Question about Goodman Heating & Cooling
Condensation drain on outside is producing a lot of water. How do I locate the main drain to try to onstop it?
  • 144 Answers
It is located at the in door coil of the unit
Posted on Sep 12, 2010
Why my air conditioner it's dropping water?
Condensation is normal but window air conditioners bases must be tilted to the outside of the window so the condensation drains outside. The drain hole in the pan can plug with dirt overfilling the pan allowing the water to leak inside your home.
Aug 25, 2014 | Frigidaire Heating & Cooling
How do I clean the condensation drain on my Fridgidaire fac127s1a?
Good Morning Friend,
I understand you want to know how to clean the condensation drain on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, and beginning to leak from the front. The drain hole is located beneath the compressor. You would have to get underneath that to clean the drain. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire FAC127S1A Air Conditioner
Ac leaking dripping lots of water outside
This is normal. this is just condensation from your A/C running. You A/C system drains under your car near the passenger side.
Feb 19, 2014 | Air Conditioning and Heat for Buick...
MY AC IS SHOOTING WATER
It's normal for ACs to produce condensation but for a window unit, they need to be installed to allow the liquid condensate to drain outside the room. If it has just started doing this, it's likely that the drain holes are clogged with debris or mold so the water builds up until it can be ejected by the fan.
Aug 31, 2011 | LG Electronic Window Air Conditioner
My amana window ac is blowing condesation out the vents. it is still cooling..is this a problem
There is a condensation drain on the unit that is probably plugged. It is natural for air conditioning units to produce condensation as the evaporator coil (the coil/fins that make the air cold as a fan blows air across it ) is much colder than the outside air temperature ( usually between 38 and 55 degrees depending on the unit ). There is a basin or tray at the bottom of the unit that catches the condensation as it drips off the evaporator coil, and there is a drain that allows the water to drain form the unit. If this becomes plugged the water will build up and eventually drip out of the vents of the unit. http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-circuit-and-cycle-diagram.html
In the image, air is blown across the coil in the bottom left section of the picture ( this is the "cold' coil). Condensation can form on this.
Jul 29, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
Pan missing when RUUD unit was installed causing problems with AC
I think your talking about an emergency drain pan. Is condensation building up on the outside of the unit? If it is, it means that the unit is not draining properly and the is too much water sitting in the main condensate pan. If you don't have the emergency pan, then the condensate drips from the unit onto the ceiling in your attic. I'm assuming a lot of things but this is what I think you are asking. You will have to find an ac supply company that will sell you an emergency pan and then it must be piped to the outside of the home or it can be plugged but with the use of a float switch. This switch will shut the unit off if the main condensate drain becomes clogged. You should have a professional come and wire a float switch unless you are knowledgeable about a/c equipment. I hope this answers your question.
Apr 01, 2009 | Heating & Cooling
Heating & Cooling Logo
35 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
