Question about Xantrex Technology XPower Powerpack 200 Plus Power Supply (9383183) 200-Watt Power Supply
Makes clicking noise when charging, and does not actually charge
Wont start making clicking noise light horn radio come on
The clicking noise is the starter solenoid trying to operate but not enough power to work. The battery must be weak.
Try charging the battery first then retry to start.
Autozone, Sears, and others will check and charge your battery free.
Autozone also has videos to show what to do.
Hope this helps.
Mar 29, 2015 | 2007 Chevrolet Chevrolet Cobalt LS
Where the relays for a dodge charger to fine the clicking noise my car won't crank just make two clicking noise
Try jumping the car with battery cables. If it starts ck that the charging system. If it is charging CK the battery.
Apr 28, 2014 | Cars & Trucks
Problems starting a toyota corolla
the clicking noise is the starter relay engaging, you say it starts w/jumpercables-starter is ok, either alt is not charging the battery or the battery can not hold a charge anymore any auto parts store can check it and tell you witch is bad
Sep 09, 2012 | 2000 Toyota Corolla
Car wont start light are dim, car making clicking noise when trying to start and electric windows wont let up or down
Charging system issue on car.
The car battery,alternator,fuses and relays needs to be inspected.
I suggest you to check out this help links given.Click the link below to go through the procedure,so as per that you can troubleshoot the problem .
How to inspect Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-inspect-vehicles-alternator.html
How to Test Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-vehicles-alternator.html
How to Service Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-service-vehicles-alternator.html
How to Replace Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-alternator.html
How to monitor Vehicles charging system?
http://repairhelpcenter.blogspot.com/2011/11/how-to-monitor-vehicles-charging-system.html
Car Alternator making noise? http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
---------Car Alternator Working Intermittently?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-working-intermittently.html
Car Alternator Bearing Makes Grinding noise?
http://repairhelpcenter.blogspot.com/2011/12/car-alternator-bearing-makes-grinding.html
How to Inspect Alternator Drive Belt?
http://schematicsdiagram.blogspot.com/2011/12/how-to-inspect-alternator-drive-belt.html
How to replace Alternator Drive Belt? http://repairhelpcenter.blogspot.com/2011/12/how-to-replace-alternator-drive-belt.html----------- Power windows not working after car wash?
http://howtobyme.blogspot.com/2011/11/power-windows-not-working-after-car.html
Car battery loosing its charge overnight?
http://schematicsdiagram.blogspot.com/2011/11/car-battery-loosing-its-charge.html
How to maximize fuel economy on your vehicle? http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
-------------Charging system problem troubleshooting? http://technoanswers.blogspot.in/2012/02/charging-system-problem-on-chrysler-lhs.html
------------For All types of Power window problem http://repairhelpcenter.blogspot.com/2012/01/pontiac-grand-am-power-window-not.html----------This will help.Thanks.
Jan 26, 2012 | 2003 Buick LeSabre
When i turn the key the escape wont start it just makes a clicking noise?
That noise is probably the starter solenoid rattling because the battery charge is low. Start out with a jump or make sure the battery is fully charged up.
May 21, 2010 | 2002 Ford Escape
Starter solenoid is makeing a clicking noise,fitted a new one and its still makeing the same noise
That clicking noise is an indicator that the battery is not fully charged. If the battery will no longer take a charge it needs to be replaced. Motorcycle batteries normally last two years. How old is your battery?
Feb 22, 2010 | 2005 Hyosung GT 125
My 88 vtr 250 makes one loud CLICK noise when i try to start the bike coming from the starter relay i bought a used one from ebay but same result ideas?
Start with making sure the battery terminals are clean. Then make sure the battery is fully charged. When that is in place try again, even if you jump it to another bike. Follow where the click is actually coming from, is it the relay or is it from the starter motor. Your problem is 98% caused but either a battery that is had it, (not holding charge) or a dicky starter motor. Having a manual will not go astray, I couldn't find one to suit your model, but you are welcome to fossick around. They are freebies:
http://www.carlsalter.com/motorcycle-manuals.asp
Jan 27, 2010 | 1997 Honda VTR 250
Battery Light Won't Go Solid. Lot's of clicking sounds and lights flashing (GN Netcom 9120).
It sounds like it may be a defective unit in that the charging points on the base and the earpiece are making intermittant contact, hence the clicking noise you get when the unit goes into headset mode and the fact that the battery never reaches a fully charged status.
A couple of things to try:
  • Check the charging points/contacts on the base and the earpiece for damage.
  • If they look ok, gently clean them with some spirits and try again.
Nov 07, 2008 | GN Netcom GN 9120 Professional Headset
Xantrex Technology XPower Powerpack 200 Plus Power Supply (9383183) 200-Watt Power Supply Logo
246 people viewed this question
Top Xantrex Technology Computers & Internet Experts
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
