Question about Sony Ericsson K800i Cellular Phone
Backup during process
How did you backup your phone when trying to sort the turning on issue? I have downloaded a back up programme but to connect the phone to it i have to switch it on and thats the original issue to be resolved?
    Brigadier General:
  • 7,752 Answers
Well that is not going to work at all then.
Posted on Jun 08, 2008
I start to back up and then it stops
backup need to drive without any other programmes, other programmes may disturb the backup-process.
Mar 27, 2012 | Computers & Internet
Tip
Nokia Firmware Updates
Hello, this is a tutorial explaining which steps you should follow in order to perform a firmware update or "Flash" on you mobile phone.<br /><br />What you will need to do this Procedure:<br /><br /> <ul> <li>USB data cable</li> <li>Nokia PC Suit</li> <li>Nokia Software updater</li></ul>In this tip the link for both PC suit and Updater will be provider for download.<br /><br /><img src="lock123.jpg" /><br /><br /><span>Step 1:</span><br /><br />You will need to <span>backup</span> all the data on your phone before you start doing anything else. You can either do the backup by following either the steps below:<br /><br /> <ul> <li>If you have a memory card in your phone, you can do the following: Tools&gt;Memory select options&gt;Backup phone memory. Once the backup is complete, remove the memory card from the phone.</li> <li>You will also be able to backup your phone using Nokia PC Suit. Once you have installed it, you will need to connect your Phone to your computer using the USB data cable. Once the phone and the computer is connected, you will have an option to backup the phone data.<br /></li></ul>At the links below, you will be able to download Nokia PC Suit and Nokia Software Updater.<br /><br /><a href="http://europe.nokia.com/support/download-software/nokia-pc-suite/download">Nokia PC Suit</a><br /><a href="http://europe.nokia.com/support/download-software/device-software-update">Nokia Software Updater</a> (To download the correct version for your phone, you will need top select your phone model)<br /><br /><br style="text-decoration: underline;" /><span>Step 2:</span><br style="font-weight: bold;" /><br />Before you start the actual firmware update, you will need to charge your phone, to ensure that the phone will not disconnect during the updating process. If the battery does not have the sufficient charge, the process will not start.<br /><br /><br /><span>Step 3:</span><br /><br />Since Nokia PC suite is already installed, you will now need to install Nokia Software Updater. Once the install is done, you might need to check your Firewall settings to ensure that there will be no data blocked or filtered during this process. Click <a href="http://www.microsoft.com/windowsxp/using/networking/security/winfirewall.mspx">HERE </a>to see how to set firewall settings.<br /><br /><br /><span>Step 4:</span><br /><br />From now on it's really simple, just follow the guide and you'll be fine. The whole updating process takes several minutes to complete, don't try to cancel it in the middle in any case, your risk damaging your phone. You will need your USB cable in this step.<br /><br /><img src="lock123_0.jpg" /><br /><br /><span>Step 5:</span><br /><br />Lastly you will need to restore the backed up data once the update is compete. Again, this can be done in two<br /><br /> <ul> <li>if you used a memory card for backup then you simply go to the <i>Tools</i> - <i>Memory</i> select <i>Options</i> - <i>Restore from card</i>; if you used Nokia PC Suite you have to connect your phone to the pc via <span>USB</span> cable, select Backup and Restore</li></ul>And then you are done.<br /><br />I really hope this can be of help. Please feel free to share your thought and advise.<br /><br />Kind regards<br />Lock123<br /><br /><br />
on Dec 10, 2010 | Cell Phones
How to backup e 63
You need to have a Nokia PC Suite on your computer to backup your stuffCreate a backup file1-Open the main window of Nokia PC Suite and select Backup application.
2-Nokia Content Copier offers you two options: to back up your device or to restore a backup file to the device. To back up your device, select the Backup button.3-Select the content types you want to back up and continue by selecting Next.4-Nokia Content Copier suggests storing the backup file in the default folder. To choose a different folder, select the Browse button.5-Select Next to start backup.6-During the backup, a progress indicator helps you keep track of the process.7-When completed, all the content included in the backup file is shown. A yellow triangle indicates that certain files cannot be backed up (e.g., because of copyright protections).8-To view more information about the completed backup process, select View the report.
Hope this helps you. Ready your cellphone's manual for more information.
