Question about Maytag MSD2756G Side by Side Refrigerator
GE TFX22R side by side door problem
Our side by side GE refrigerator has now started to pop open the refrigerator side....held it shut walk away and a few minutes later it has popped open....could it be the gasket?
  • 1 more comment
  • Anonymous Jul 04, 2008
    My Maytag side by side door doesn't shut good, it looks as if it sticks out 1/2 inch out further than the freezer door which shuts just fine. The door gasket looks ok, I
    haven't checked the hinges for wear.
  • scastle Aug 02, 2008
    My GE TFX22R side by side freezer frig has the problem indicated. The frig side will not close properly. The gasket looks good and the frezzer side shuts just fine. We cleaned the contact points and did not seem to help. I plan to purchase a new gasket and hope that will help.
  • RileyPants Nov 26, 2008
    The fridge side has popped something on the bottom and the door no
    longer closes automatically nor stays shut. This has made the two doors
    uneven. Looks like a piece broke at the bottom of the door??????
Undo the bolt at the bottom of the fridge side and have someone hold the door level, this happened to mine over time and the doors had just became uneven. Level up both doors by refixing the bolts and see if that helps. It did for me.
Posted on Jul 04, 2009
My one is TFE22R maybe we have same problem, i found plastic ring in the botom hins broken now i,m tring to get the spare part for thats plastic ring( the ring unequal thicknes so when you open the door up make it the doors close by it self)
hendra.tjioe@gmail.com
Posted on Dec 30, 2008
  • 828 Answers
Check your product storage in the door and on the shelves. When you first close the door a negative pressure forms from the contraction of the air. When the pressure equalizes something is causing the door to push open.
Posted on Jul 29, 2008
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
My ge profile refrigerator makes popping sound for about 3 minutes before the compressor starts. This happens almost every 8 hrs.
You may be hearing ice or water dripping on the defrost heater, which would be normal operation if the refrigerator is operating okay, otherwise.
Sep 16, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
How long after plugging in fridge should compressor start ?
It should start up within a couple minutes. the electronic control board controls the compressor as well as all the other functions of the refrigerator. If the refrigerator is cold when you plug it in then it may not start right away but opening the doors for a few minutes should get it to start up. If it doesn't come on after a few minutes the control board may have issues.
Aug 15, 2014 | GE Profile¿ Arctica® Energy...
Fridgedaire Upright Freezer Door won't stay shut. Normally when closed, you hear the seal take place, now it pops open
Check the seal in the corners on the side of the door your hinges are on, ya may need to tack it down with crazy glue, but usually it'll curl in the corners preventing door from closing or pop open after you walk away
May 06, 2011 | Kitchen Ranges
Freezer door pops open about 1/8" when you shut refrig door
this is very normal this means that you have an extremly good seal .. causing air to push threw duct work when closing door .... try changing the levelnes of refrigerator so when door does pop open it falls back closed meaning tilt fridge front higher than back of fridge
Feb 01, 2011 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Freezer side door not locking shut
Mine has been doing this for over a month. Then on Friday it started making a clicking sound a CONSTANT clicking sound. I get home from a marriage retreat for families getting ready to be deployed and gee ALL my food in the fridge is BAD!!!!
My model number is ssh25kfrfww Please give yours. Also my door NEVER locked from day one. As my children are older I didnt think it was a big issue till today.
Apr 14, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
How to replace the inverter on a gateway laptop
Fairly easy operation and is standard accross laptops for years.
Get yourself some microdrive screwdrivers
This is all slow and steady..if you get annoyed or frustrated at any stage, walk away for a few minutes and take a breath.
  • Carefully remove the rubber stoppers at the top and bottom of the screen and put aside (you need these to go back in later)
  • Remove the screws and set aside (get a magnet to hold onto them if you can..they have a tendancy to run away)
  • Very gently starting at the middle bottom, lift the bezel up and out slightly. You will hear it pop as it releases.
  • Move around and do one side, then the other side leaving the top intact.
  • When you have the 3 sides free, start along the top. You will have to slide the lid catches out of the way to pop it near those sections and is why it is left until last.
  • After you have the bezel removed, you will be able to see the inverter at the bottom (sometimes on the side)
  • Remove the plugs from both ends being careful not to break any of the connectors, and install the new inverter
Test the laptop before you put it all back together.
Hope that helps =)
Apr 09, 2008 | Computers & Internet
Maytag MSD2756G Side by Side Refrigerator Logo
1,514 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
