Question about Broderbund American Greetings Creatacard Platinum 8 for PC
I have Windows XP system and have recently upgraded my hard drive memory. Before the upgrade my Creata Card Gold 3 with Forget Me Not worked without any problems. Now the Creata Card portion works but the Forget Me Not calendar will not run. I depend on this portion for everyday events. What can I do?
  • gibsontl54 Sep 12, 2010
    How does this help my problem? I have CreataCard Gold 3 with Forget Me Not.
  • gibsontl54 Sep 15, 2010
    I have done this several times and the CreataCard workd fine but the Forget Me Not will not work at all.
  • 6,487 Answers
Base from the description of your problem what you can do here to correct the problem is to uninstall and reinstall the software from your computer, because sometimes some components of the software can be corrupted and that cause the problem.
Posted on Sep 12, 2010
  • Mark Gil
    Mark Gil Sep 12, 2010
    Uninstalling and reinstalling your CreataCard Gold will correct any problem with it like corrupted components of it that is needed of forgetmenot to run fine on your computer.
  • gibsontl54 Sep 14, 2010
    I have already uninstalled the program and reinstalled from the program CD and this still does not work. CreataCard works fine just not the Forget Me Not calendar.
I have installed windows 7 on p5vd-mx and it is not working fine what is the solution
This board may not support Windows 7 unless you install a video board with 128 MB or more of graphics memory. The onboard video appears to be only 64 MB. The main memory should be at 4GB even though Windows 7 will operate at a minimum of 1 GB(very slowly). I would first run the Microsoft Windows 7 Advisory software to see any compatibility issues. If it was my decision, I would get a new ASUS motherboard certified for Windows 7 with DDR3 memory, a 1GB graphics card, and a 1TB Hard Drive. Upgrading to Windows 7 requires a computer upgrade in most cases.
Aug 17, 2011 | ASUS P5VDC-MX Motherboard
I have windows 7 I uses creata cars gold in my old computer but now it won't run in windows what do I need to do
You can either upgrade to the latest Broderbund greeting card software. (See this site for a list of all the Broderbund Design and Print products: http://www.broderbund.com/c-6-design-print.aspx . You may not be able to import old projects into the new software.)
Creata Card Gold 8 was for Windows XP and older OS versions. I suspect the compatibility mode will not work but you can try it. Right click on the installer. Then choose Properties and then the Compatibility tab. Turn on Run program as Compatible with the appropriate OS. Then right click again on the installer and choose Run as Administrator. Then check if the program itself is running in the compatibility mode by right clicking again and choosing Properties. This is more likely to work if you have Windows 7 32-bit.
I do not know if this will work. A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from your CD in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them to print them. A printer can be installed to either the real or virtual machine at a given time. You will be asked to uninstall the printer if you try to install it in the virtual computer with it installed on the main computer.
I hope this helps.
Apr 04, 2011 | Broderbund American Greetings Creatacard...
Since upgrading to XP my CreataCard Platinum 7 will not work
Well first of all you can try to uninstall your creata card after then just reboot your system and after rebooting your system just again install the creata card........... let us know if this helps you..... please post comments for more help or information.........
Good Luck!!
Thanks
Feb 04, 2010 | Broderbund American Greetings Creatacard...
Ugrading to a newer system with higher performance specifications
You can upgrade you memory to 2 x 512MB DDR PC2700 333MHz, and install pretty much any size 2.5" IDE hard drive you wish. Installing Vista will make this machine very very slow. Windows 7 would be better as it uses less resources. Ideally XP Pro would be better suited based on this boards specifications.
Jan 10, 2010 | Compaq Evo N1000C Notebook
I want to upgrade my cpu, but dont know how to go about it.
it is not complicated for upgrade the desktop.as per my knowledge ur system configuration is-
Key Features
Form Factor Mini Tower
Processor Intel Pentium 4 1.6 GHz
Installed Memory 256 MB (SDRAM)
Operating System Microsoft Windows XP Home Edition
Recommended Use Business
ur system processor and memory both will be upgrade.
Memory-
RAM Technology SDRAM
Installed RAM -256 MB
Max Supported RAM 3 GB
Installed Video Memory 32 MB
Processor-
Processor Type Intel Pentium 4
Processor Speed 1.6 GHz
Processor Manufacturer Intel
Processor Upgradability Upgradable
Audio / Video-
Audio Output Type Sound Card
Max. Video Resolution 1920 x 1440
Hard Drive-
Hard Drive Capacity 40 GB
Hard Drive Interface DMA/ATA-100 (Ultra)
Thanks,
Nov 30, 2009 | Acer Veriton 7200 PC Desktop
Is there an upgrade for American Greetings Creata Card Platinum 8
You can try to right click the setup.exe file and select properties. Next select the compatibility tab and choose Run this program in compatibilty mode and click the drop down to find the version of XP that you think it will run in and the program will install and run in its own memory space and work in VIsta. Don't worry about any other settings on that dialog box. No need to buy a new copy. Now if the program has been installed and won't run, you can right click the shortcut and perform the same steps.
Jul 16, 2009 | Broderbund American Greetings Creatacard...
Upgrading my old laptop
this are the things that will help you upgrade your laptop. first of all replace the ram memory with a higher configuration.then get your hard disk reformat by reinstalling fresh operating system like windows xp-sp2 or windows vista.install all the latest updates and drivers and its done. please do not forget to rate the solution.
Jun 12, 2009 | Dell Inspiron 2200 Notebook
32 mb ATI Rage 128 Ulta upgrade
http://support.dell.com/support/edocs/systems/dim4550/techov.htm#1101565
The documantaions say thar you have an APG-port, i cant see any problem why you couldent upgrade it...if u can find a card.
Good luck
Nov 19, 2008 | Ultra ATI Rage 128 Pro Graphic Card
IBM Thinkpad T20 Type 2647
I currently own 3 Thinkpad T-20 Laptops. They all have a 700 mhz processor in them, and so will yours, more than enough to run windows xp, in fact, I am running Windows XP Profession on one of them. The PC100 is the type of memory it uses, not the processor speed. i recently installed a 120 gb drive in one of them so you will have no problem installing a 20 or 40 gb drive, or larger.
Dec 08, 2007 | IBM ThinkPad T20 2647 Notebook
Broderbund American Greetings Creatacard Platinum 8 for PC Logo
57 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