Oct 01, 2011 | Nokia E63 Cell Phone
Blackberry mobile has error102 on screen
You need to reinstall your device OS to regain access to your device.
Check steps below for OS upgrade -
Before starting make sure that BlackBerry Desktop Software is installed on the computer.
Make sure that you have installed updated device software installed in your PC. Check this link to get update device software from carrier OS download site.
Users can perform a full or selective backup of the data using the Backup and Restore tool in BlackBerry Desktop Manager by completing the following steps:
  1. Connect the BlackBerry device to the computer running BlackBerry Desktop Manager.
  2. Open BlackBerry Desktop Manager.
  3. Double-click Backup and Restore.
  4. Select Backup to perform a full backup or select Advanced to perform a backup of specific databases.
  5. Choose a location to save the backup file, then click Save.
To perform a clean install of the BlackBerry Device Software, perform the following steps:
  1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
  2. Double-click the Application Loader icon.
  3. Click Next to start the installation process.
  4. Type your BlackBerry smartphone password, if prompted, and click OK.
  5. Click the check boxes next to the names of the applications you want to load, and then click Next.
  6. Click Advanced, and then click the check box beside Erase all currently installed applications.
  7. Click Next.
  8. Click the check box next to Do not automatically backup the application data during the loading process.
  9. Clear the box next to Backup and restore applications installed wirelessly.
  10. Click Next > Finish.
  11. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager.
Regards
Jun 28, 2011 | RIM BlackBerry Bold 9700 Smartphone
I have an HTC 8925 and when I turn it on, it turns on but it doesn't fully load. The only thing it shows is the ATandT logo on a white background. It does not make any sound or beep or anything in that...
Thanks for visiting FixYa!
From your explanation, it sounds like you've downloaded an app or program that has a driver conflict with the phone's operating system. You may need to flash your phone's ROM (operating system) with a new updated version to get it to work properly again. Since you didn't include who your cellular carrier is, I'm going to assume that it is AT&T. If the phone is not an AT&T Branded phone, disregard these instructions.
This phone is also called the HTC Tilt 2 (AT&T) and there is a new ROM download for the phone which should solve your problem. You'll need to follow the directions EXACTLY to flash your phone's ROM - and I do mean exactly!
This software update is intended for the HTC Tilt 2 for AT&T only and users should not load or attempt to load this version on any other device as it may cause serious issues/damage.
Please note that during the update process, the device will be Hard Reset and anything that is NOT part of the Operating System (contacts, calendar, music, etc) will be permanently deleted; always make a point of backing up your device's data on a regular basis!
Before you proceed, please confirm that this software upgrade is a newer version than what is currently loaded on your device. If it is the same version and your device is operating normally, there is no need to reload the software.
To determine the software version running on your device, go to Start > Settings > System Folder > Device Information > Software Information.
Validate that the ROM version is 2.10.502.4 if it is not, you will need to update the software on you device.
Before you run the ROM Upgrade Utility (RUU), make sure you check and do the following first:
  • USB sync cable is connected to your device and PC to establish a connection with Activesync/Windows Mobile Device Center. If you don't have ActiveSync installed on your PC already, the CD found inside your handset box can be used to install the application. If you lost the disk, please go to www.microsoft.com >Downloads & Trials> Windows Mobile Downloads and download the appropriate application (ActiveSync or Windows Mobile Device Center) depending on your PC's OS. You will also need Outlook or Outlook express installed in order to backup your contacts, calendars, e-mail, tasks etc.
  • Remove your storage card prior to running the upgrade. Do not put it back into your phone until after the upgrade process is complete.
  • The standby and hibernation modes are disabled on the computer.
  • All running applications on the computer have been closed.
  • Ensure that you device has a battery level of at least 50% (Start > Settings > System Folder > Power > Battery) If the battery "dies" during the upgrade process, there is a chance that the device will not recover and will need to be sent to HTC for repair.
  • The update can take several minutes so set aside time when you will not be interrupted.
  • Do Not interrupt the upgrade process or press any buttons on the device until the process has been completed (the device will reset itself when the update is done).
  • Warning: Installing this update will erase all data stored on the device, restoring your device to the factory default settings. Please be sure to back up any important files to preserve your data.
