra kia is stuck on Parking it wont move to D. it start and everything seems fine but doesnt want to move from p
check to see if your brake lights are working .if not look for blown fuse or brake light switch or bulbs their should be a override slot or procedure to release from park.release solenoid is not working.
Jan 25, 2011 | 2001 Kia Spectra
Kia spectra 2005 problem starting turn car off next it will not start sometimes it maybe week or longer before it will not start no problem once it starts
check for corrossion at the battery posts, greenish/white powder. clean it off and reconnect the cables. If the corrossion travels up into the cable, you may want to replace it.
Jun 16, 2010 | 2005 Kia Spectra
Power light is flashing red and nothing happening
Most of the people having this problem had to replace a blown capacitor C316 (1000uF/10V) on the power supply module. You can read step by step instructions at:
http://club.cdfreaks.com/f114/philips-dvp-642-37-power-problem-180909/
Hope this helps
Jul 15, 2009 | Philips DVP642 DVD Player
Front 2 burners wont light on ovenrange (spectra xl44)
most of the time underneath the top there is a ignitor wire it mightb have come off or when you cleaned it you plugged up the holes
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Freezer not working on sub-zero 642 model
Remove the top grille and touch the compressor on the left, above the freezer. Is it warm, can you feel it vibrating? If not, your compressor may need to be replaced.
May 10, 2009 | Sub-Zero 642
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
GE Spectra Oven won't heat
i would def try to replace the bake ignitor. most common problem on any gas range. part problbly $75, $250 for someone to install one
Feb 28, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
