Question about Masterbuilt ESQ30B Smoker
I have a masterbuilt smoker (electric) and the digital display needs replaced. It is part # 990050048
SOURCE: Need electric plug for smoker
go to home depot and get the replacement element for the brinkmann gourmet smoker. costs $29.95. the replacement parts from charbroil (thermostat and element) will cost about $60.00. just remove the elemnt, replace it with the brinkmann and you're back in business.
Posted on Aug 16, 2008
  • 72 Answers
SOURCE: MASTERBUILT GAS SMOKER
Here is the link for the maunel online in pdf format
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
the main website says individual parts will be availible for sale soon, main website is
http://www.masterbuilt.com/index.html
hope this helps
Posted on Nov 09, 2008
SOURCE: Masterbuilt Smoker Model 20070108 Digitial Controller not working. Worked the first time, then no power. I hear a beep when I plug it in, but no display.
I had the same problem this morning. I seasoned it two days agao with an outside temp. of 50. This morning it was 8 degrees and when I pluged it in there was no readout. I removed the digital unit from the top and heated it with a hair drier and it worked when I reinstalled it. I think it had some moisture in it although the unit has been covered the whole time. I am going to call Masterbuilt tomarrow and see what their answer is to this problem.
Posted on Jan 25, 2009
  • 512 Answers
SOURCE: Where to put the wood chips in my gas smoker
Yes soak in water for around 30 minutes.
If you dont soak them they will burn.
Posted on Feb 25, 2010
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
Why does my centro electric smoker digital display show incomplete numbers
I would say that just like any other digital display whether it be a clock, radio, thermostat, watch, or whatever, the display is failing. Sometimes it is the heat (too hot where the display is, like in the sun) and sometimes it is too cold (like cooking in the snow).
Jul 09, 2014 | Masterbuilt 20070106 Electric Smoker
After reseting the circuit braker the smoker did not come back on
Hi and welcome to FixYa, I am Kelly
Most likely the heater has failed.
The manual for the 20070106 is on this page:
http://www.masterbuilt.com/manuals.aspx
The element kit is PN: 9907090033 (Est. $45.00)
My thoughts are the element has shorted out. Before ordering read out the element with an ohm meter. Read each terminal to ground with the at least one wire disconnected. Then read the element end to end. You should read resistance end to end but NOT end to chassis.
That is just for the element. You said it did not come back on after resetting the CB. If the display is blank the control panel has failed: Contact Masterbuilt at 1.800.489.1581 (<-Only source)
MASTERBUILT Customer Service at 1-800-489-1581.
Control panel PN: 990050048 Digital Control Panel Kit
Something has caused the control panel to fail... if there is a chassis short some where in the unit you can have a brand new control panel fail. Inspect the wiring and components for signs of damage BEFORE replacing the control panel. Repair any wire damage found. Thee are only 2 components that use electricity; the control panel and the heater. Finding a wiring problem should be simple.
Thanks for choosing FixYa,
Kelly
Jul 24, 2011 | Masterbuilt 20070106 Electric Smoker
I NEED A MANUAL FOR MY MASTERBUILT ELECTRIC SMOKER
Here is a link to the Masterbuilt Smoke House 30" Electric Smoker, Model # 20070210. Which is what I think you have. You can download and print the manual.
http://www.masterbuilt.com/pdf/manuals/20070210%20ESQ3082%20Manual.pdf
Hope this is what you need. Please let me know.
Mar 07, 2011 | Masterbuilt Electric 30inch Smokehouse ...
I need a replacement cord for my Masterbuilt Turk-N-Surf Digital Electric Fryer
Get to Masterbuilt Turk shop where you got the fryer and buy a new code for the replacement of the old one.
Dec 18, 2010 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
Can you buy a replacement heating element for the masterbuilt smoker
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
Jul 23, 2010 | Masterbuilt 20070106 Electric Smoker
Digital panel no longer works. need source for circuit board and approximate cost
Masterbuilt Digital Smoker no longer heats up and digital display has stopped working completely. The unit acts like there is no power to it and is completely dead. By replacing the digital component will this solve my problem
Jul 01, 2010 | Masterbuilt 20070106 Electric Smoker
Jan 17, 2009 | Masterbuilt 20070106 Electric Smoker
Masterbuilt ESQ30B Smoker Logo
653 people viewed this question
Top Masterbuilt Grilling Experts
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