General Procedure on Installing the ROM Update
  1. Back up your personal data from the Mobile Device to your computer using ActiveSync (Windows XP or sooner)/Windows Mobile Device Center (Windows Vista and Windows 7) or a 3rd party backup utility if you want to ensure you don't lose any of your data.
    • If using a 3rd party backup utility, be sure that you are not backing up the Registry as this will cause issues once restored to the device after the update.
    • You will need to reload any 3rd party applications manually. Once you have created your backup file, be sure to copy the backup file to a storage card (ensure that Storage Card Encryption has been disabled on the device if you have enabled it) or to your PC before proceeding with the ROM update.
  2. On your computer, click on the Download link (below) and save the file to your desktop.
  3. Establish a connection between ActiveSync/Windows Mobile Device Center and your device using the provided USB Data cable.
  4. Locate the ROM file (the one you saved in step 2 above) on your PC and double-click on the file to run the ROM Update Utility (RUU) to install the ROM update to your Mobile Device.
  5. Follow the RUU Wizard prompts. When presented with the readme screen, please read the Readme since it provides a lot of valuable information on the upgrade process and what you can expect during the upgrade process. Check the box beside the "I understand the caution indicated above and has reviewed the Readme" and then press Next to continue. The remaining steps will typically involve checking the check box and pressing the Next or Upgrade button until the upgrade is completed.
  6. Restore your personal data back to your Mobile Device using ActiveSync/Windows Mobile Device Center or the 3rd party backup utility you selected.
Click here:
HTC Tilt 2 (AT&T) ROM Update 2.10.502.4 ' 08.30.2010 then click on: Download when you get to the HTC Downloads page to download the ROM to your PC. Then begin the install.
Apr 07, 2011 | Cell Phones
I wann update my nokia n 72 software
  1. Go to the Nokia website and download the Phone Software Updatemag-glass_10x10.gif utility. You should also consider reading the FAQ which will help you if you run into problems.
  2. Install the software.
  3. Optionally, follow the phone backup procedure below.
  4. Start the software. The initialization can take a few moments. Once the software has been initialized you should see this screen:
  5. Click Start. Plug inmag-glass_10x10.gif the USB cable to connect the phone to the PC (and choose 'PC Suite', if there's a choice of modes, as will be the case if you're using a S60 3rd Edition device). You should also plug in the power cable to the phone. Updating the firmware can use a lot of power and by plugging in the power cable you ensure that the power does not fail during the update process. If it does your phone may become unusable.
  6. Click Next. The software will try and connect to your phone and identify it. Once it has done this it will search for updates through your PC's Internet connection.
  7. If no updates are available then the program will inform you. If updates are available then you will see this screen. Tick the acknowledge box and then click Update to start the update process.
  8. The software will then download the update from Nokia's servers, before writing the update to the phone. You will see this happen in two stages. The most important stage at which the update should not be interrupted is when writing the update to the phone.
  9. Once this stage has been successfully completed you will be informed that you have successfully updated your phone.
  10. Optionally, restore your backup as discussed in the Phone Backup Procedure below.
Notes:
  • In some cases (including one of our trials) the software may report it has failed to update the software. If this occurs at the end of the process then this may not actually be the case. Reboot the phone (you may need to take the battery out) and check the firmware version. Hopefully all will be well.
  • An Internet connection is required to download the firmware update. These firmware updates can be up to 40MB in size (but are usually around half this), which is why broadband is recommended.
  • The Phone Software Update is still being tested. If it does not work first time - try again.
  • If you receive messages about being unable to recognize the phone, being unable to connect the phone, or that the connection is already in use then you should restart your computer and your phone and try again.
Phone Backup ProcedureUpdating the firmware will overwrite any information stored on the internal flash disk (C:). If you wish to preserve this information then you should back it up before updating the firmware. Information stored on the internal disk typically includes data files such as your Contact and Calendar databases, plus application configuration files (including registration codes).
You can use PC Suite to do a full backup or you can use the backup to memory card functionality included on the phone.
Using the phone:
  1. Open the Memory application (usually found in the Tools folder).
  2. Choose Backup phone memory. This will backup the contents of the internal memory to the memory card. This process can take several minutes.
To restore your backup:
  1. Open the Memory application.
  2. Choose Options -> Restore from card. Your backup will be restored. This process can take several minutes. At the end of the procedure the phone will restart.
