Question about Kenmore Sewing Machines
I have thin cotton fabric and I can't get the tension right so the top 7 bottom stitches are the same. I am not a great seamstress but I can sew a straight line. What to do?
    Genius:
  • 1,788 Answers
Try using a tear away stabilizer or tissue paper under your fabric. We used tissue paper years ago and it worked great and practically free. Good luck
Posted on Sep 13, 2010
Ho can i get bobbin tension right?
Bobbin tension depends on the thickness of the fabric that you're sewing on. A cotton fabric should have medium tension...but a heavy wool would need a looser tension. Best way to get the tension right is to take a few stitches, then look at the bottom side of the fabric. If the threads are loose, then tighten the tension one notch or number. Sew a few stitches, then test again. If the fabric is pulling up tight, then loosen the tension and check again. Top stitches and bottom stitches should both be the same.
Jul 04, 2014 | Husqvarna Freesia 415
Cant get bobbin tension right
Tension of the bobbin depends on the type of fabric you are sewing on. Thin fabrics usually require mid to higher settings. Heavy weight fabrics require lower or looser tension. To check the tension, set to medium number, take a few stitches, then check the underside of the fabric. If the threads are too loose, be sure needle is raised, and change the tension to a higher setting. Take a few stitches and check again. If the fabric pulls too tight, then loosen the tension. Top threads and bottom threads should be the same when you have the correct tension. Your manual may have suggested settings for fabrics also.
My Brother LS 2160 is threaded but not stitching
Hi there Kathryn... when you load/thread the top cotton through the machine.... and then through the eye of the needle.... do you also load the bobbin case... or is it already in there and loaded as per instructions... ? What I normally do... is load up the bottom and top threads first.. making sure to put the top thread through the needle and make the thread end go through and behind the 'foot'... when placing on fabric to try... I make sure to load the fabric... with the top thread's tail going out through the presser foot and behind your foot.. sometimes.. if its the thread (some machines don't like certain threads)... I will manually (wind the right hand wheel) so that the machine does a few stitches.. before I use my foot pedal!.. I have both a serger/overlocker... and a Brother 8500 (sewing/embroidery machine).. I have been sewing for over years now...
You will need to change your needle... when you've used it for more than 6-7 hours continuously.. OR you notice that the stitches are not as they should be... in your fabric...
Mar 22, 2014 | Brother LS 2160 Sewing Machine
Thread tension
Needle/fabric/thread combination is wrong. hope this helps
Aug 17, 2017 | Sewing Machines
I am sewing a cotton piece of fabric for a dress and i do not know how to set the tension for cotton
The tension for cotton is set the same way tension is set for any fabric:
1. The thread should pull freely with a small resistance before/after it goes through the needle, on many machines that's half way on the tension adjustment.
2. The bobbin thread when dangled by the thread with the bobbin inside the case should drop down a bit when slightly flicking your wrist like you do with a yo-yo. If it reels out to the floor the tension is too loose. If it doesn't drop at all it is too tight.
3. Now make sure you use the right type of needle. For cotton you want a "sharp" and for reg. weight cotton about a size 10 maybe 12.
Now take a piece of strap cotton material like you're going to sew a seem and sew with a wide zig zag. Example the top side and then the bottom. They should appear identical, flat with needle holes at each side where the thread disappears to the other side. You should see no loop where the threads over lap each other and the material should not be puckering in the middle.
If that is not what you see then think this way:
The TOP side of the stitch is effected by the BOTTOM thread. the bobbin tension.
The BOTTOM side of the stitch is effected by the TOP /needle tension.
Adjust the responding tensions until the stitch looks the same on both sides. Now you are ready to sew your cotton! :)
Apr 26, 2011 | White Sewing Sewing Machines
Im using a free mashine foot to do embordery work and i cant get the tension setting right. ive tried all the diffrent settings and the stitch seems really loose when i sow. how do i get the setting...
First make sure you have a good quality cotton thread. I like to use Mettler silk finish 50 weight natural color. Start by sewing a straight stitch on two layers of light cotton fabric. You should have a tension the looks the same on both sides of the fabric when you sew. Adjust the tensions, if nessesary, and then try a sample on a practice sandwich. You might have to increase the top tension just slightly.
Apr 24, 2011 | Janome 4623 Mechanical Sewing Machine
My zig zag stitch is puckering fabric. I even went to the multiple zig zag, same problem. I decreased tension. What should I have double. Note: this was on single layer, along edge of fabric so I could...
Check the bobbin tension too. It could be too tight. Make sure you are using the right size needle for the material as well. Sheer, thin fabric needs a smaller needle, thicker material requires bigger needles. Bobbin tension is the typical problem as most think to adjust the top tension but don't check the bobbin tension.
Is your quilt peices cotton? Cotton shouldn't cause as much trouble sewing along the edge but don't use too long of a stitch length else it will seem to gather up. Puckering side to side however is a tension problem usually. With sheerer fabrics that cause a problem sometimes you can put thin paper underneath, sew through both and then pull the paper off after sewing. (thin like the iron on type interfacing type fabric but like paper).
Mar 25, 2011 | Janome Sewing Machines
In what order do i put the tension assembly together
Probably the most important contol on your machine is this one that regulates your top thread tension there are reason for having to reset your tension.Classified your fabric that you are using there are several set up of tension in every fabric that you use.Cotton fabric is most easier other than silk fabric make a record on this set up.The required tension depend upon the stiffness of the fabric,thickness,layer of rabric to be sewn and required stitches.Try cotton fadric turn tension dial to N0. 3 and Stitch set to from 8 to 12 defend to what is nice to you.
Mar 07, 2009 | Necchi Sewing Machines
JANOME RX18S
If it was sewing correctly BEFORE the needle break...why did the needle break in the first place?...and what fixes did you make?
If it sewed properly...what changed?
Cut your upper thread close to the spool...make sure the presser foot is raised and pull the cut off thread section through/out of the machine from the needle area (sewing direction...do not pull the thread backwards!)
Clean out the bobbin area...remove any traces of lint or pieces of thread...look for any broken off needle pieces... brush the bobbin area out....then add a drop of sewing machine oil (but only if your manual says to oil that area).
Remove the needle plate to expose the feed dogs...brush/clean out that area too and add a drop of sewing machine oil...then secure the needle plate back on.
Replace the needle...do it again...yup...some needles arrive bad from the factory. Make sure the needle is inserted and positioned properly. Then thread the machine WITH the presser foot in raised position. (The thread needs to get seated into the upper tensions.)
..with the.presser foot down...thread the new needle.
Oh...and use the correct needle for the thread. (a universal 80/12 is standard).
Thread can cause issues too. Try a different bobbin, or maybe a different spool of thread to see if that makes a difference.
Mar 25, 2017 | Janome Memory Craft 9500 Computerized...
Sewing Machines Logo
53 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
