Question about SanDisk Sansa m240 MP3 Player
Power i dont no how to turn on my m240
There is a button at the top of the unit. it is longer than the others. all you need to do is press and hold it until the screen comes on. you do the same thing to turn it off.
Posted on May 14, 2008
Can I use my apple compluter to transfer music to the m240?
You can if the m240 is set to mass storage, but dont think about using itunes, you'll have to use the finder to drag/drop files into your player.
Sep 07, 2010 | SanDisk Sansa m240 MP3 Player
Screen frozen when powered on
turn it off, take out the battery, then replace it, turn it back on. see if this helps.
Mar 15, 2008 | SanDisk Sansa m240 MP3 Player
Dont know where the power is
Hold down the menu button until it starts to power up. Do the same thing to power down.
Apr 11, 2009 | SanDisk Sansa m240 MP3 Player
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
Wont bring up all songs on mp3 player sandisk m240
i had the same problem, the only solution is to reformat your mp3 player, when you explore, right click on "sansa m240" then click "reformat" once this is dont, it will deleat all your songs on the device. the sandisc support line is 1-866-726-3475 or you can contact me at www.freewebs.com/mixedjujitsu
Dec 28, 2008 | SanDisk Sansa m240 MP3 Player
Looking for a solution for my Sansa m240 MP3 Player
hmm weird problem, same error code youre having.
Why dont you try to reformat your player using PC. That may loose your current songs but i think that is the only thing you have to do.
Take cautions when connecting and unplugging to the PC that may cause errors and data corruptions.
Dec 17, 2007 | SanDisk Sansa m240 MP3 Player
Frozen screen
Hold down the power button for 20 or more seconds; when you release the power button, the Sansa Connect will restart on its own. If it doesn't restart, you did not hold down the power button long enough -- try again.
Make sure there's a battery in the player. This doesn't work when it is plugged into the USB port.
Oct 15, 2007 | SanDisk Sansa m240 MP3 Player
Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
Aug 02, 2007 | SanDisk Sansa m240 MP3 Player
My sansa M240 WonT turn on all the way
Jan 21, 07 I called and spoke with a Sandisk rep on Jan 16 about the "Sansa m240 startup screen" freeze-up problem that so many are experiencing. He said a bad batch was sent out in early December and on those m240's there is "NO POSSIBLE FIX" for that problem, but no plans for a recall. He said he could not discuss what the problem was, but I guess it would be a hardware issue, since a firmware issue could easily be resolved. He said anyone with this problem is requested to call Sandisk and get a MRA number, then return the m240 to Sandisk for a replacement. If you have one that's frozen on the Sansa m240 startup screen (all other freeze-ups can probably be corrected) take it back to your place of purchase or call Sandisk immediately.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
New SanDisk Sansa m240 MP3 Player
Hey regan have u fixed it yet?? Mine is doing the same thing and it wont turn on at all well write back!! ~sam~
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
15 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