Firmware OTA - the future?Phones using S60 3rd Edition Feature Pack 1 will ship with FOTA functionality from day one. This stands for Firmware Over The Air and will use the data connection of your phone to download software updates. This allows you to carry out the process outlined above directly from your phone. Updates are started from the Device Manager application. An example of this can be seen in the screenshots below.
Nov 03, 2010 | Nokia N72 Cellular Phone
I have JUM error 102 on my blackberry pearl phone and now it wont power up, is there a way to fix it without having to replace the whole phone?
Try to put a good battery,if it still not working flash it with desktop manager and a new blackberry firmware.
Mar 20, 2010 | RIM BlackBerry Pearl 8100
Got this Bold two days ago & it started yesterday by shutting down & then re starting but showing "uncought exception : java.lang.nullpointer.exception" about 8 times then it stops. Then theres all...
Technically speaking you should just return the phone and get a new one.
If you are feeling adventurous, you can try upgrading/reinstall the software on the device.
Here is the procedure to upgrade the software.
Step #1
Step#2
Step#3
Step#4
  7. Click Next.
Please rate this if it fixes your issue
Jun 03, 2009 | RIM BlackBerry Bold 9000 Smartphone
My phone Wants me to reset it
Try to connect to it using the desktop software. you can download this from either your service provider website or, blackberry.com If you can connect to it back the phone up using the software then reset it to factory and put the backup on phone using the same software ... it will be for pearl 8100. If you cannot connect to phone you can try the service provider to see if they can recover it. But I am guessing the software below will be able to connect to it
Here is another solution step by step:
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
But, since this has happened so many times, I have to ask myself, is it something you're doing that it causing this? I know the Red Pearls from AT&T have had issues from DAY ONE!
Jan 01, 2009 | RIM BlackBerry Pearl 8100
BackupBuddy VFS Pro supports the LifeDrive?
The readme info needs to be updated. The current readme is actually from the previous version and out of date. It should now look something like this.. (note newest info at top, previous version info underneath) BBVFS 3.1.4 New features include: + added option to backup after HotSync + LifeDrive compatibility fixes Bug fixes include: - some password letters were being ignored - fixed problem of backing up files encrypted with the built-in Security app - blank screen/crash on startup - crashes during orphans processing - no scrollbar appeared when there were more than 10 checkpoints in the list - didn't fail gracefully when trying to restore corrupted backup files BBVFS 3.1, 6.05 * Users may now select which card to backup to on devices with more than one card slot * Backup and Restore of T5 internal drive (!) is now supported * Backup of databases with records > 64K is supported, which will allow backup/restore of Photo/Videos on T3/T5/T650 and "VoiceDial" application * Advanced screen now adds new files to the backup set automatically * Wireless updating (via "About" screen) * Implemented a Palm Source Installer package * Many important bug fixes, including: Several issues relating to compression and encryption "Last Backup" being incorrectly set to "NEVER" No longer will soft-reset if no card is mounted on the T5 TUNGSTEN T5 SUPPORT This build includes further refinements to backup and restore on the T5 but we have confirmed with PalmOne that there are some issues with the T5 NVFS implementation that require a patch from to completely resolve. We recommend that all users download and install the T5 patch that is available here: http://www.palmone.com/us/support/d...ent5update.html Alternatively T5 users may want to try a program called "DBCache Tool" which you may download here: http://www.jade.dti.ne.jp/~imazeki/palm/DBcT/ LIFEDRIVE SUPPORT We are aware that this release contains some remaining issues with the new PalmOne LifeDrive and we are working to resolve them. Please contact support@bluenomad.com if you'd like to help with testing. BBVFS 3.07, 1.05 BackupBuddyVFS 3.07 is being released with preliminary support for the T5/Treo 650, although there are still some outstanding issues that we are continuing to investigate; specifically: * Power Users with a (near) full device especially may experience "out of memory" errors and/or random resets; restarting the backup or restore operation will usually allow it to reach completion. This is due to issues with the new "NVFS" file system on these new devices that developers cannot currently work around. We hope that palmOne will issue a patch to fix this, and we will continue to try and find a work-around. * Photos and Videos will not be backed up on the Treo 650/Tungsten T5.
Sep 15, 2005 | Palm LifeDrive Handheld
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
