Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
I have a whirlpool Gold side by side frige Model number G56 SHEXNLOO . This morning we woke up to find that the light & the temp control lights are out on the frige side but is keeping frige cold. We put a new bulb in so that is not the problem. Please offer any help you can on this issue for us. Thanks in advance.
SOURCE: whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Posted on Jul 30, 2008
garing
  • 998 Answers
SOURCE: Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Posted on Aug 24, 2009
  • 48 Answers
SOURCE: side by side, freezer very cold, frige warm
Any ice buildup is due to one of 2 problems. Either the defrost circuit is not working properlyor the drain hole where the defrosted water drains down to the underneath pan is clogged. I once found a spider's nest in the drain of a refrig that was in a seasonal house after the winter shutdown.
Very common is a defective (open) defrost thermostat, or a bad defrost timer. But for a unit only 5 yrs old I'd start with the drain hole. BE SURE YOU GET ALL THE ICE OUT. Use hot water, hairdryer etc, so water flows freely to drain pan
Sea Breeze
  • 4655 Answers
SOURCE: my whirlpool gold frige ices up and doesnt keep
The most likely problem is mthe part number W10135899 defrost control board. Next likely is the defrost heater and the defrost thermostat. Thanks, Sea Breeze
Posted on Oct 07, 2009
dmftrucker
  • 1922 Answers
SOURCE: I have a Whirlpool side by side. GD5SHAXNB00. The
you definitely need to replace the control board in rear left corner in lower back side when light bulbs go out it destroys the board go to appliance parts pros 1-877-477-7278, I have done 3 of these in the last week its very common board is $80.25 shipped
Posted on Nov 03, 2009
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator lights both not working. Freezer / Fridge LED Control numbers not lighting up. Still works fine. Freezer lights work fine. Whirlpool Gold Model GS5SHAXNL00.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirpool gold Frige no light or temp display working
I am having the same problem does anyone have a solution?
Dec 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator model GD5rha does not cool but freezer portion does.
replace the control board usually lights are out in refrige side also ans temp readout is also out part # 4334000 appliance parts pros $80.25 shipped
Oct 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold gs5shaxnl side by side-the ref. side has no power and when the door is opened there is a clicking sound until the door is shut -temp is 33 degrees-everything is working on the freezer side...
replace the control board Part#4334000 appliance parts pros $80.25 if you recently blown a light bulb in the refrige section this will also ruin the board
Oct 11, 2009 | Whirlpool Refrigerators
My whirlpool gold frige ices up and doesnt keep refrigerator side cold
Oct 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a 2004 whirlpool gold model #gd5rha. When
you need a new control board,this is very common,especially if the bulbs on thr refrige side blow out,this creates a surge and ruins the control board $85.00 w/shipping at appliance parts pros or 1-877-477-7278
Oct 06, 2009 | Whirlpool Refrigerators
Whirlpool gold side by side 2006 defrosting
temperature gadge must have been bumped, everything is working right now. Thanks
Jun 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
